Whistling Sound at High Speeds?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Scorpion006, May 4, 2023.
  1. May 4, 2023 at 9:44 AM
    Scorpion006
    Scorpion006 [OP] I'm athletic - I’m known to surf the web for hours
    Austin, TX
    2017 White Tundra 1794
    I'm not sure if this is something I've had since I got it (6 months ago) or if this only started happening after I installed my cat shield (Taco Tunes version).... but any time I'm driving north of 90 mphs (in MX or on a race circuit) I hear a very distinct whistling/howling like nose coming from what seems the front wheel wells... It depends on which side the wind is blowing to determine which side the noise is more apparent. Anyone else have anything like that happen?
  2. May 4, 2023 at 9:48 AM
    You're probably going to have noise at that speed. You're driving a non-aerodynamic cinder block.
  3. May 4, 2023 at 9:50 AM
    Scorpion006
    Austin, TX
    I didn't have any noise at those speeds in my 2007 Tundra.... only on this newer 2.5 gen (2017) Truck.
  4. May 4, 2023 at 9:51 AM
    Scorpion006
    Austin, TX
    Oh, and I think I've heard it at lower speeds (50 mph) too when the crosswind was blowing really hard.
  5. May 4, 2023 at 9:53 AM
    SwitchThrottle
    SwitchThrottle Living in Idiocracy
    2021 Barcelona CrewMax
    Is the sound only noticeable with the front windows down? Mine does that, and I've narrowed it down to mirror seams. I think it's turbulence related. If you change the air flow by moving your fingers around the seams, it goes away.
  6. May 4, 2023 at 9:58 AM
    Scorpion006
    Austin, TX
    Definitely not the windows - I've heard it with the windows down or up...
  7. May 4, 2023 at 10:53 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Sounds like air interacting with the slots in the plate (most likely) or the plate itself is vibrating (less likely if whistling).
    You may be able to fix the issue with vortex generators or bending the slots leading and lagging edges up if possible.
    If it is vibration of the plate some rubberized sound dampening mat might help but it will act as an insulator and a dust magnet so there is a tradeoff. You don't need to cover the whole plate probably just the middle to test first.
    I would reach out to TT first. If it is a common complaint they may have a fix for you.
  8. May 4, 2023 at 11:29 AM
    Scorpion006
    Austin, TX
    It's not the plate vibrating - I double checked that right after I heard it more than 1 time... I will reach out to ********* though - didn't think of that. Thanks!
    Saltyhero13[QUOTED] likes this.
  9. May 4, 2023 at 11:41 AM
    art64
    art64 New Member
    Get some high temp tape and block off some of the openings. Those long slot cut outs can make whistling sound. If the tape removed the whstling, then replaced tape with sheet metal. Trial and error thing.
    SC4333 and Saltyhero13 like this.
  10. May 4, 2023 at 11:44 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    My windshield needed to be replaced to fix my whistling issue. I ended up just going around taping stuff off on my truck with 2" wide painters tape and driving a blue-striped clownmobile up and down the highway until I figured it out.
    (Turns out the original buyer had a windshield replacement by insurance and whoever did it, didn't use OEM glass, which didn't fit right and wasn't heated. $300 later and my windshield is heated again and no longer whistles.)
    27bluenote and Saltyhero13 like this.
  11. May 4, 2023 at 11:55 AM
    Scorpion006
    Austin, TX
    Hmmm... Now I did have the windshield replaced with a OEM like windshield within the first month of purchase - I had a huge crack on the passenger front side. Mine was similar cost (So I doubt yours was OEM either, cause OEM is closer to like $800+). Mine is heated but I haven't tried to use painters tape to check their install. Might have to try that - Thanks!
  12. May 4, 2023 at 1:14 PM
    Saltyhero13
    Since it is not the plate vibrating and if you've eliminated the windshield as the culprit you can do what @art64 suggested and cover up the holes
    I would probably cover up the twelve up top to see if it makes any impact and if not switch to the bottom twelve. If the noise quiets down you can uncover one "Y" at a time to until the noise comes back. That will let you max airflow min sound.
    Hard to say what a fix could be by looking at them but it could be the thin pieces at the base of the "Y"s that are making a tone.
  13. May 4, 2023 at 2:26 PM
    centex
    centex New Member
    I’ve experienced this with different vehicles but not the tundra yet. Generally heavy cross winds at speeds over 70mph. Only thing I’ve come up with is turbulence across a seam or crease or something.
  14. May 4, 2023 at 4:40 PM
    SwitchThrottle
    When you figure it out, let us know. Curious what it ends up being.
  15. May 4, 2023 at 4:55 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    Tape up that shield as others mentioned. It is the easiest and quickest way to start your troubleshooting. I say it is the most likely cause too, from what you have described.
  16. May 5, 2023 at 7:30 AM
    Scorpion006
    Austin, TX
    Yeah, I think I might have to try this method.... might take some time though and hopefully the tape sticks under that much heat.
    Wonder how much heat those Y air slots actually help dissipate?:monocle:
  17. May 5, 2023 at 8:27 AM
    Saltyhero13
    Probably some trial and error to figure it out.
    You may not have to cover the whole slot.
    The other option is to just cover or Dremel out the thin piece of the "Y" if you can determine the whistling is from those parts.
  18. May 6, 2023 at 9:48 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Well, no shit there's a buncha whistlin' goin' on.
    centex likes this.
  19. May 6, 2023 at 9:52 AM
    centex
    centex New Member
    Glad I wasn’t alone on that thought.
    WILLINH and RichterScale[QUOTED] like this.
  20. May 6, 2023 at 10:26 AM
    Scorpion006
    Austin, TX
    Lol, and she's not just their pretty face, she actually works on all their trucks...
  21. May 6, 2023 at 10:40 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    I wouldn't want my vehicle worked on there.
    There ain't a damn guy in there that's watchin what the hell he's doing.
    Azblue likes this.
  22. May 6, 2023 at 11:55 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    :rofl:Yeah, that's a tough one. I've never driven that fast in this truck. I wonder what the top speed it?
  23. May 6, 2023 at 12:07 PM
    Scorpion006
    Austin, TX
    I've seen 120... truck is stable, just noisy.
  24. May 6, 2023 at 12:08 PM
    Scorpion006
    Austin, TX
    True story... lol
    RichterScale[QUOTED] likes this.
