Wheel Spacers
Discussion in 'Wheels & Tires' started by Hitz2021pro, Apr 29, 2022.
  1. Apr 29, 2022 at 6:42 PM
    Hitz2021pro
    Hitz2021pro [OP] New Member
    2021 Tundra Pro Crewmax
    Just put 1.25 spacers on. Tough choice rather to do or not, but I do like.
    Tundra805, WFD473, Rugerla1 and 13 others like this.
  2. Apr 29, 2022 at 6:55 PM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    Looks great. I just ordered some 1.25" wheel spacers from BORA for my land cruiser wheels (+60mm offset) to push them out some.
    65SNAKE likes this.
  3. Apr 29, 2022 at 7:07 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Looks great.
    I've been debating this too.
    You ever had bad experience with spacers?
    Only time I ever used spacers was on a high mileage tacoma and I had to replace front wheel bearings a few months later. Not sure if coincidence. My tundra is over 100k miles so maybe it might be asking for trouble.
  4. Apr 29, 2022 at 7:31 PM
    Make sure you retorque them after a 100 miles or so.
    pvn.beluga likes this.
  5. Apr 29, 2022 at 7:42 PM
    Hitz2021pro
    I never had spacers before and have heard a lot of good and bad. Seems like the most knowing people on the subject all say the same thing, it’s no problem and safe when installed properly. I did the initial retorque today and not one of the 20 nuts had moved. Put a line of white paint on them so I’ll a quick check option in the future. Thanks for the compliments!
    alb1k and bulldog93 like this.
  6. Apr 29, 2022 at 10:23 PM
    Airfire06
    Airfire06 New Member
    2016 trd pro
    Nothing yet
    Looks good got spidertrax 1.25 u can rock 295/70r18
    Tundra805, jmladdy, J&ATundra and 5 others like this.
  7. May 4, 2022 at 2:19 AM
    schacal06
    schacal06 New Member
    Lunar Rock 2021 Tundra TRD PRO
    AT tires / Leveling kit
    Was thinking of getting the spidertrax spacers but I don't want blue spacers showing, so looking into Bora now.
    Blang805 likes this.
  8. May 4, 2022 at 5:15 AM
    Depending on the wheels, it's hard to see them.
    schacal06[QUOTED] likes this.
  9. May 4, 2022 at 5:38 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I have trd offroad wheels and you have to look only at certain angles to see the blue. Looks great! 1.25 spacers completely change the image of the truck
    schacal06 likes this.
  10. May 5, 2022 at 7:32 AM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    Any mods to make? Assume you had to take off front mud flap.
  11. May 5, 2022 at 7:47 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I have 6 lug spidertrax and boras that I used for a test fit before ordering steel spacers. I noticed the boras have a sightly tighter hub centric tolerance to the rotor. They both likely leave a hair of space for heat expansion. Both are high quality and grade 10.9 lugs.
  12. May 5, 2022 at 11:42 PM
    schacal06
    i have the stock TRD PRO wheels. i tried googling but nothing really popped up.
  13. May 5, 2022 at 11:42 PM
    schacal06
    do you have picture of how it looks?
    thanks.
  14. May 6, 2022 at 4:44 AM
    65SNAKE
    65SNAKE New Member
    RON
    2020 TRD PRO
  15. May 6, 2022 at 5:14 AM
    Rockanock
    Rockanock 21 Chevy 2500
    OP that looks great
  16. May 6, 2022 at 5:43 AM
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I'm in the camp that as long as you buy high quality spacers like BORA or Spidertrax and install/maintain them correctly, they are fine. I liked the Toyota wheels, so wanted the wheel/tire to stick out a little more and more factory UCAs clearance. Otherwise, I would have just bought aftermarket wheels with the correct offset. I've run spacers for years on 4Runners, Tacomas, and now my 2016 Tundra. I started out with 1.25" but went to 1" BORAs to help a bit with crap being thrown on the side of the truck:
    1.25" Spacers, Off Road Wheels, 295/70 R18 Cooper Discoverers XLT AT3, and TRD Pro suspension + .5" CB front spacer, 1.5" Rear shackles:
    Same tires and suspension but TRD Pro BBS wheels and 1" BORA wheel spacers:
  17. May 12, 2022 at 7:59 AM
    Airfire06
    2016 trd pro
    Nothing yet
    Just the front and rear flaps and I melted back the front
  18. Jun 7, 2022 at 5:34 AM
    65SNAKE
    65SNAKE New Member
    RON
    2020 TRD PRO
    I used Extreme 1 1/4" spacers. Very satisfied with Extreme parts in the past an pleased with the spacers. Checked the torque on every lug after a couple hundred miles and they were still on spec.
  19. Oct 2, 2023 at 6:07 PM
    csgaddy
    csgaddy New Member
    with the 1in bora spacers, did you have to trim the studs on the front or back in order to fit them?
  20. Oct 3, 2023 at 10:30 AM
    coTony
    Tony
    Montrose, CO
    Anyone ever use a 0.375" BORA spacer? I have a slight rub on my UCA and would like for it to just clear "but" not sure if that will solve the problem or create other rubbing. I should be fine, I have space everywhere except for of course where I did not plan for it to happen
    EDIT: I am not sure how this is supposed to work with hub centric wheels being this thin. I need to check my wheels and see how thick the hub lip is
  21. Dec 16, 2023 at 9:22 PM
    S13ka24de
    S13ka24de New Member
    This is not true. The oem 20" i have on my 2020 even with the pocket got press marks on them and really messed up my front. After i installed the 1" with that protruding bolt issue the front was never the same. I went to 2" but have shaking issues at 70mph. Now i took them out completely
  22. Dec 19, 2023 at 8:08 AM
    Badknees
    Badknees New Member
    South Carolina
    Sorry, I never want to mislead anyone with my experience using 1" BORA spacers. I had no issues and "did not recall" the front situation as I only took photos of the rear. I have deleted my previous post.
  23. Apr 13, 2024 at 4:23 PM
    Everything G3 n Yota
    Everything G3 n Yota New Member
    Kevin
    2015 super white tundra ltd double cab
    Firestone air bags. DS grab handle. Toyo 10 ply tires
    Hello all. I just installed 1 inch wheel spacers on my 2015 tundra double cab. The 1 inch spacers had plenty of room to spare regarding the studs. The rear studs only stuck out maybe 1/8 inch past the spacer. The front studs were flush. The OEM aluminum wheels have a good 1/4 inch indentation on the rear of them.... So the 1 inch spacers work perfectly without trimming the studs. But..... After I had them all installed, I noticed them passenger rear wheel stuck out about 3/4 inch further than the left side. I triple checked and could not figure it out. But then, I searched another thread here and ..ITS NORMALL, ON ALL TUNDRA'S. you just don't notice it until you space the wheels out or put wider tires on. Oh well ,nothing to worry about, I just hope the 4
    wheel alignment goes well next week.
    TundraTXTSS, WFD473 and Badknees like this.
  24. May 22, 2024 at 1:31 PM
    TexasTundy
    TexasTundy New Member
    19 SR5 CM 4x4
    Has anyone changed to shorter wheel studs to accommodate 1 inch spacers? I have 1 inch Bora spacers on order, but would rather swap studs instead of trimming them.
  25. May 23, 2024 at 5:38 AM
    Kevin
    Hello Texas, what rims do you have?. I have the OEM limited wheels and the 1 inch spacers worked just fine. There was plenty of room , as listed above, this he OEM wheels have a recess in the back. And the studs barely stuck out past the spacers. Regardless of what others said... Mine only stuck out about 1/8 inch past the spacers. Hope this helps.
    TundraTXTSS and Badknees like this.
  26. May 23, 2024 at 5:44 AM
    Dually HD trucks come factory with spacers...if this is a concern.
    Badknees, ZappBrannigan and WFD473 like this.
  27. May 23, 2024 at 2:09 PM
    TexasTundy
    19 SR5 CM 4x4
    I have the black wheels with the machined face. I’m not sure how else to describe them. 18 inch.
  28. May 23, 2024 at 3:16 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Sounds like the factory off road package wheels, 18x8 and +60 offset
  29. May 23, 2024 at 3:21 PM
    TexasTundy
    19 SR5 CM 4x4
    That’s them
  30. May 23, 2024 at 3:35 PM
    Kevin
    I also did the 1.5 inch front lift/level kit at the same time I put my spacers on. Had truck aligned and everything worked great. No trouble with alignment either. Truck looks perfect... Just a little wider stance and a slight rake to the front ,ales or looks bigger, it still looks factory. but it looks almost like a 3/4 to truck.
