Which UCA's to go with?
Discussion in 'Suspension' started by UTAHRTK, Mar 10, 2023.
  1. Mar 10, 2023 at 5:59 AM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I could use some help deciding on UCAs. Im at about 1.75" lift front and currently OEM UCA's. Spend most time as a daily driver but do a little trails around San Diego.
    The ball joint boots are busted... I am leaning towards ball joint but not opposed to uniball such as Total Chaos. I have been pondering Dirt King and someone recommended Icon Delta joint UCA's. What do you think? Thanks.
  2. Mar 10, 2023 at 6:11 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Dirt King and TC are overkill for a DD, imo. SPC is ideal. Even the lesser known brands would work.
    FrenchToasty likes this.
  3. Mar 10, 2023 at 6:11 AM
    2mchfun
    MCM fab, I think he has a delta joint option too.
    Tom likes this.
  4. Mar 10, 2023 at 6:12 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Saltyhero13 likes this.
  5. Mar 10, 2023 at 6:25 AM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    You're right by Dirt King. You could go talk to them. They have a good price on their ball joint UCA's too.
  6. Mar 10, 2023 at 7:09 AM
    Chasntuna
    Chasntuna New Member
    2015 DC TRD 2WD
    I just ordered JBAs yesterday, we'll see !
  7. Mar 10, 2023 at 8:14 AM
  8. Mar 10, 2023 at 8:10 PM
    UTAHRTK
    SOCAL
    Thanks everyone. That link is awesome.
  9. Mar 10, 2023 at 9:11 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Can confirm…. And he also sells the Delta Joints for folks (like me) that want to retrofit and lose the Uni-Balls. Nothing wrong with Uni’s but they hold water, goo, and grime. I live in Western Oregon, and that’s all we got. Short life for Uni’s compared to other areas.
    2mchfun[QUOTED] and Kwe1982 like this.
  10. Mar 12, 2023 at 9:36 AM
    kevine0001
    kevine0001 New Member
    Kevin
    Been looking at the Freedom Off-road. Just installed the 6112/5160 lift. Running stock UCA but the Freedom Off-road UCA looks comparable to other tubular UCAs. Only $350 for the pair
  11. Mar 12, 2023 at 10:22 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Here's plenty of info about them.
  12. Mar 12, 2023 at 10:44 AM
    UTAHRTK
    SOCAL
    Thanks for all the info- I learned some along the way. Probably going with Dirt King Fab ball-joint-upper-control-arms-dk-815901 ... Chatted with them... they are down the street and offer mil/vet discount... I see their builds around town all the time- badass!
    Sierradevil and texasrho83 like this.
  13. Mar 21, 2023 at 6:44 AM
    DoublePro
    DoublePro New Member
    Anyone knows if any UCA that uses rubber OEM like bushings? I have Total Chaos on my FJ cruiser, it has polyurethane bushings, squeaky af, even after I greased them. Cold weather makes it worst going up and down any curve. Ironman 4x4 has been sold out and don’t know when they will restock it according to them.
  14. Mar 21, 2023 at 7:27 AM
    2mchfun
    SPC adjustable UCA's have rubber bushings and easily replaceable ball joints as well.
  15. Apr 6, 2023 at 11:21 AM
    jojo9878
    jojo9878 New Member
    Joseph
    2016 magnetic grey 1794
    Front: 2.5 king 2.5 coil overs Rear: 2.5 kings
    Have you looked into JBA HC control arms?
  16. Apr 6, 2023 at 11:25 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Drip some tri flow on those uniballs every few weeks. Should not be a problem. Do they need replacing by any chance?
    Rodtheviking likes this.
  17. Apr 6, 2023 at 11:49 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Steer clear from non adjustable Icons. Hell, just get adjustable UCA's, cry once... or test your luck with the fixed UCAs but NOT Icons. Uniballs will last a very long time in CA so long as you keep them dry and lubed.
    alb1k likes this.
  18. Apr 6, 2023 at 12:12 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    In TX as well
  19. Apr 12, 2023 at 5:54 AM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    SPC's...better for roads and occasional offroad. JBA's way too much camber....per Dave at Coachbuilder. I always follow Dave's advice
    jayhawknavy02 likes this.
  20. Apr 12, 2023 at 7:34 AM
    hiimbrando
    hiimbrando Chop shop owner / Degenerate car part buyer.
    Brandon
    Dallas, Texas
    For those running SPC UCAs have yall had any issues with the ball joints? I ran them on my tacoma but swapped them out since they were going through ball joints prematurely. Seems like they had a bad batch.
  21. Apr 12, 2023 at 8:28 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I’ve heard this on multiple occasions with spc’s
  22. Apr 12, 2023 at 10:45 AM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Not had an issue....
  23. Apr 12, 2023 at 12:15 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    How much camber (in degrees) is too much camber? Gotta give us some real numbers to back this statement please. Not saying you're wrong, but hoping you can prove yourself right. Especially since a huge number of people would kill for a little more camber on our trucks to keep the tires away from the body mount.
    Coachbuilder1 likes this.
  24. Apr 12, 2023 at 4:30 PM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Call Dave...quoted a trusted vendor for hundreds on this forum should suffice. Certain situations call for more camber...mine didn't. I'm no expert that is why I called him. Please do the same he is always happy to help.
  25. Apr 12, 2023 at 5:13 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Just replace the ball joints. You don't need UCAs for 1.75" lift, that is perfect.
    And all of you talking about camber really mean caster. Camber is not negotiable, but caster can be higher than spec.
    One "bad" thing with aftermarket UCAs and a 1.75" lift is that they are usually designed for more lift, and move the balljoint back and in more than ideal... which may require a BMC.
    Saltyhero13 and dkrou like this.
  26. Apr 12, 2023 at 5:21 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Wasn’t trying to argue with you, just pushing to have accurate information posted rather than a person’s (or trusted vendor’s) opinion. Not knocking the parts or how the fit at all!
    Corbic likes this.
  27. Apr 13, 2023 at 6:05 AM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I'm sure it is an acccurate assessment even in lieu of the exact numbers which you seem to need to believe it...I sent the thread to Dave at coachbuilder hoping he can weigh in. Not sure he will....Just fyi...this entire forum is peoples opinions and experiences. If it had to be something beyond that to post we can all pack it in and go home.
  28. Mar 28, 2024 at 6:08 PM
    Corbic
    Corbic New Member
    Jack
    '17 Platinum
    And he never did.
    For information to be useful it needs to be backed by data.
    "Ideal range is x - y"
    "JBA puts you at Y++"
    Or whatever. Also in what situation? Stock? +1? +1.15"? 2" lift? Ect
    rruff likes this.
  29. Mar 28, 2024 at 6:26 PM
    rruff
    rruff New Member
    X-Y of balljoint relative to stock would be good info to have for the sake of comparison. I guess the manufacturers like to pretend this is esoteric info...
