Who has spyder headlights and has swapped to led bulbs?
Discussion in 'Lighting' started by Rica25, Jul 30, 2018.
  1. Jul 30, 2018 at 8:56 PM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    Who's switched over from the halogens to led on spyder headlights?
  2. Jul 31, 2018 at 5:17 AM
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    matictundra and War Machine like this.
  3. Jul 31, 2018 at 6:07 AM
    Rica25
    Ricardo
    Tulare
    I installed those also but I don't think they are bright enough .....on my stock headlight housing I had jdm led lights and they were real good but now I tried these and don't really like the output
  4. Jul 31, 2018 at 7:29 AM
    War Machine
    War Machine SSEM # 5 3MW
    Did you take the black caps off the tips? They are screwed into the end. I didn’t notice when I installed mine. When I took them back off to return them I noticed it. Once they are off the output is much better. It says nothing about this in the paperwork that came with them.
    tinman10101 likes this.
  5. Jul 31, 2018 at 7:32 AM
    War Machine
    The little black piece on the tip is supposed to come off.
  6. Jul 31, 2018 at 8:03 AM
    Rica25
    Ricardo
    Tulare
    Ok I'll try and see I didn't notice them
  7. Jul 31, 2018 at 8:06 AM
    Rica25
    Ricardo
    Tulare
    Screenshot_20180731-080536_Chrome.jpgI dont think mine have that black cover
  8. Jul 31, 2018 at 8:07 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Do u install this in the stock headlights to replace the haolgens?..
    War Machine[QUOTED] likes this.
  9. Jul 31, 2018 at 8:16 AM
    War Machine
    You can, and I did at first. Depending on your lift, etc, they’ll be pretty bright to oncoming cars in the stock reflector housing. I ran it that way for a month or so, but I kept them aimed down unless I was on an empty road.
    So, yes, they’ll work, and put out good light, but may be a problem for other people on the road. I didn’t get a lot of people flashing their brights at me, but it did happen. Also pretty bright if you’re behind a small car. Even with the Spyder projectors I keep them pointed down about halfway.
  10. Jul 31, 2018 at 8:36 AM
    saybng
    Gary
    Ventura CA
    My truck is just leveled, thanks for the input, going to order them soon..also do these heat up in the housing?
  11. Jul 31, 2018 at 9:03 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    i have smoked spyders with Heise LEDs... overall, not impressed by the output. I heard that HIDs are a little better when working with the spyder heads though.
    I came from TRD black housing and PlashLight LEDs and the difference is night and day (literally). if the spyders didn't look so cool, I would sell them immediately. if I didn't have aftermarket LED fog lights, I would be better off with stock heads.
  12. Jul 31, 2018 at 9:40 AM
    PMG
    PMG New Member
  13. Jul 31, 2018 at 10:20 AM
    Bo-Hunter
    Greg
    NOVA
    2009 RW 4x4 Truck
    I think they are much brighter than the stock lights. You can also get them in a 12,000lm version for a little more.
  14. Jul 31, 2018 at 10:22 AM
    War Machine
    Not that I’ve noticed. LED lamps in general are much cooler than any other option.
    saybng[QUOTED] likes this.
  15. Jul 31, 2018 at 10:26 AM
    War Machine
    Actually H11 I believe. It wasn’t the same as what was in the stock ones.
    HecticEnergy likes this.
  16. Jul 31, 2018 at 12:03 PM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    Appears to be the same as the Gen 2's
  17. Jul 31, 2018 at 12:06 PM
    War Machine
    When you get them, look up how to switch your leveling motors over. It’s pretty easy.
  18. Jul 31, 2018 at 12:09 PM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Easy enough, but make sure you look at a few different resources before jumping in (watch some youtube videos, look for writeups online, etc). Could easily damage your headlight if not careful.. but it's only like 3-5 steps.
  19. Jul 31, 2018 at 12:10 PM
    War Machine
    I just remember being pretty aggravated. I had the led lamps in my stock headlights, which meant I took the grill out when I put those in the first time. Then I got the Spyders, took the grill off again, found out the old lamps didn’t fit, put it all back together, ordered the right led lamps, did it all again.
    Total bullshit that you have to do all that just change a headlight lamp. I can imagine having to do that in a parking lot some night on a trip, which I’ve had to do on vehicles before.
    HecticEnergy[QUOTED] likes this.
  20. Jul 31, 2018 at 12:25 PM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    My initial thoughts exactly.
    I did the same thing: Swapped lights in stock housing, swapped housing... mine shipped with bulbs though, so that was nice... Why the hell do I have to take the whole front of the truck apart to swap bulbs!? Also, unless you have the proper tool (low profile ratchet or similar angled tool of the appropriate size) good luck setting the initial level on your lights... I feel like they made all that way more complicated than it had to be.
    Mine shipped with upgrade bulbs too (for an additional charge)... but they style they sent didnt fit... They'd fit the factory housing, but not the spyders they came with... wtf? I meant to bring that up to them (pro tuning labs) but I forgot until just now.. and it's probably too late to do anything about it. Oh well..
  21. Jul 31, 2018 at 12:34 PM
    War Machine
    Yeah, my gen 2 and my wife's Sequoia weren’t like that. I can understand them not worrying about it being easy to change the housing, but just to change the bulb is insane. Most people will have to do that at some point. It’s a perishable part. They should have more foresight than that. It’s kind of like a car I had in the nineties. You had to take a fender off to get to the oil filter. You think I ever changed that filter?
  22. Jun 24, 2019 at 11:48 AM
    Truck Norris
    Truck Norris New Member
    David
    2013 Tundra
    loading....
    I have the Spyder - Black LED DRL Bar Projector Headlights on my 2013 tundra. In the process of switching out low beams to leds but has anyone or can you even switch out the bulb on the drl bar so that it is brighter without taking the light apart and breaking the seal?
  23. Jun 26, 2019 at 4:51 AM
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    I did the switch but not blown away at all. I dont think the LED's work well in the spyder headlights, Im awtiching back to H1 Halogens or Ill do a Morimito Conversion.
    Truck Norris likes this.
