Which Toyo AT3 on Gen3? 35x11.50 or 35x12.50
Discussion in 'Wheels & Tires' started by akira, Dec 11, 2024.
Toyo AT3 35x11.50 or 35x12.50
  1. 35x11.50x17
    45.5%
  2. 35x12.50x17
    54.5%
  1. Dec 11, 2024 at 11:29 AM
    akira
    akira [OP] 25 Tundra Limited TRD OffRoad
    San Diego
    Going with Toyo AT3 in load range C. I live in San Diego and want a tire with good all around characteristics. Will spend a lot of time in the Sierra's during winter and snow performance is important. Thinking the narrower 35x11.50x17 tire may be better than the 35x12.50x17. Tire will be mounted on a 316 17"x8" wheel.
    Thoughts on the 2 options below?
  2. Jan 30, 2025 at 4:38 AM
    bnib
    bnib New Member
    Brent
    2025 Lunar Rock Tundra Platinum
    Which option did you end up going with? I’m debating these exact tire options now for my 2025 on a 17”x8.5” wheel.
  3. Jan 30, 2025 at 4:53 AM
    akira
    San Diego
    35x12.50x17. It was lighter weight and fit is perfect on a 17” wheel.
  4. Jan 30, 2025 at 5:01 AM
    bnib
    bnib New Member
    Brent
    Looks awesome! I’m leaning the same way due to the lighter weight. The Max PSI of 35 was throwing me off though. What’s your wheel offset and how much poke do you have?
  5. Jan 30, 2025 at 5:12 AM
    akira
    San Diego
    Method 316 17x8 +25. Tires sit just outside the fender and I’m running factory mid flaps front / rear.
  6. Jan 30, 2025 at 8:01 AM
    bnib
    bnib New Member
    Brent
    Wow! That's a perfect stance IMO. So, no rubbing/fitment issues then?
    akira[QUOTED][OP] likes this.
  7. Jan 30, 2025 at 8:07 AM
    akira
    San Diego
    No rub no issues. Would 100% recommend this tire.
    bnib[QUOTED] likes this.
  8. Jan 30, 2025 at 8:11 AM
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    Looks great! I was in the same situation and ordered 11.50. However, it never came (2 weeks). Asked a second shop to order it for me. They said 12.50 would be easier to order if i needed a replacement. So I ended up going with 12.50 also.
    bnib likes this.
  9. Feb 20, 2025 at 4:45 PM
    Reef2018
    Reef2018 New Member
    Colton
    24 TRD Offroad 4x4 Limited
    If I’m running 35x12.50x17 BFG K02’s and put them on Method 316s in theory the poke would be the same right? currently have rrw 17s and the offset is 0. Too much poke for my liking
  10. Feb 20, 2025 at 4:56 PM
    akira
    San Diego
    Yes, as long as you get the offset of the Method 316s in +25. You want the 17x8 6x5.5 +25 wheels.
  11. Feb 20, 2025 at 4:58 PM
    Reef2018
    Reef2018 New Member
    Colton
    Thank you so much. Do you have any pictures from the back?
    I also have a 3in lift but I wouldn’t think that would affect poke.
  12. Feb 20, 2025 at 5:02 PM
    akira
    San Diego
    They just barely sit past the factory fenders. I am still running front and rear mudflaps and nothing kicks up on the body from the tires.
    Reef2018[QUOTED] likes this.
  13. Feb 20, 2025 at 5:06 PM
    Reef2018
    Reef2018 New Member
    Colton
    Appreciate the information & pictures!
  14. Mar 1, 2025 at 9:57 AM
    elukianic
    elukianic New Member
    Eugene
    Would 12.5 rub on +18 offset and 3 inch lift or should I be safe and get 11.5?
  15. Mar 1, 2025 at 10:00 AM
    akira
    San Diego
    +18 and a 12.5 should be ok. You might rub the front mud flap and need to remove, but the 3” lift could give you the clearance needed.
  16. Mar 1, 2025 at 10:01 AM
    elukianic
    Eugene
    My main concern is rubbing on uca and sway bar
  17. Mar 1, 2025 at 10:09 AM
    akira
    San Diego
    +18 wheel and 12.5 tire I would not expect any rub on upper control arm or sway bar. I run +25 wheel and 12.5 tire with plenty of room between tire and UCA/sway bar.
  18. Mar 1, 2025 at 10:10 AM
    elukianic
    Eugene
    Perfect thanks! How do you like Toyos so far? I’ve only had wildpeaks on taco before, but they are too heavy so I’m going with toyo on the tundra.
  19. Mar 1, 2025 at 12:11 PM
    akira
    San Diego
    So far so good. I would normally run BFG A/T’s, but was after a light 35x12.5x17 Load C tire and Toyo had the lightest offering. Balanced well and no issues.
    BFG is going to release a 37x12.5x17 Load C A/T KO3 in 2026. If Toyo doesn’t come out with a 37” Load C, I will probably go with the BFG as next tire.
  20. Mar 3, 2025 at 5:47 AM
    dragtek
    dragtek New Member
    2023 limited Trd OR
    Te37x in 17” -10mm offset, 35” toyos, wescott design preload
    I currently have 12.5 width, but may opt for 11.5 when these tires are up. Most of my driving is on pavement.
  21. Mar 3, 2025 at 6:50 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I like the 35x12.5x17s. I went with C load rating and they feel great. Im on a 2nd gen (2.5) Methods 0 offset. Im not sure how much advantage an 11.5 over a 12.5 is going to have in the snow. Specs show the C load is 59 lbs.
  22. Mar 3, 2025 at 7:05 AM
    elukianic
    Eugene
    I think the only reason for me id go with 12.5 is because they are lighter. I am picking up some today. Are they relatively quiet?
  23. Mar 3, 2025 at 8:02 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Yes. I was on smoked Toyo R/T Trails prior and new AT III’s are night and day.
  24. Mar 3, 2025 at 11:35 AM
    elukianic
    Eugene
    Just waiting on my wheels now and lift
    SnowToy, UTAHRTK and akira[OP] like this.
