Whirlpool washer help....any appliance repair guys here?
Discussion in 'Off-Topic Discussion' started by Tundra234, Apr 12, 2020.
  1. Apr 12, 2020 at 7:23 PM
    Tundra234 [OP] New Member
    I'm having issues with a Whirlpool Cabrio washing machine. It shakes violently and moves all over the place. I constantly have to reposition the load and it never gives an out of balance error. The clothes are soaked, and I'm assuming its caused by the other issues. Any help on what to look at will be greatly appreciated. Thanks.
  2. Apr 12, 2020 at 7:42 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Look like this one?
    Owners manual is located under the top panel behind the front piece if I remember right.
    assuming you are loading right it says check for level or select slower spin speed.
  3. Apr 12, 2020 at 7:43 PM
    Juanjoolio007
    Oregon
    You can put it in diagnostic mode and check for errors.
    Does it drain?
  4. Apr 12, 2020 at 7:44 PM
    CobySon
    CobySon New Member
    2017 White Tundra Platinum
    18 inch Method wheels 33s BFG KO2, front leveling kit only, painted front grill, LED interior lights, backup, puddle lights.
    broken springs on the bottom is my guess how old is the washer?
  5. Apr 12, 2020 at 7:45 PM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Take it apart and make sure all the springs are in place that hold the drum in place
    CobySon likes this.
  6. Apr 12, 2020 at 7:50 PM
    I looked at the springs today. None of them seem to be broken that I could tell. I'll look again though. All of the rods are fine. The tub itself drains, but the loads are drenched. I'm thinking it's because it's not spinning them out because of the severe wobbling? The machine is about 6 years or so.
  7. Apr 12, 2020 at 8:12 PM
    I found the whole OEM suspension kit on Amazon for $53.00. Sounds like a good plan since the springs could be worn and not broken at all.
  8. Apr 12, 2020 at 8:16 PM
    CaptainGrumpus
    Maine
    Probably worth a shot but I’ve chased problems before with washer machines and it always ends up with my replacing it.
  9. Apr 12, 2020 at 8:48 PM
    CobySon
    CobySon New Member
    I would replace the springs with that kit from Amazon. I have a washing machine that is twenty years old and I changed them twice already
    Tundra234[OP] likes this.
  10. Apr 13, 2020 at 5:51 AM
    soobaroo
    soobaroo New Member
    Gene
    2019 Tundra SR5
    We had a Speed Queen that lasted 25 years and was never serviced for anything. Just bought a new Whirlpool and I’m hoping for 10 years. If you have kids 6 years might be all the good years you get out of it. If you decide to replace it look at Speed Queen. We no longer have a dealer close by or I’d have a new one. They are more expensive but not in the long run.
  11. Apr 13, 2020 at 5:52 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Any washing machine called a "Cabrio" has got to have some problems imo. SMH. :D
    Pictured washer above is a new design top loader with no center agitator. If it has no center shaft to center the tub, then it likely has a "spider" inner tub support bracket just like the front loaders. If the machine has a spider tub support bracket, that is likely your problem. The service life of a tub support bracket in a Samsung front loader is around five years. Unless the owner can change the support bracket DIY, then it's not economical to pay someone to diagnose and repair it.
    I suggest you go to link below to look up the tub parts configuration. If that model has a "spider" tub support bracket, they'll probably have a repair video as well. Also check out youTube for repair videos...it's always my first stop for DIY help. People have made videos about everything under the sun.
    https://www.appliancepartspros.com/
    jeremyd and CobySon like this.
  12. Apr 13, 2020 at 7:11 AM
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    When I was shopping for washers this was a known issue with some of the newer top loading washers, and I do not think its truly fixable. I read a boat load of complaints about it! You may want to look in the reviews section of your particular washer and see if anyone found the solution, or Youtube it.
    Sorry and good luck.
    -T
    CobySon likes this.
  13. Apr 13, 2020 at 1:40 PM
    CobySon
    CobySon New Member
    I Google and YouTube everything it’s crazy how much information is out there. Just watch everything and use common sense to eliminate certain information sometimes. I am a French model .
  14. Apr 17, 2020 at 7:30 PM
    Update...washer is fixed. All of the springs and rods were connected and none were broken. They were just worn out. I installed the new ones and did a load and no issues......a perfectly drained load. I will have to replace the tub upper ring.....it was shredded and mangled on some of the edges. It actually got caught under the edge of the back panel.
    EDDO likes this.
  15. Apr 17, 2020 at 9:01 PM
    CobySon
    CobySon New Member
    Nice man sure does beat wasting money on a new one. Glad it worked out for you.
