Wheel offset
Discussion in 'Wheels & Tires' started by Fire132, Mar 31, 2021.
  1. Mar 31, 2021 at 3:30 PM
    Fire132
    Fire132 [OP] New Member
    2008 Black Tundra D-Cab Long Bed 4wd
    Flush ARE cap 8’ bedslide 285 55 20’s on TSS bbs 20” wheels 350,000 KMS & counting
    Hi all,
    Looking to put some new wheels and tires on my truck.
    Right now I have 285 55 20’s on TSS bbs wheels. They’re 20x9 and as I understand it, have an offset of +50.
    I’m looking at 20x9 KMC 535 Renegades in flat black.
    They have an +18 offset.
    I’m thinking of putting 295 55 20’s on the wheels. Any comments on how far out they’ll be? Cheers
  2. Mar 31, 2021 at 4:52 PM
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    Offset is based on the center of the wheel width. A + offset is closer to the outside (visible) side of the wheel. A negative is closer to the inside.
    A +50 offset means the wheel moves IN to the vehicle 50mm. So a +18mm offset will only be 18mm in.
    The new wheels will stick out 38mm(1.25inches) more than the current wheels.
    EDIT: YOU NEED TO CONSIDER WHEEL WIDTH. If you change wheel width. You have to subtract (or add) half the difference.
    For example: a 9" wheel with a +50 offset to a +18 will give you 1.25" further out.. But a 9" at +50 to an 8" at +18 will only give you 0.75" further out. It's all relative to wheel width.
    Visual reference:
  3. Mar 31, 2021 at 6:21 PM
    Fire132
    That sounds great, thanks!
  4. Mar 31, 2021 at 6:32 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Black Wolf likes this.
  5. Mar 31, 2021 at 6:54 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You don’t need to calculate all that. And wheel width doesn’t make a difference because the tire width will determine the final poke. Use this formula for exact poke. It’s pretty ingenious.
    https://www.tundras.com/posts/189124
  6. Mar 31, 2021 at 6:59 PM
    Fire132
    That’s awesome, thanks.
    295/2 - 18 - 90
    =39.5
    1-1/2” total
    cheers
    joonbug likes this.
