Which Roof rack for paddle boards
Discussion in 'Tonneau Covers, Caps and Shells' started by Xplorin, Feb 28, 2019.
  1. Feb 28, 2019 at 4:46 AM
    Xplorin
    Xplorin [OP] New Member
    Yorktown, Virginia
    2019 cement crewmax
    looking for some advice
    I’m in the market for 2 stand up paddle boards, which also means I need to figure out how to haul them.
    10-12ft in length
    I like the idea of a roof rack because I like the way it would look on the truck.
    And have a trifold tonneau which really
    Limits the bed rack options without spending a lot of money
    I do not want to drill holes or permanently mount the rack so I’m heavily leaning to either the Thule or Yakima rack that clamps onto the truck
    My question is for those who have experience with these setups which one works better on a crewmax to haul a 12 ft board?
    Or is that even enough room on the roof for them?
    Thanks!
  2. Feb 28, 2019 at 6:35 AM
    Cemented
    Cemented Function over Form
    Manuel
    2017 Cement TRD Pro
    Can’t help much with cab rack experience as I have mine on my shell, but once you figure out the rack itself I recommend checking out the Yakima SUPDawg to hold the boards. Lockable and can hold two boards. It also has a strap to use from the front of the board(s) to your front bumper area to help hold it down. I would think length is fine as long as you position properly and secure it, I’ve hauled 12’ sups on smaller vehicles no problem.
    InfernoPRO and Stormtrooper81 like this.
  3. Feb 28, 2019 at 6:55 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
  4. Feb 28, 2019 at 1:57 PM
    Xplorin
    Yorktown, Virginia
    2019 cement crewmax
  5. Feb 28, 2019 at 2:32 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    No, I’ve only used Thule and Yakima. The etrailer reviews look great, and one pickup owner said they’re better than the aforementioned. I’ve been looking at no drill cross bars for the roof, not sure we need them yet.
  6. Feb 28, 2019 at 2:41 PM
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    What @Cemented was trying to say is get the Prinsu* cab rac and never look back!
    *some drilling required.
    Cemented and smslavin like this.
  7. Feb 28, 2019 at 3:12 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    no need to spend the money for a specifc board holder unless you really want to. grab some board rack pads with a couple of tie downs and you'll be fine. just remember. fins forward. fins. forward.
    porkitt likes this.
  8. Mar 3, 2019 at 7:39 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    ROLA Rack
  9. Mar 3, 2019 at 7:47 AM
    Xplorin
    Yorktown, Virginia
    2019 cement crewmax
    Does that use the bed rail track system?
  10. Mar 4, 2019 at 8:04 PM
    r1-superstar
    DB
    UTAH
    Yes it does.
  11. Mar 5, 2019 at 2:00 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    Don’t think so. It’s a 12’ SUP only being supported by 5 feet or less, no bueno for the board.
    I would suggest doing low over the bed roof rack system with a hitch mounted secondary support that elbows out, and up to carry a little weight from the nose.
    I carry windsurf boards and many of my friends haul SUPs, we would never support a board by half it’s length. Very expensive risk to take.
  12. Mar 5, 2019 at 8:17 AM
    r1-superstar
    DB
    UTAH
    That's funny... Both my SUPs are 11' 6" and I have zero issues. I also hauled them around on my 03' Sequoia with factory roof racks with no problems. Almost every single Tacoma on Maui uses them to haul their big boards with no problems.
  13. Mar 5, 2019 at 8:29 AM
    Tundrius
    Tundrius New Member
    Jonah
    08 tundra, matching 10 prius!
    I have rhino on my hard cover and I love them. I have never carried paddle boards. We prefer the blow up units instead of the solid units, Kayaks as well.
  14. Mar 5, 2019 at 8:49 AM
    r1-superstar
    DB
    UTAH
    Just re-read your post again. The ROLA Rack won't work with the tonneau cover. I know mine won't that's why I'm selling my racks.
  15. Mar 5, 2019 at 9:24 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Or you can do what I do. When I can't find what I want, I build it. Had a rack over my big cap on my 88 GMC. I built is so it was clamped on and went into the holes with the cap. When in doubt
    TXRailRoadBandit73 likes this.
  16. Mar 5, 2019 at 10:40 AM
    Jettech
    Jettech New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    TRD Exhaust, DC 305/55/20s, TRD PRO Shocks, HID's, JOBOX, Bully Dog Tuner, TRD sway bar, Shorty FM Int,
    Rhino racks are solid for sure. I could stand on mine without it flexing much at all. But I have not put the SUP on it yet.
  17. Mar 5, 2019 at 10:46 AM
    Nice welder, my Dad passed a few yrs ago, I gained all his tools, I have a Hobart Handler 120 wire welder, and a Lincoln cracker box stick welder I need 220 wired up in garage to use to to practice welding skills
  18. Mar 5, 2019 at 12:06 PM
    Racingjohndeere55
    I'm very blessed to have all the tools I have, and the knowledge to use them. Thank you dad!
  19. Mar 5, 2019 at 2:42 PM
    B737
    Jersey Shore
    It’s ur gear treat it how you want. Any rack will do, I’m just saying don’t cantilever half or less of the board with no support under under the remaining 50%+. It’s not good for the board. It's not rocket science to see how you are structurally loading the board in a way its not supposed to be carried.
  20. Mar 5, 2019 at 2:48 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    That’s a big bush on the roof!
  21. Mar 5, 2019 at 3:03 PM
    Xplorin
    Yorktown, Virginia
    2019 cement crewmax
    What hard cover do you have that lets you use rhino?
  22. Mar 5, 2019 at 3:29 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I'm looking to get two stand up paddle boards as well. Only difference is i want to store them in a smaller location so i am going with the inflatable ones.
  23. Mar 5, 2019 at 3:50 PM
    Xplorin
    Yorktown, Virginia
    2019 cement crewmax
    Also debating on getting a set of inflatable ones but live just a couple miles from the water so I’d leave them inflated most of the time unless traveling a little farther out
    csuviper[QUOTED] likes this.
  24. Mar 7, 2019 at 6:05 AM
    r1-superstar
    DB
    UTAH
    Okay :thumbsup:
    Racingjohndeere55 likes this.
  25. Mar 7, 2019 at 6:16 AM
    B737
    Jersey Shore
    i mean if we're talking about disposable gear like "inflatable" and sub $1000 SUPs have at it. But If you are serious about your sport, I would not carry around $2000-$3000+ board half assed. Even my short boards i wouldnt cantilever like that. My long board is around 9', it's supported at the fin box, and 2/3rd out off the nose. The other problem with over the roof, is loading it during any kind of wind, and driving highway speeds. With a 12' board, if you're going to use tall bed rack, supplementing support with roof rack would be sufficient, but it would look like scaffolding on your truck :eek:
    It takes me 5 minutes to load my gear. Keeping it at a manageable height means it can be blowing like hell and still in total control of your equipment. Plus, it's not a leading edge while on the highway.
