Which caps fit..or close to it
Discussion in '1st Gen Tundras (2000-2006)' started by itscoreyc, Jul 11, 2020.
  1. Jul 11, 2020 at 12:14 PM
    itscoreyc
    itscoreyc [OP] New Member
    Corey
    QC
    2001 Tundra V8 4WD sr5
    3" lift 33" x 10.5" ko2s
    hey i bought a 01 tundra access cab.
    i am looking for a used cap..not spending that kinda of money on a truck that cost as much as a new cap.
    So the question is which caps from which trucks fit or come close..
    as long as i can attach it ill be happy.
    thanks
  2. Jul 11, 2020 at 12:52 PM
    ezdog
    ezdog New Member
    Gateway To The West
    The 1st gen Tundras were really pretty much in a size range of their own.
    I imagine that you will need to find a top made for one to get a decent fit honestly.
    That said if you take measurements and shop around you might find something else?
    itscoreyc[OP] likes this.
  3. Jul 11, 2020 at 12:59 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    1st gen Tundra and T100s are the only models that will fit well.
  4. Jul 11, 2020 at 1:04 PM
    itscoreyc
    Corey
    QC
    as mentioned in my post im not looking for a perfect fit.. i dont care if the angle is off or i have 3/4 inch of space between it.
  5. Jul 12, 2020 at 7:09 AM
    I hear the DC caps fit the AC also. Fit, not perfect, but fit. Maybe someone else can chime in. Also the F150 caps of similar years are likely to be very close as well. This is essentially the Japanese F150 clone. Some measurements and a trip to a place that sells caps would probably help shake out which will be close. Good luck hunting and let us know what you come up with. Been looking for a cap as well.
  6. Jul 12, 2020 at 10:53 AM
    itscoreyc
    Corey
    QC
    thanks man, ill look into older f150 ones now for sure..never actually realized that there almost identical and i owned 2 of them before..
  7. Jul 12, 2020 at 11:42 AM
    ezdog
    ezdog New Member
    Gateway To The West
    I have an 01 and a 15 both regular cab longbeds.
    I thought about sticking the top from the 01 onto the 15 as they both can carry a 4x8 sheet in them so I figured they might be pretty similar as might any or every other regular cab 8' bed truck?
    Turns out that might have actually worked except that the shell has french doors on the back and the bed depth difference is almost a foot between the 2 trucks!
    So you might well be able to fit another trucks shell onto your truck but you will need to shop armed with the measurements of the bed that you already have and try to get close to that.
    Good luck getting anyone selling to help by providing reliable measurements too!
    So I don't think it will be too difficult but it will require some work too.
  8. Jul 12, 2020 at 12:03 PM
    itscoreyc
    Corey
    QC
    ya haha that bed depth was the first thing i noticed before buying it.. i have a few other non toyota trucks and have never seen that before...
    they could have made it 6and a half feet like everyone else lol
  9. Jul 12, 2020 at 12:05 PM
    itscoreyc
    Corey
    QC
    looked online dont think the f150 box would fit at its like 3-4 inches longer...
  10. Jul 12, 2020 at 12:08 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I mean the depth from the rails to the bed more like 17" on yours but 25 on the 3rd gen trucks.
    Only an issue for the french doors in back for me.
    6 1/2 is what I would consider the Length not the Depth.
  11. Jul 12, 2020 at 12:21 PM
    itscoreyc
    Corey
    QC
    i know what you meant, my response just came out wonky.. i noticed it was more shallow compared to my f150 and sierra. what i was refering to was the odd box dimensions compared to other pickups..there is nothing remotely close to the dimensions of my tundra. everything is within 3inches to long or short and between 3 and 6 inches to short or wide on the width.
  12. Jul 12, 2020 at 12:24 PM
    itscoreyc
    Corey
    QC
    also the 1st gen tundra is not 6 1/2 box it 6'2" box
    another manufactures make 6 1/2 foot box which actually is 78"
  13. Jul 12, 2020 at 12:25 PM
    ezdog
    ezdog New Member
    Gateway To The West
    That is my experience too which is why I keep suggesting you keep the measurements handy and measure everything you can!
    There are also used ones out there that if you try hard enough can be turned up for sure.
  14. Jul 12, 2020 at 12:30 PM
    itscoreyc
    Corey
    QC
    ya it seems like comparing charts online is not going to help.. going to have to go actually try some on and see how they fit.
  15. Jul 12, 2020 at 8:19 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    t100 and 1st gen are the only ones that'll fit where they wont leak.. anything else might "fit" but not quite right. Theyre out there, check craigslist, facebook marketplace, junkyards...
    my cap was less than 200 bucks from a junkyard. theyre out there
  16. Jul 14, 2020 at 8:25 AM
    Online searching is not very helpful it seems. But the general idea is that every other full size truck that's close is gonna be 2-3" wider and or longer. Actually having one to try may reveal that the way it sits is doable since there's some play with the width of the bedrails and doesn't look to bad, or its all gaps and overhangs. The search continues...
  17. Jul 15, 2020 at 3:22 PM
    itscoreyc
    Corey
    QC
    • Found myself one off a t100 today. Super happy. Just need to paint it now. Fits great.
    • Thanks for the help guys
