Wheels wont come off!
Discussion in 'General Tundra Discussion' started by RockWarrior2k10, Apr 23, 2020.
  1. Apr 23, 2020 at 2:36 PM
    RockWarrior2k10
    RockWarrior2k10 [OP] New Member
    2010 Tundra Rock Warrior
    Bull bar with led light bar, 35in tires, more to come.
    Got the lug nuts off but the wheels wont come off the truck!20200423_163619.jpg
  2. Apr 23, 2020 at 2:40 PM
    Caveman
    Caveman New Member
    Is the axle or frontend lifted off the ground and secured?
  3. Apr 23, 2020 at 2:41 PM
    SouthWestGA
    SouthWestGA New Member
    Probably seized by surface rust to the rotor hub face
    It happened to me before
    I ended up trying 3 things
    1. Letting wheel back on to ground with lugs off to see if it breaks loose
    2. Put a block of wood Over the tire rim and hit with a hammer
    3. Drive to tire shop and watch them come out with a giant rubber sledgehammer like the ones at carnival games. A few bumps with that and it popped off
    To avoid that happening again,i cleaned the hub surface and applied Anti Seize,and used a torque wrench for proper lug torque
    Finch and T-Rex266 like this.
  4. Apr 23, 2020 at 2:43 PM
    RockWarrior2k10
    I got it up on a bottle jack and a jack stand under the center frame cross member
  5. Apr 23, 2020 at 2:44 PM
    mcm0455
    mcm0455 New Member
    2020 Tundra Platinum
    I always wire brush the hub surface and use anti seize when I'm swapping winter wheels for the summer set. Works great!
    TechWrench likes this.
  6. Apr 23, 2020 at 2:46 PM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    1. Make sure it is securely sitting on a jack stand.
    2. Kick the top sidewalk of your tire a couple times (bottom of your foot).
    Just had to do this yesterday. I was surprised how hard It was stuck on there.
  7. Apr 23, 2020 at 2:48 PM
    RockWarrior2k10
    I'm glad it isnt a major problem though. Just stuck on lol thanks guys! I'll post a pic once i get it off
  8. Apr 23, 2020 at 2:51 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    If all else fails - Bottle or scissor jack against the opposite wheel with a length of 2x4 across in contact with the stuck wheel. Pop it right off.
    Anti-seize is your new friend, just not on the wheel studs.
  9. Apr 23, 2020 at 3:04 PM
    Coupe
    Coupe New Member
    James
    Houston, Texas
    2008 Toyota X-Runner
    TRD S/C, headers, APR X1, T56 Magnum 6 spd, NST pullies, Stptech Big Brake Kit, dropped, leather
    When this happens to me, I loosen the lug nuts, but leave the nuts on the studs. Just back them off of being tight. Then go drive around a cul-de-sac sack a couple of times. Then go jack up the truck and remove the wheel.
  10. Apr 23, 2020 at 3:05 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    That happened to me before also. I just got a small sledge and hit the backside of the wheel.
  11. Apr 23, 2020 at 3:16 PM
    RockWarrior2k10
    A swift kick for attitude readjustment and it came off lol my rotor is slightly warped so look like that's my next project. 20200423_171453.jpg
    eccracer104, Tundra2, D4x4TRD and 3 others like this.
  12. Apr 23, 2020 at 4:16 PM
    SouthWestGA
    Rotor may be fine
    Wheel was torqued on unevenly?
  13. Apr 23, 2020 at 4:35 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Rotor warping are a known issue in the 2nd gen. There is a TSB issue referencing this, you may want to inspect your studs to ensure they're not damaged. Wheels will stick to the hub as rust shows up... There is a solution that you can put on the hub to evade this situation. I've been there done that. I would suggest you acquire some jack stands for safety and to prevent damage in case your jack fails, or vehicle shifts and fall off the jack.
  14. Apr 23, 2020 at 5:02 PM
    RockWarrior2k10
    I got the wheel back on but upon inspecting the rotor it seemed to be warped slightly. I could see some thinner spots on the edge. Any suggestions on cheap but good quality rotors and pads?
  15. Apr 23, 2020 at 5:10 PM
    blackdemon_tt
    I would stick with OEM... Honestly, you can get them at some stealerships online cheaper than aftermarket options. I bought an aftermarket rotor and it failed, it cracked and it took my rear caliper with it. I may be the exception, but that is my experience.
    rebmo likes this.
  16. Apr 23, 2020 at 5:24 PM
    Shifless Joe
    Shifless Joe New Member
    Mesa AZ
    2016 TRD Off-Road
    NAPA Ultra Premium Polymer Coated
  17. Apr 23, 2020 at 5:33 PM
    RockWarrior2k10
    Any websites that give good discounts? Military, or forum?
    eccracer104 and 831Tun like this.
  18. Apr 23, 2020 at 6:28 PM
    Spaceiscool
    Spaceiscool Something something.. danger zone?
    JL
    Ontario
    2008 White Tundra CM TRD
    Spray painted rims
    What, do we all not kick our tires off? I thought thats just how its done! :bananadead:
    Will be doing the anti seize trick next time. :hattip:
  19. Apr 23, 2020 at 9:09 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Put a 4x4 flat on the ground and use it to knock the tire off.
  20. Apr 23, 2020 at 9:37 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Ask our very own @eccracer104. Great guy and he'll set you up
    eccracer104 likes this.
  21. Apr 23, 2020 at 10:49 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Yea, these trd wheels are always stuck.. clean up the hub and put a wee bit of anti seize and it goes a long way.
    (you have to be careful too, sometimes tightening them down due to the crud that made them hard to remove, makes it so they don’t tighten down all the way)
    blackdemon_tt and TechWrench like this.
