Which tires to put snow chains on?
Discussion in 'Wheels & Tires' started by big_jarv, Jan 23, 2020.
  1. Jan 23, 2020 at 1:31 PM
    big_jarv
    big_jarv [OP] New Member
    2021 TRD Pro
    Hello,
    I’ll be heading up to the mountains soon and while I don’t expect needing to use my chains, which tires would they go on?
    My truck is 4x4, and I’ve seen people say front or back and haven’t been able to get a solid answer.
  2. Jan 23, 2020 at 1:33 PM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    If you're going to be using them with it in 4WD; put the chains on the front so you can get some steering traction.
    big_jarv[OP] likes this.
  3. Jan 23, 2020 at 1:35 PM
    Owners manual will give you the correct information and not a bunch of miss information.
    AZTundra, shellshock and 15whtrd like this.
  4. Jan 23, 2020 at 1:35 PM
    Aerindel
    Aerindel New Member
    Montana
    Well, nobody agrees on anything other than 'both' is best.
    Myself, I've been running chains on different vehicles my whole life, and I always run them up front. It lets you pull the front end up, over, or around problems while the rear end just shoves you forward into them (and on a truck has a fraction of the traction of the front tires anyway.)
    The exception would be if you are towing or otherwise heavily loaded in the rear.
    The owners manual doesn't care if you get stuck. They are just going to give you the answer the least likely to result in anyone suing toyota.
    big_jarv[QUOTED][OP] likes this.
  5. Jan 23, 2020 at 1:36 PM
    15whtrd
    15whtrd Mr. Blonde
    I would put them on the back. I don’t think there’s enough room in the front between the upper a arm and the tire. Too close for comfort. I actually think there may be something in the manual talking about it.
  6. Jan 23, 2020 at 1:38 PM
    big_jarv
    2021 TRD Pro
    I really did try this option, but didn’t see anything on it.
  7. Jan 23, 2020 at 1:39 PM
    15whtrd
    15whtrd Mr. Blonde
    Also I’d like to point out that I have just a slightly larger than stock tire. At full lock turning the wheel, my tires get pretty close to everything, front and rear mudflap as well as body mount. Chains in front would be a bad idea on my truck.
  8. Jan 23, 2020 at 1:39 PM
    big_jarv
    2021 TRD Pro
    Thanks guys!
    15whtrd likes this.
  9. Jan 23, 2020 at 1:47 PM
    Check under winter driving tips (page 260-265 I think).
    Ely010606 and 15whtrd like this.
  10. Jan 23, 2020 at 1:57 PM
    big_jarv
    2021 TRD Pro
    Thanks!
    Page 247 for me. Previously I had only been able to find info if your vehicle was stuck.
    Manual says rear wheels, but also didn’t specify for 4X2 vs 4X4.
  11. Jan 23, 2020 at 2:54 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    I installed the chains in the rear. I felt more comfortable in rear due to sharp turns in the mountains and was afraid of chains getting caught up with front suspension/ brakes etc...didnt want them to come loose as I turned my wheels..
  12. Jan 23, 2020 at 3:15 PM
    395 Runner
    395 Runner New Member
    2018 Tundra Platinum MGM 4x4 Crewmax
    Here in CA if cal trans goes to R3 (4x4s must put on chains) they’d likely close the roads anyway. I do carry them with me to the mountains because technically I’m supposed to have them just in case per chain control regs.
    Ive only had to use them once many years ago because CHP required them at a checkpoint. I put them on the rear of my 4x4 Tacoma. It was complete overkill and not necessary at all, but what do I know.
    Unless you’re planning to be anywhere off a local road/highway, I’d look at getting some cables. Lower profile, easier to install and meets the requirement of having them if needed (at least here in CA). I have Z6s for my truck and the wife’s suv.
  13. Jan 23, 2020 at 4:05 PM
    The Californian
    Eric
    When I bought my truck, I actually had to sign a waiver saying I was aware that I should only use cables, and never use chains due to the TRD Pro Wheels.
  14. Jan 23, 2020 at 4:15 PM
    395 Runner
    Yup. Had to do that for my wife’s suv. That form said no chains or cables at all. It’s awd, so I likely will never need to put them on.
    I bought my tundra used, so I don’t recall having to sign anything re chains.
    Although my favorite is the authorized chain installers that sit on the side of the highway in the Sierras and put on chains all day at $60-$80 for 15 minutes of work. Good gig if you don’t mind the weather.
  15. Jan 25, 2020 at 2:00 PM
    big_jarv
    2021 TRD Pro
    We made it! No chains required! Lol
    tbutler, rodm1 and saybng like this.
  16. Jan 25, 2020 at 6:33 PM
    saybng
    Gary
    Ventura CA
    Where did you end up going?..nice pic!
  17. Jan 25, 2020 at 8:19 PM
    big_jarv
    2021 TRD Pro
    Thanks, rock tub hot springs.
    saybng[QUOTED] likes this.
  18. Jan 25, 2020 at 9:41 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I’m not doubting that this happened, but if it was a purchase and not a lease, why on earth do they care what you do with your truck once they get their money?
  19. Jan 26, 2020 at 4:28 PM
    The Californian
    Eric
    They’ve had people come back and complain that they were never told that chains would damage the TRD Pro wheels, this way they have proof otherwise.
  20. Jan 26, 2020 at 4:56 PM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    I bought a set to fit my 295s when I was passing the base of the road up to Big Bear (330). Saved me $75 shipping. I used them on the rear once so far. The last 5 miles of road to my place are dirt and there are steep hills. I had to put them on after a big snow made the roads all muddy and slippery as snot. I know there is not enough clearance up front.
