Which crank pulley holder for removing crank bolt?
Discussion in '1st Gen Tundras (2000-2006)' started by atikovi, Aug 31, 2021.
  1. Aug 31, 2021 at 5:05 PM
    atikovi
    atikovi [OP] New Member
    Suburban Washington DC
    I see two types,
    or
    Is one any better than the other?
  2. Sep 1, 2021 at 7:15 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Depends on whether you can get your socket in the center hole...I know the top one works, not so sure about the bottom
  3. Sep 1, 2021 at 7:20 AM
    w666
    Maryland
    FYI, as I recall the threaded holes in the harmonic balancer are thoroughly rusted, and need to be chased with a tap before the bolts will thread in. Also, the bolts supplied with my tool were too long, and came out the back of the pulley and into the cheesy plastic cover behind. I wound up using shorter bolts from a puller kit I have.
    No, I don't recall the thread pitch (but I may have already posted this ~ 1 1/2 yrs ago when I did mine).
  4. Sep 1, 2021 at 7:50 AM
    atikovi
    Ended up ordering the latter one for $29. Will see how it works.
  5. Sep 1, 2021 at 7:53 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    If heather were here, she’d recommend the big mamba impact, zip zip
    DaWhiteTundra, KNABORES and bmf4069 like this.
  6. Sep 1, 2021 at 11:47 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I got you.
  7. Sep 1, 2021 at 12:49 PM
    If Mando were here he would agree. Big HD Impact gun. This is the way.
    DaWhiteTundra likes this.
  8. Sep 1, 2021 at 1:09 PM
    atikovi
    From just a quick glance, there isn't room for an impact unless you remove the radiator.
  9. Sep 1, 2021 at 2:11 PM
    FrenchToasty
    Mo
    Bone stock
    That’s the safest option even when not using a impact, you’ll thank me later
    w666, bmf4069 and BubbaW like this.
  10. Sep 1, 2021 at 2:12 PM
    I definitely removed the radiator. Are you ding the timing belt job?
    BubbaW likes this.
  11. Sep 1, 2021 at 2:14 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    ^^^ agree with @FrenchToasty
    It should not be a rush job and it gives one a chance to even inspect/clean the coils of radiator better !
  12. Sep 1, 2021 at 2:14 PM
    atikovi
    Yes the timing belt.
  13. Sep 1, 2021 at 2:15 PM
    I used the opportunity to replace my radiator and put fresh coolant in. A good plan for a 90k interval anyway.
  14. Sep 1, 2021 at 2:19 PM
    atikovi
    Since when is the radiator a service item?
  15. Sep 1, 2021 at 2:42 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    is "service item" synonomus with Maintenance item ?
    If so, the maintenance schedule is to check the radiator core and condenser every 30K !
    N84434 likes this.
  16. Sep 1, 2021 at 2:49 PM
    atikovi
    Check for leaks or debris. You don't have to remove it for that if you have a blow gun.
  17. Sep 1, 2021 at 3:03 PM
    FrenchToasty
    Mo
    Bone stock
    Don’t remove it and let us know how it goes.
    FirstGenVol, Lil Steve and BubbaW like this.
  18. Sep 1, 2021 at 7:27 PM
    Since they started making them out of plastic and they started cracking and leaking with age. Mine made it 170k miles. That's not quite 2 timing belts depending on time elapsed. Radiators are $85-150. Cheap enough for me to do it while I'm in there every timing belt change instead of on the side of the road in some random town on a road trip. I wouldn't have attempted the timing belt with the radiator in. What a pain in the back that would be.
    N84434 and FrenchToasty like this.
  19. Sep 1, 2021 at 7:29 PM
    FrenchToasty
    Mo
    Bone stock
    I’m not even old, and I wouldn’t want to hunch over the rad the entire time trying to get to all the components.
    N84434 likes this.
  20. Sep 1, 2021 at 9:15 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I'm at 180k or so and planning to do mine sometime soon. Don't want to worry about cracking and definitely don't want to worry about pink milkshake from trans fluid and coolant mix.
  21. Sep 2, 2021 at 4:21 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    There's Proactive maintenance, and then there's Reactive maintenance....
    .02
  22. Sep 2, 2021 at 4:32 AM
    atikovi
    So where do you stop? Why not replace the alternator or power steering pump while you're in there.
  23. Sep 2, 2021 at 4:35 AM
    NickB_01TRD
    Nick
    KY
    I think some people do the alternator while they're in there honestly.
    I guess it just depends what your budget is and how much stuff you don't want to have to worry about later.
  24. Sep 2, 2021 at 6:18 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Since the consequences of a transmission cooler failure results in catastrophic failure of the transmission. There have been many reports of pink milkshakes among Gen-1 Tundras lately. Check this thread:
    https://www.tundras.com/threads/engine-oil-cooler-rubber-lines.93063/#post-2350589
    My previous vehicle was an '02 4Runner and the consensus of owners on T4R.com (based on 1st hand experience) was to replace the radiator every 10 years. Mine had a pink milkshake at about 15 years. The radiator and trans cooler design on the 4Runner is the same as on our Tundras.
    I believe as more of these trucks approach the 20 year mark we're going to see more and more of these incidents. It's a little over $100 for a new radiator. You're already draining it for a timing belt service. At that point, it's about a 20 minute job.
    In this thread, I posted pics of the failed trans cooler removed from the radiator. It shows where it fails and why it fails.
    https://www.tundras.com/threads/rough-transmission-shifting.93323/#post-2355468 (BTW, this that was started as a result of a pink milkshake.)
    I replaced the radiator as a maintenance item on my Tundra a couple months ago. I haven't dissected it yet, but when I do I'll post a pic of the trans cooler.
    BTW, this is not exclusive to Toyotas. This is a Denso radiator problem. Honda uses Denso radiators in at least some of their vehicles (Ridgeline and Odyssey for instance) and the same transmission cooler failures are reported with those vehicles.
    bmf4069 likes this.
  25. Sep 2, 2021 at 6:22 AM
    atikovi
    Wouldn't installing a separate transmission cooler be even better?
  26. Sep 2, 2021 at 7:02 AM
    Mine has both. And some have chosen to separate the transmission cooling from the radiator to avoid the disaster scenario. And as to your previous comment, you stop with things that have no history of failure on a timeline, and things that wouldn't leave you stranded if they do.
    DaWhiteTundra and N84434 like this.
  27. Sep 2, 2021 at 7:15 AM
    sixteen2nd
    sixteen2nd Shadetree Mechanic
    2003 White Tundra Access Cab TRD
    Pink milkshake = engine replacement
    So...
    Rediator replacement = preventative maintainence
    DaWhiteTundra and KNABORES like this.
  28. Sep 2, 2021 at 7:52 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I don't see a difference between the two. It isn't like they get the same job done differently, they do the same job the same way.
  29. Sep 2, 2021 at 8:08 AM
    The difference between which two?
  30. Sep 2, 2021 at 8:15 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    I believe he's referring to the internal VS. external Trans cooler.
    @Baller The difference is that the external can fail without effecting the engine, while the internal cooler (inside the Radiator) can have an effect on the engine antifreeze/coolant if it fails. And the other way around. If the engine side fails and you get coolant into the transmission, that would have detrimental effects on the Transmission.
    Makes sense?
