Who wants to buy the rave and ebay heritage grill lights to see if they are different?
Discussion in '3rd Gen Tundras (2022+)' started by Savagesawyer, Aug 20, 2024.
  1. Aug 20, 2024 at 2:39 PM
    Savagesawyer
    Savagesawyer [OP] New Member
    Beaverton, OR
  2. Aug 20, 2024 at 2:42 PM
    Savagesawyer
    Beaverton, OR
  3. Aug 20, 2024 at 2:43 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    same trash
  4. Aug 20, 2024 at 2:45 PM
    Savagesawyer
    Beaverton, OR
    I'm not one to read into things, but I can sense a tone in there that this has been exhaustively discussed already.
  5. Aug 20, 2024 at 2:53 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I went with the OE grille, then a Diode Dynamics light bar and I am trying the Rave grille lights. They have been good but they are different and a bit brighter than the OE ones which I might end up putting in afterall.
    just waiting till the new engine is installed.
  6. Aug 20, 2024 at 2:55 PM
    Savagesawyer
    Beaverton, OR
    Well, I know someone who might be willing to buy them off of you...I've been spending too much money on this truck already and am obviously trying to cut corner with the lighting for now. I want the good stuff eventually, but for now I just need a placeholder so there isn't a big hole in my grille.
  7. Aug 20, 2024 at 3:00 PM
    eddiefromcali
    Eddie
    100% Stock
    yes, the china/rave bar are the same. Abysmal output when compared with a true light bar. Evident by the teeny tiny lead wires coming from the bar itself. The ambers are not like oem and the orange lens will fade. I was one of/the first to install the knock off lights when they first came out and before they made the metal brackets for it and had them installed for the longest time before I upgraded. Get oem markers and a true lightbar in the grille if you want quality/useful output. The china bar looks fine and fits good on an oem grille...Im sure itll work even better on a chinesium grille but idk how the fit n finish compares.
  8. Aug 20, 2024 at 3:05 PM
    Savagesawyer
    Beaverton, OR
    I actually knew you were an OG because I went back into the 2022 threads and saw you there. Appreciate the sage advice. I do have the OEM grille coming, but I might as well just hold off on installing it until I can have quality all around. Enable my laziness please (I know there are threads on here about this topic): can I install the lights after installing the grille, (i.e., without removing the grille)?
  9. Aug 20, 2024 at 3:14 PM
    eddiefromcali
    Eddie
    100% Stock
    the markers? probably. Bar might be tricky if you have the shutter things...that one I think requires grille removal for sure
  10. Aug 20, 2024 at 3:26 PM
    Savagesawyer
    Beaverton, OR
    Ah yes, I forgot about that thing. For sure will need to remove it, but it looks like a simple project.
