Where to buy alternator?
Discussion in '1st Gen Tundras (2000-2006)' started by robabeatle, Aug 22, 2024.
  1. Aug 22, 2024 at 2:21 PM
    robabeatle
    robabeatle [OP] New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Looking for a 130 A alternator for a 2002 AC. I dont see it at RockAuto.
    Can you suggest a reputable place to buy it?
    Thanks.
    FrenchToasty likes this.
  2. Aug 22, 2024 at 2:45 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Toyota or Denso only
  3. Aug 22, 2024 at 2:48 PM
    robabeatle
    AZ
    Yes, looking for Denso.
  4. Aug 22, 2024 at 2:49 PM
    FishNinja
    Lee
    06DC2wd
    It wasn't a question...........
  5. Aug 22, 2024 at 2:57 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Was the 130 an upgrade option? I see a 70amp and 100amp available from Toyota.
  6. Aug 22, 2024 at 3:00 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I ordered mine online from the dealer. Not sure if I got the 130 or not
  7. Aug 22, 2024 at 3:00 PM
    FishNinja
    Lee
    06DC2wd
    130amp comes with the tow package I believe
  8. Aug 22, 2024 at 3:04 PM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    robabeatle[OP] and FrenchToasty like this.
  9. Aug 22, 2024 at 3:14 PM
    MT-Tundra
    Montana
    Will that fit an '02? I see it's for '03 and up. But yeah, they don't show a 130amp option for an '02. Just 70 (discontinued) & 100.
  10. Aug 22, 2024 at 3:17 PM
    des2mtn
    SW
    Tonto cover
  11. Aug 22, 2024 at 3:17 PM
    robabeatle
    AZ
    So you guys are seeing what I am seeing. I didnt think that that the 03+ was the same as the 02 as the connector is different. I have the 130 A due to tow package. With my stereo, I want to stay with the high amps.
    I was agreeing with you that I am only looking for Denso.
  12. Aug 22, 2024 at 3:33 PM
    robabeatle
    AZ
    Local dealer want $330 plus $75 core charge. ugh
  13. Aug 22, 2024 at 3:36 PM
    FishNinja
    Lee
    06DC2wd
    Well shit if you don't I will. That's not a bad price at all.
    Weagle and FrenchToasty like this.
  14. Aug 22, 2024 at 3:36 PM
    des2mtn
    SW
    Tonto cover
    Shoot, didn't look at what year your truck was. I don't think they actually offered a 130A in the 02 even with a tow package. You might not have one unless a PO swapped one in. Either way, I'd still try to get the 130A/150A and do the modifications to make it work.
    Another option is to replace the brushes yourself
  15. Aug 22, 2024 at 3:39 PM
    des2mtn
    SW
    Tonto cover
    Denso are like $160 + $79 core from RockAuto when they're in stock. That's what I paid for my 150A. Didn't return my 130A for a core.
  16. Aug 22, 2024 at 3:40 PM
    FrenchToasty
    Mo
    Bone stock
    Is that online or over the phone? Desert toy has decent prices online
  17. Aug 22, 2024 at 3:45 PM
    FishNinja
    Lee
    06DC2wd
    Reman'd? I wonder if OP's quoted one is a new or reman'd
    everytime I FIND a 130 from anywhere other than the dealer. The price difference is like 260-275 vs $350ish
    negligible if you're in NEED of the alternator. I guess I would hold out if I could wait and knew they would have them in stock.
  18. Aug 22, 2024 at 4:04 PM
    robabeatle
    AZ
    Phone
    Reman'd
    I swear that when I looked up my VIN a while back the tow package stated 130 A and the dealer said that they have it for my year. Now I am slightly confuzzled.
  19. Aug 22, 2024 at 4:04 PM
    robabeatle
    AZ
    The diode(s) are shot.
  20. Aug 22, 2024 at 4:08 PM
    FrenchToasty
    Mo
    Bone stock
    Yeah I’m not sure about the different years variances.
    I’ll usually call and get part numbers, then look it up on their online parts store, it will usually be cheaper and free shipping to the store for pickup
  21. Aug 22, 2024 at 4:15 PM
    FrenchToasty
    Mo
    Bone stock
    So is it completely dead?
    I have my old one if you need to get by for a while?
  22. Aug 22, 2024 at 4:19 PM
    robabeatle
    AZ
    Nope not dead. I am getting serious whine in the stereo. It is not a ground loop issue as is typical with picking up alternator noise in the stereo.
    It is charging the battery for the moment, though I can tell it is not operating at full capacity. I ran a quick test with the alternator in place, pulled the neg battery lead, ran a DMM across the pos. battery lead to the alternator and am getting about 370 mV, spec seems to be above 500 mV. It has been getting worse over the last month or so.
    Thanks for the offer.
  23. Aug 22, 2024 at 4:19 PM
    FrenchToasty
    Mo
    Bone stock
  24. Aug 22, 2024 at 4:21 PM
    robabeatle
    AZ
    This thread seems to tell me I am mistaken and that I must have a 100 A: OKay, just ran my vin again and I was wrong.I do not see the 130 A so that makes this cheaper.
  25. Aug 22, 2024 at 5:43 PM
    Yeah, you'd need to repin. I believe Denso is sending all extra inventory to Toyota, and everyone else be damned.
    Toyota has the 130A: https://autoparts.toyota.com/products/product/reman-alternator-270600f06084
    If you have the square connector Frenchie is showing, you can do the 130A I just linked (aka Denso 210-1065), or you can do the Sequoia 150A (aka Denso 210-1066). But both are backordered at the moment.
    Per the Toyota parts diagrams, up through August of 2002, trucks came with the option of 70A or 100A. If your door tag has you manufacture date prior to August, you're one or the other. The 100A part is OEM @ 27060-0F020 or Denso @ 210-0403.
    Sadly, you're stuck man. Denso seems to be outo f stock on every part number I just listed.
    FYI, repinning to use the newer style connector is inexpensive and easy. And now I'm kinda wishing I hadn't sold off all my spare alternators :rofl:
    des2mtn and FrenchToasty like this.
  26. Aug 22, 2024 at 5:50 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  27. Aug 22, 2024 at 7:06 PM
    robabeatle
    AZ
    Looking like I will go to the local stealer tomorrow...
  28. Aug 22, 2024 at 8:03 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Making me wish I would have bought a denso 130a last year when I thought about it
    robabeatle[OP] likes this.
  29. Aug 23, 2024 at 5:44 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Part #27060-0F040-84 is much cheaper for some reason but does require a $75 core exchange. Not sure what the difference is there.
  30. Aug 23, 2024 at 6:44 AM
    MT-Tundra
    Montana
    Crap now this thread is making me want to buy a 100amp just to have on hand for the eventual end of my original. Or look into the 130 or 150 upgrade. Alternator on my Tacoma lasted 300,000 miles and 23 years. But I expect 300,000 miles is almost ten years down the road for me with the Tundra. All the more to reason to wonder if they'll still be available at that point.
