Where do I find the remote wire to tap into
Discussion in '3rd Gen Tundras (2022+)' started by Solsurvivor, Feb 18, 2024.
  1. Feb 18, 2024 at 10:14 AM
    Solsurvivor
    Solsurvivor [OP] New Member
    2019 tundra
    I have 2-10’s plus an amp all hooked up and ready to
    go. I tapped into the green/brown and grey/black wires in the door sill using a converter. I tested it by running the remote wire from the new amp straight to the battery and it works perfectly(JUST TO TEST IT)
    Obviously I need to tap into the factory remote wire, anyone know which wire it is?
    Driver side door sill??
    thanks in advance
  2. Feb 18, 2024 at 12:28 PM
    raylo
    raylo not so new member
    Frederick, MD
    The easiest way might be to use a fuse tap on a switched +12V circuit in the fuse box behind the glove box. Then run the wire down the door sill to the back.
  3. Feb 18, 2024 at 12:39 PM
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    2024 Tundra Hybrid Platinum
