Whistling wind noise from side mirrors
Discussion in '3rd Gen Tundras (2022+)' started by Kap1, Oct 27, 2022.
  1. Dec 15, 2022 at 5:57 AM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    I agree manufacturing tolerance could be the difference. Consider something less extreme than filling in the whole gap so you can manually fold the mirror. Just a thought. But wonderful find none the less.
  2. Dec 15, 2022 at 12:28 PM
    2301CC
    2301CC New Member
    23Tundra Platinum Hybrid
    359A9FB6-AB0A-4A89-B337-B11184C1B29B.jpg Maybe toyota should go back to one of their vortex generators by the mirrors
  3. Dec 19, 2022 at 11:13 AM
    armyosboy
    armyosboy New Member
    Aldie, VA
    2022 SR5 TO
    I tried ordering a vortex generator and sticking it to it with a blue tape. It didn't work. I'm planning to take it to the dealer and see if they have a solution.
  4. Dec 19, 2022 at 11:27 AM
    hBaz
    hBaz New Member
    middle of nowhere south of OK City
    2021 black 1794 Edition with TRD package
    Kap1[OP] likes this.
  5. May 23, 2023 at 10:17 AM
    sopranojam85
    sopranojam85 New Member
    2023 Metallic Gray Tundra Limited Crew-Max 2WD
    The dealership replaced my driver side mirror and fixed this problem in doing so. It was not a big deal, just one of the things done at my 5k service.
    Kap1[OP] and Mattedfred like this.
  6. May 23, 2023 at 5:12 PM
    Kap1
    Kap1 [OP] New Member
    San Francisco, CA
    Thats cool. So far we didn't have any reports of mirror replacement resolving the issue.
    My mirror stop whistling on its own after about 2k miles
    Is it possible that they also replaced the rubber runner seal between top of the window and door frame?
  7. May 23, 2023 at 5:40 PM
    armyosboy
    Aldie, VA
    2022 SR5 TO
    My whistling less during the summer time. Maybe the rubber seal expands during warmer weather? If it comes back in colder temperature, I'll ask them to replace
  8. Aug 22, 2023 at 11:13 AM
    Unitdosed
    Unitdosed New Member
    '22 Celestial Silver SR5, CREW CAB TRD OR 4X4
    None, yet
    Does anyone here know if there's a thread on gap tolerance for headlight and hood spacing?
  9. Oct 24, 2023 at 2:28 AM
    06X3Tundra
    06X3Tundra New Member
    I have the same issue on my 2022 tundra sr5 off-road package crewmax.
    Haven’t tried fixing it yet but it’s so annoying and usually happens post 55ish mph like started before by others.
  10. Oct 24, 2023 at 5:40 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2022 Tundra Platinum
    I posted this in another thread somewhere but I had whistling from drivers side between 35-40 mph. I taped some things up and isolated the noise. On mine it was whistling on the inside of the pivot points with the mirrors in the outward position. There are two black plastic pads and one is slightly raised. I used clear hockey tape which is very pliable. I taped over the two pads and the noise is now gone. Here are pics of what I did
  11. Oct 24, 2023 at 5:52 AM
    PhearCVBz
    PhearCVBz New Member
    2021 Black Tundra DC, 2024 Black Tundra CrewMax
    I picked up a 2024 a few weeks ago and this was the first 'issue' I noticed. Plan on mentioning it to the dealer, but may try one of the tape fixes in the meantime. Thanks.
  12. Oct 24, 2023 at 7:32 AM
    Kap1
    San Francisco, CA
    Wow that's good you figured it out. I waited on mine and dust/dirt may have filled in some hole and the mirror stop whistling after about the first 2-3k miles. They had to replace driver window runner though to completely get rid of whistling sounds.
    You should tape it up and find exact spot that causes the whistling, otherwise dealer will be looking for it forever... Read through this thread on all the possibilities and what to tape
  13. Oct 24, 2023 at 11:05 AM
    06X3Tundra
    Can’t believe they don’t have a fix for it yet
  14. Nov 29, 2023 at 4:12 PM
    atomic4877
    atomic4877 New Member
    2024 Toyota Tundra TRD PRO
    Has anybody had any luck using any materials (tapes preferably black) that will work for the auto folding mirrors? I have a brand new ‘24 TRD pro that I just purchased the other day at my local dealer and have a terrible whistling noise above 55 mph from at least the driver side mirror (not sure about the passenger side) that goes away when I use my hand to cover the front of the pivot point. I can hear it windows open/closed.
  15. Nov 29, 2023 at 8:30 PM
    Kap1
    San Francisco, CA
    You have to pinpoint the exact area what's causing the whistling.
    Take white or blue painters tape, tape up all of the seals and gaps around the mirror and the window and door and take it off little by little to determine which area is causing the whistling, then take photos and show it to your dealer once you figure it out.
    I had same issue with mirror supposedly causing whistling, but it was actually the rubber window runner. Again, tape it up and figure out what's causing it exactly.
  16. Nov 29, 2023 at 8:42 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Just turn up the fricken radio....the worlds an imperfect place. After driving my truck in. Pa. for 8 months now and hitting every fucking pothole...it sounds like shit. Other things to worry about than whether or not you can hear yourself breathe...
  17. Nov 29, 2023 at 8:50 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I would have respected this post more if it was all in Caps.
    Mattedfred and Roborob70[QUOTED] like this.
  18. Nov 30, 2023 at 12:15 AM
    Roborob70
    Robert
    JUST TURN UP THE FRICKEN RADIO... THE WORLDS AN IMPERFECT PLACE. AFTER DRIVING IN PA. FOR 8 MONTHS NOW AND HITTING EVERY FUCKING POTHOLE... IT SOUNDS LIKE SHIT. OTHER THINGS TO WORRY ABOUT THAN WHETHER OR NOT YOU CAN HEAR YOURSELF BREATHE
    TexasCabledawg and Mattedfred like this.
  19. Nov 30, 2023 at 11:49 AM
    #49
    atomic4877
    I went ahead and took a trip this afternoon and still heard the whistling. so I taped the mirror pivot points from the front over the top, the whistling sound was gone. I only have 60 miles on it and frustrating to say the least. Some road noise is expectable, but the high pitch whistling sound is like nails on a chalkboard. I am going to look around this weekend to find a tape solution that will work the best. I am looking at either the hockey tape, clear repair tape, or possible even the felt side of velcro to help seal up the gap. Looking for something not blaringly obvious when the doors are locked and mirrors folded.
  20. Feb 5, 2024 at 11:59 AM
    #50
    sauceboss269
    sauceboss269 New Member
    I am having the exact same issue (24’ Limited). I have tried electrical tape over the gaps up front, it solved it for a little while until I was riding in some gusty winds and came back. Any further recommendations?
  21. Feb 5, 2024 at 2:10 PM
    #51
    Kap1
    San Francisco, CA
    You guys supposed to use tape to pinpoint issues and show dealer exactly where noise is coming from, then let them do their job and fix it for you
  22. Feb 5, 2024 at 2:13 PM
    #52
    sauceboss269
    Did that and unfortunately were not able to pin point it. The dealer attempted too at multiple occasions and weren’t able to pin point either
  23. Feb 5, 2024 at 2:15 PM
    #53
    Kap1
    San Francisco, CA
    How is that possible?
    Step 1. Tape up everything. Is the noise gone? If yes go to step 2.
    Step 2. Remove tape little by little and keep driving around to test, at certain point you'll hear noise comeback - it came from the piece of tape you removed last. Show that spot to the dealer and have them start swapping out seals for window, door, etc
  24. Feb 5, 2024 at 2:17 PM
    #54
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Sounds like a dealer problem they should figure out??
  25. Feb 5, 2024 at 2:18 PM
    #55
    sauceboss269
    Did exactly that, thought it was coming from the bend (noise came back as I uncovered, and covered back up). It stopped the whistle for a while, but in gusty conditions and seems at a certain angle it comes right back.
    Showed them the location and came up with the same “issue” I was having
  26. Feb 5, 2024 at 2:21 PM
    #56
    sauceboss269
    I thought the same, but after 3 different appointments and leaving it for multiple days they told me they couldn’t do anything or figure it out and that was the end until something is reported by Toyota
  27. Feb 5, 2024 at 2:33 PM
    #57
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    SauceBoss, try the clear hockey tape like I showed a few post up. It sticks well and is very pliable. Just cover up those black plastic pad thingys inside the mirror. Mine has held up for over a year with no whistling. Again mine was specific to the 30-40 mph range. Good luck
  28. Feb 5, 2024 at 2:39 PM
    #58
    sauceboss269
    okay! I have been using electrical tape at the location you showed. But I will try hockey tape and someone also mentioned foam tape.
    Yeah mine starts around 45mph and higher
  29. Feb 5, 2024 at 3:12 PM
    #59
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    Clear hockey tape. Its more rubbery than regular hockey tape
  30. Feb 5, 2024 at 3:57 PM
    #60
    Kap1
    San Francisco, CA
    Why not just use paper painters tape? Easy to remove and leaves no residue.
