Which can be easier to fit? 295/70 vs 285/75
Discussion in 'Wheels & Tires' started by Stig, Apr 19, 2020.
  1. Apr 19, 2020 at 4:54 PM
    Stig
    Stig [OP] New Member
    295/70/18 versus 285/75/18 on +25 offset
    Is one of these sizes generally easier to take care of any rubbing issues than the other? Common sense tells me the shorter tire should be easier but I figure rubbing issues arise mainly when turning full lock where the width also comes into play.
    I'm running 6112 at 1.9 with two shims driver and one passenger and the new tires will be on a +25 offset. Cooper AT3 XLT so not too aggressive
  2. Apr 20, 2020 at 6:41 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    @Stig I am running 295/70/18 on a +25 offset on a 3/1 lift. I have a very slight rub on the front finder liner.
    Stig[OP] likes this.
  3. Apr 21, 2020 at 1:16 AM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    Do your tires make contact with the UCA?
  4. Apr 21, 2020 at 10:01 AM
    TwistedTad
    Tad
    Canyon Lake, CA
    @Henry2019 I have about 1.5 inches of clearance from my SPC UCA’s.
    Henry2019 likes this.
  5. Apr 21, 2020 at 11:26 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Looks like more choices in 295/70....and they seem to run cheaper than the 285/75s
  6. Apr 21, 2020 at 6:06 PM
    VENUSDOOM
    VENUSDOOM New Member
    2020 Tundra SR5 SX
    I just installed my 3"/2" ReadyLift kit on my 2020. I am keeping my stock wheels but I'm not sure what I can fit. My tire guy said only 270/70R18s but I could have swore people are getting a little bigger tire with these. What do you think?
  7. Apr 21, 2020 at 6:21 PM
    808Guy
    808Guy New Member
    Midwest
    2020 White Tundra SR5 CrewMax
    3" ReadyLift
    I'm running 285/75/18 on TRD Pro wheels (60mm offset) with 1 1/4 Spidertrax spacers and a 3/1 ReadyLift. It slightly rubs on the frame when turning sharp left in reverse. By the way, anybody got any ideas on how to fix the rubbing?
  8. Apr 21, 2020 at 6:39 PM
    robbb38
    robbb38 New Member
    Rob
    18 limited crewmax
    I have the BDS 3/1 lift and im running 295/70 on 25mm offset with zero rubbing. Tires are cooper st maxx
  9. Apr 23, 2020 at 5:49 AM
    Stig
    Still up in the air which of these sizes to go with.
    Both are within 1 lb of each other. Can get either for the same price.
    98% pavement. Rest is fire roads that get nasty sometimes but in those cases I won't be on them anyways.
    I'm sitting at 39 inches ground to fender on the OEM 18s with worn out 275 65
  10. Apr 25, 2020 at 2:11 PM
    Stig
    Decided between the two in my OP. Going with neither. 275/70 for now. 4.88 and supercharger by the time those need to be replaced. I drive to fast in the rolling hills highways to put up with making my truck even slower.
  11. Apr 25, 2020 at 3:14 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    There are a couple of newer tires out there in that size that are super light compared to previous 275/70r18 models. The new Toyo AT3s are around 50 lbs. There is also a new Firestone Destination XT which is light and looks badass but no guys on here have tried it yet.
  12. Apr 25, 2020 at 3:27 PM
    Stig
    Yep! ATIII it is
  13. Apr 25, 2020 at 3:42 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    I was gonna get the ATIII, but I think i decided on the new Bridgestone Revo 3, 295/70 is only 54lbs. I had revo's before and they ride smooth and balance easily.
    Hbjeff likes this.
  14. Apr 25, 2020 at 4:02 PM
    MICKs18yota
    MICKs18yota New Member
    Ohio
    2018 Tundra SR
    I was going to mention 285/70/18s I’m running them with 6112s set at 1.9 no trouble here I probably could have gone 285/75s but would have more rub on the front of the liner and definitely would have had to do bumper shims next time around if I don’t go with 37s I’ll do the 285/75s though. Good luck with whatever you go with.
  15. Apr 25, 2020 at 4:24 PM
    Stig
    My main concern going too large on the diameter, besides just weight increase, is causing the tranny to hear hunt or not have power on the highways here. They are constantly rolling hills and traffic usually does 80, my stock Tundra already has to go to fifth more than I'd like.
    I'll go to 34/35 when this next set wears out when I can also add gears and a supercharger.
