Which gas tank..?
Discussion in '3rd Gen Tundras (2022+)' started by Qcguy4198, Feb 3, 2024.
  1. Feb 3, 2024 at 12:51 PM
    Qcguy4198
    Qcguy4198 [OP] New Member
    Don
    2022 XP series
    None
    How do I find out which gas tank ( size) I have..?
  2. Feb 3, 2024 at 1:01 PM
    danlikescats
    danlikescats New Member
    Houston, Texas
    2023 Black Tundra Limited 4x4
    Fill it up and see how much it takes? I don’t have it on the PDF or the window sticker for mine. I know it’s the 32 gallon though because I’ve filled up about 24 gallons when I run it to 0-50 miles or less until empty. If you have the smaller tank, it’ll take less than that to max out because of the large and heavily debated reserve. I think certain trims also come standard with the larger tank. I’ve got a limited ‘23.
  3. Feb 3, 2024 at 1:45 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    Might help to know what model you are driving. Could be a Yaris based on your vehicle description.
    Emdoc1 likes this.
  4. Feb 3, 2024 at 1:49 PM
    Hella Krusty
    Hella Krusty New Member
    If it takes more than 22 gallons, you have the 32 gallon tank
    303Gen3 and Mattedfred like this.
  5. Feb 3, 2024 at 2:28 PM
    Qcguy4198
    Don
    2022 XP series
    None
    Thank you all for your responses. I was hoping that there’s a place in the owner’s manual that simply uses the VIN and specifies what tank is in the truck.
    I recently purchased a 2022 Tundra, double cab, V6 twin turbo, “ X-series”,
    XP I believe, if I’m reading it correctly.
  6. Feb 3, 2024 at 3:01 PM
    DRP
    DRP Old Member
    Dave
    Just poke your head under the truck and look up. If it's one of the longest tanks you've ever seen, it's 32 gallons.:thumbsup:
  7. Feb 3, 2024 at 4:37 PM
    303Gen3
    Golden Colorado
    It should have decals-premium, Limited, SR5 and maybe bed-decal like TRD? But just wait until the gas light comes on and fill it up..low light usually comes on with 3 gallons left for 22.5 gallon tank - so 18 +/- to fill for small tank.. GL. Just don't run it out of gas and burn up the fuel pump!
  8. Feb 3, 2024 at 4:56 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    I believe SX model is a special package SR5, so you could have either. SR5 is the only model that could have either tank. I also believe there has to be a place where you can pop the VIN and get your specs.
  9. Feb 3, 2024 at 5:00 PM
    303Gen3
    Golden Colorado
    Maybe @ryanwgregg can help you identify if you have standard or larger capacity? DM him hopefully your VIN will let him identify.
    pwpblue likes this.
  10. Feb 3, 2024 at 5:17 PM
    Go to Google. Search "Toyota features by VIN" and the first non ad should be to Toyota. Type your vin and read the packages it has. Then search what is in the packages for that model year.
    Qcguy4198[OP] and Mattedfred like this.
  11. Feb 3, 2024 at 7:08 PM
    nafterclifen
    nafterclifen New Member
    Pocono's, PA
    Mattedfred likes this.
  12. Feb 3, 2024 at 9:24 PM
    Hella Krusty
    Its huge lol
  13. Feb 8, 2024 at 9:38 AM
    Qcguy4198
    Don
    2022 XP series
    None
    By VIN number, 32.2 gal tank. Thanks for the help folks.
    22whatwedo and Mattedfred like this.
