Who is Towing Above Tow Capacity?
Discussion in 'Towing & Hauling' started by Tundra1194, Apr 14, 2024.
  1. Apr 14, 2024 at 5:49 PM
    Tundra1194
    Tundra1194 [OP] Tundra Dave
    Dave
    Colorado Springs, Colorado
    2017 Tundra
    My 2017 Tundra Crewmax is tow rated at 7200 pounds. I tow a 32 foot travel trailer which has a dry weight of 9,000 pounds. I never tow with full fresh water or waste water tanks.
    I have towed the camper for several thousand miles without issue. In tow mode with the transmission in the recommended S4 position, there has been plenty of power. I have installed a fan-driven external tranny cooler, bypassing the factory-installed cooler. I constantly monitor the tranny temperature with a Bully Dog and seldom does the temperature get above 195. Every now and then, on a hot day and climbing a steep grade, it has gotten over 200; then I look for a pull-off, have lunch, and let it cool down.
    My vacations typically are for a month or more. When I get home, I drain and replace the fluid that's in the pan, which usually has no more than 6,000 to 7,000 miles on the fluid. That's way more than recommended change interval.
    I don't use Toyota brand fluid, but Valvoline full synthetic multi-vehicle fluid. I expect Toyota fluid has a longer life than Valvoline, but I doubt it matters under my conditions.
    Is anyone else like me? Are you towing heavier than your door panel's rated capacity?
    Here's a tranny build shop YouTube link that rebuilt a seriously-abused AB60F tranny -- way more abused than my towing conditions:
    https://www.youtube.com/watch?v=3jrwkr-SUhQ
    koditten likes this.
  2. Apr 14, 2024 at 5:51 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Oh boy.
    Let me go get a beer and some popcorn.
  3. Apr 14, 2024 at 6:18 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    2nd and 2.5 gen towing performance is feeble.
  4. Apr 14, 2024 at 6:30 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    This thread is going to be fun!
    If a Gen 2 or 2.5 can pull the space shuttle. Then anything is possible!
  5. Apr 14, 2024 at 6:57 PM
    hainesfive
    hainesfive New Member
    MD
    2020 Black TRD Sport Crewmax
    TRD Dual Exhaust Weathertech rear floor liner Black out badging Linex sprayed bed TRD PRO Wheels VLED Interior and exterior Drivers side grab handle Front drivers and passenger window tint Focal speaker upgrade with amp and 10" sub Retrax pro bed cover Falken tires
    My Lawyers will love you for this, God forbid you're ever in an accident when towing with it. SMH
  6. Apr 14, 2024 at 7:00 PM
    You are over-servicing the transmission. 30k mile intervals is way more than needed.
    Cpl_Punishment and PBNB like this.
  7. Apr 14, 2024 at 7:05 PM
    2mchfun
    What size tires? Any differential gear mods?
  8. Apr 14, 2024 at 7:08 PM
    centex
    centex New Member
    I only tow a rzr but leave it in s5 and set the cruise at 75 and the temps settle around 205*. When I stop they go to 225-230. No clue what the previous owner did but he towed a camper. Still not gonna change the fluid until a 100k because I’ve spent to many decades dealing with this and realize the internet just scares people into thinking vehicles are delicate flowers that will shatter the moment you don’t follow their guidelines.
    The real concern you should have here is overloading the truck and the wear and tear on it from that and the safety impact of doing such.
  9. Apr 14, 2024 at 7:09 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    You know what’s way more than needed, a 3500 series truck. Real men just use a tundra. :p
  10. Apr 14, 2024 at 8:02 PM
    Good luck....:rofl:
  11. Apr 14, 2024 at 8:25 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Is 205 at the TC or the pan? There are 2 temp sensors
    i find when towing the TC is usually 3-4 degrees warmer consistently. The pan is often at 199 while my TC will peg at 203
  12. Apr 14, 2024 at 8:43 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Pfffft
  13. Apr 14, 2024 at 8:54 PM
    :rofl::rofl::thumbsup:
  14. Apr 14, 2024 at 10:44 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    :ohsnap::benchpress:
  15. Apr 15, 2024 at 12:18 AM
    NatesNightMare
    Pinetop Az
    What do you guys use to monitor trans temp?
  16. Apr 15, 2024 at 3:53 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Have you looked in your owners manual for you actual tow rating for your VIN? The 7200lbs, on the door jamb sticker, is the truck's Gross Vehicle Weight Rating (GVWR). This is not your towing capacity. This is your vehicle and payload (people, fuel, items inside/on the truck/in the bed, and hitch and tongue weight).
    The manual will have your tow ratings, which I'm guessing will be somewhere around 8800-9200lbs based on VIN (your 1794 is slightly different than my fully loaded Limited).
    Are you saying your truck itself is weighing in at 9000lbs? Have you been to the CAT scales to confirm any of your numbers? If not, encourage you to take that journey. It'll tell you what's real vs not and may be surprising in a few areas.
    Happy camping.
  17. Apr 15, 2024 at 4:37 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I use a piece of bacon on the Xmission tunnel inside the cab.
    If I smell delicious bacon frying then I know the ATF is right around 325°F, just like Mr. Sweers intended.
    If the cab is getting smokey then I know I need to goggle AAMCO near me.
  18. Apr 15, 2024 at 4:45 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Bacon doesn't lie. It's too good to do so.
  19. Apr 15, 2024 at 4:46 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Cpl_Punishment likes this.
  20. Apr 15, 2024 at 4:57 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Your GVWR is 7200 lb. Your tow rating is probably north of 9k. What build code is on your door jamb sticker? It’s the bunch of letters with a dash in the middle at the bottom of the sticker that has your GAWR (4000 lb FF, 4150 RR) on it.
    My big fat ‘21 crewmax is still rated for 9400 lb. With 1270lb of payload, that’s good for me and 1100lb of tongue weight.
  21. Apr 15, 2024 at 5:10 AM
    koditten
    Kirk
    Midland of the Mitten
    I could have wrote this.
    My specs are similar except I drag a 5th wheel RV.
  22. Apr 15, 2024 at 5:12 AM
    koditten
    Kirk
    I read about this all the time, but I've never actually seen any litigation because of over capacity.
    Leo's first likes this.
  23. Apr 15, 2024 at 5:18 AM
    yt-1300
    yt-1300 New Member
    2021 white sr5 crewmax 4x4
    I’ve never heard of litigation but I have heard of insurance not covering the owner vehicle’s. The claim was the accident would have been avoidable had towing capacities not been exceeded.
    It makes sense because that number isn’t about what it can pull its about what it can safely stop and control.
  24. Apr 15, 2024 at 5:28 AM
    koditten
    Kirk
    What makes a 3/4 ton truck a safer tow vehicle than a 1/2 ton truck?
    It's not because it can stop faster. The trailer does it's own stopping.
  25. Apr 15, 2024 at 5:29 AM
    Terndrerrr
    Music City
    6UR-FE
    Please link to this. My understanding is that this is an internet myth.
    Insurance exists because of your negligence. They have to pay for negligent acts. Knowing you are speeding, knowing you drank too much, knowing your trailer is too heavy, etc—these are all negligent acts. The ONLY thing insurance denies claims for is fraud.
    Remember the Ram HD truck with too big of a truck camper in his bed that ended up breaking his frame? His insurance covered it. Because it wasn’t fraud on his part; it was gross negligence.
  26. Apr 15, 2024 at 5:36 AM
    koditten
    Kirk
    I'm thinking if you had consecutive insurance claims/accidents on your RV, then you could be cancelled...but I think a sane person would realize at that time, that RV ownership is not for them.
  27. Apr 15, 2024 at 5:54 AM
    I don't have a link because it's not national news, but a few months ago my best friends wife wrecked his new Ranger by hitting a travel trailer at an intersection on her way home from work. He a notification on his Ford app (I think for airbag deployment) so we hopped in my truck and ran down the road to help.
    Totaled the Ranger, spun it 180º. Also spun the trailer she hot 180º and rolled it on its side. His wife was dazed and didn't know what had happened, so she assumed she had a seizure and said that to the cops on scene. Of course tgey wrote that down and marked her as at fault. Other stuff in there that makes he and I doubt she had a seizure, but that's personal stuff that doesn't need to be on here.
    The tow vehicle was a little undersized SUV and my buddy had taken pictures of the scene. He provided those to his insurance and upon reviewing the pics they marked it as not at fault in they're system and are pursuing the other party for damages. They're reasoning; the trailer should never have been there in the first place because the tow vehicle wasn't rated for it. His premium isn't going up and he doesn't have to pay for anything related to the accident.
    Towing over ratings leaves you liable.
    ColoradoTJ likes this.
  28. Apr 15, 2024 at 5:55 AM
    I hate these threads.
  29. Apr 15, 2024 at 6:03 AM
    Most if not all of these cases have an NDA and the people involved are not going to risk that.
  30. Apr 15, 2024 at 6:25 AM
    Terndrerrr
    Music City
    6UR-FE
    So it shouldn’t have been there because it looked too big, or it shouldn’t have been sticking out in the intersection?
    Can you get a screenshot of some details from the insurance company from your best friend?
    You may get a limp-wristed attempt from an insurance company to deny a claim, but my understanding is that insurance exists for your negligence, and they will pay up to the policy coverage limits you pay for. Will they drop you or raise your premiums? Sure, those are possibilities.
    Insurance covered the Ram 3500 truck camper guy for being overloaded.
    Everyone on the forums: “Insurance is going to deny his claim because being overloaded makes you liable!”
    His insurance company: Insurance covers $17k repair to Pavel’s broken Ram 3500 frame
