Where can I find the transmission plugs torque specs?
Discussion in '2.5 Gen Tundras (2014-2021)' started by JEHTUNDRA, Mar 31, 2023.
  1. Mar 31, 2023 at 6:14 AM
    JEHTUNDRA
    JEHTUNDRA [OP] New Member
    2021 Crewmax SR5 4x4
    Doing a drain and fill on 2021 and need to find the torque specs for the fill, drain, and check plugs.
    I found 15 ft lbs for the drain and check plug and 29 ft lbs for the fill plug up top. Is this still right for the 2021?
  2. Apr 4, 2023 at 3:01 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    https://www.tundras.com/threads/tundra-maintenance-guide.315/
