Wheel Spacers
Discussion in 'Wheels & Tires' started by SkyWriter, Sep 26, 2024.
  1. Sep 26, 2024 at 3:13 PM
    SkyWriter
    SkyWriter [OP] New Member
    2024 TRD Pro Terra
    IMG_1656.jpg Hey everyone.
    I have a 2024 TRD Pro and I’m installing the Westcott Preload Collar Lift Kit next month. I already have 35” Toyo Open Country R/T Trails and really like the look with the TRD BBS Forged wheels, I just want to improve the stance a touch. I’m thinking about 1.5” spacers but need help with what brand you recommend and also where to purchase them.
    Any assistance is greatly appreciated and thanks in advance!
    Mdl likes this.
  2. Sep 26, 2024 at 4:26 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I had Bora spacers for a very short time. I liked the way they made the stance look but where I live it rains a lot and with the spacers the tires slung a lot of stuff on the truck. No more spacers, sold em cheap.
    Just my experience.
  3. Sep 26, 2024 at 4:41 PM
    Taikowaza
    Taikowaza New Member
    Spidertrax. Absolutely love mine
  4. Sep 26, 2024 at 4:43 PM
    SkyWriter
    2024 TRD Pro Terra
    I've heard good things about Spidertrax and Bora. Where did you buy yours from and are they 1.5"?
  5. Sep 26, 2024 at 4:45 PM
    Taikowaza
    https://www.tundras.com/threads/trd-pro-wheel-well-camo-trim.111271/page-17#post-3208845
    A number of us who installed the lighted TRD Pro camo wheel flares used spacers. Ordered my Spidertrax direct from the makers. Also called them w/questions and they were super helpful. The anodized blue is fantastic. Make sure to follow the detailed torque specifications and then check them after driving the recommended # of miles. After that they are GTG. Love them, beautiful machining and rock solid.
    read about them here and I suggest buying direct from them not Amazon or other places. You never know and this is mission critical equipment. https://www.spidertrax.com/whs034?sc=2&category=29920
    https://407909.app.netsuite.com/cor...8851&c=407909&h=28485e5b3a3e31bfbec6&_xt=.pdf
  6. Sep 26, 2024 at 6:02 PM
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    Not a fan of wheel spacers. They put undue stress on the suspension geometry. Change out the wheels if you want more poke.
  7. Sep 26, 2024 at 6:37 PM
    Taikowaza
    Soupbean77 likes this.
  8. Sep 26, 2024 at 6:39 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Seems dramatic, but in 38 years of professional driving, I've seen that happen a few times.
    Not actually coming off, but the aftermath of it happening..:thumbsup:
  9. Sep 26, 2024 at 9:13 PM
    brutalitybob
    brutalitybob New Member
    Im no expert here but not sure if thats true as your moment is still the same your just offsetting the wheels with the same metal were as the spacers are just another connection from the wheel to the hub. So yes you do induce a "failure" point but still the same amount of stress on your suspension geometry.
    Soupbean77 and Backslider like this.
  10. Sep 26, 2024 at 10:04 PM
    blenton
    blenton New Member
    I believe @brutalitybob speaks the truth. Spacers create the same moment on the hub as a wheel with a more negative offset. It has been discussed many times before, but it would seem that there are only two real downsides to spacers: 1 - cheap, lug centric spacers are enticing due to the price, but can be poorly machined, made of poor quality metal, and lack the hub centricity required by our vehicles to safely carry loads; 2 - there are technical more parts that could fail, being two sets of studs and two sets of lugs. I say technically, because while they could fail, that doesn't indicate an increased propensity to fail. Else, the hub/bearing/front end components see the same stress with spacers as the do with different wheels.
    To answer the OP's questions, generally speaking, ~1.25" spacers are generally the recommended spacer thickness, and it is always recommended to go with a quality product. Spidertrax and Bora have proven to be of high quality. If your factory wheels are +50mm, adding a 1.5" spacer as you suggest would change that offset to 50mm - (1.5in*25.4mm/in) = 11.9mm. That would make your wheel equivalent to an aftermarket wheel with ~ a +12mm offset. A 1.25" spacer would change it to ~ 18mm offset. Most quality aftermarket wheels usually stay around this offset as a sweet spot for parts wear vs look vs minimized rubbing. 0mm offset is also quite popular, but a little bit of poke and more scrubbing/fitment issues.
    Mdl and Soupbean77 like this.
  11. Sep 26, 2024 at 11:30 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, DIY Traction Bars, Tuning by snivspeedshop.com
    I've been running Bora 1 inch spacers on the fronts since 2012 with no issues. Keep up on maintenance and proper torque specs.
    blenton and Soupbean77 like this.
  12. Sep 27, 2024 at 5:53 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    On my 2010 4Runner Limited with the factory 20”x 7” rims and no lift, I increased tire size to
    275/55-20 and had Bora make a set of 19mm (3/4”) spacers. Ran it like that for a few years until I sold it to purchase my 3rd gen. Pulled the spacers before I sold the Runner and will probably eventually install them on the Tundra as they have the same bolt pattern. As others have stated, proper installation, torque and periodic torque check/stud inspection is essential. Along with Spidertrax and Bora, another quality spacer manufacturer is Ichiba. Have been running a set of Ichiba spacers on my Corolla slot car for about fifteen years for wheel track and handling purposes with no issues.
    Mdl likes this.
