wheel bearing retaining lock nut removal
Discussion in '2nd Gen Tundras (2007-2013)' started by Maqinatya, May 7, 2022.
  1. May 7, 2022 at 2:05 PM
    Maqinatya
    Maqinatya [OP] New Member
    Hello,
    looking to remove the 8 pin bearing locknut found on 2wd front wheel bearing.
    I have the 3/4 inch 8 pin tool but have not found a way to secure it well enough to get off. Any help would greatly appreciated.
  2. May 8, 2022 at 8:45 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Stick it in a giant vice.
  3. May 8, 2022 at 8:49 AM
    “J”
    “J” New Member
    NC
    2021 Tundra SR Barcelona Red
    Have you tried an impact wrench? With a couple C-clamps.
    NueveTundra likes this.
  4. May 8, 2022 at 10:38 AM
    TXTundra2722
    2015 Black Tundra
    Can't you buy that entire piece? I'm assuming you're changing the bearings out?
  5. May 8, 2022 at 4:09 PM
    Dr_Al
    Dr_Al New Member
    Al
    You could get an old steel wheel from a junkyard that's the right bolt pattern. You can put that in a vice. Or possibly drill holes in a piece of steel to match the pattern that could be put in a vice.
  6. May 8, 2022 at 4:11 PM
    That's what I thought. The front is one assembly and the rear has to be pulled apart.
    TXTundra2722[QUOTED] likes this.
  7. May 9, 2022 at 3:41 AM
    TXTundra2722
    2015 Black Tundra
    Agreed, I'm all about saving money, but sometimes you don't want to take things down this far.
  8. May 9, 2022 at 3:48 AM
    TXTundra2722
    2015 Black Tundra
    I'm only posting this as an example and am not recommending this particular brand. You can find the front hub for ad low as $85 dollars. Everything I've read is its easy to tear or damage this part if you try and take it apart.
    WVI likes this.
