Why did Toyota officially change the oil from 7.9 quarts to 8.5
Discussion in '2.5 Gen Tundras (2014-2021)' started by IEsurfer, Feb 11, 2025.
  1. Feb 11, 2025 at 12:05 PM
    IEsurfer
    IEsurfer [OP] New Member
    jimbo
    Socal
    2005 tundra 4x4
    So I had a 2021 tundra a few years ago and put in 8.5 quarts per the manual and the dipstick read full and life was good
    I just got a 2016 tundra (both non flex fuel 5.7) and did my first oil change the day I got it from the dealer and since I’ve always put 8.5 quarts that’s what I did but after driving it around the next day and I let it sit on the street leveled and flat went to the gym for an hour and checked the oil and it read as over filled! My friend with a 2017 tundra said his manual puts in for 7.9 so I checked mine and to my suprise it said the same
    so this morning I checked it again after it sat overnight and it reads full now instead of overfill so I’m beyond confused if it took 8.5 for all these years and Toyota realized it and changed it during 2020? I included two pics one where it reads just full after sitting overnight and the other where the black line is after driving and sitting for an hour
  2. Feb 11, 2025 at 12:21 PM
    Tundra1D6
    My 2008 says 7.5 with filter. Maybe the 07-09 had different from 10-13. The. 14-21 had more, strange.
  3. Feb 11, 2025 at 12:28 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    My 17 is 7.9 with filter.
  4. Feb 11, 2025 at 12:42 PM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    My 2020 is around 8.25 - 8.5
  5. Feb 11, 2025 at 12:45 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    This is from Toyota TIS. It's 7.9 without a filter. 8.5 with.
    From my experience this is how the dipstick read.
    6 quarts low mark
    7 quarts almost in the middle
    8 quarts to the full mark
    After running need to add .5 to get back to full mark so capacity with oil and filter is 8.5qts
    HulkSmurf14 likes this.
  6. Feb 11, 2025 at 12:47 PM
    AZBoatHauler
    So.Arizona
    8 always gets me where I want to be.
    HulkSmurf14 and koditten like this.
  7. Feb 11, 2025 at 1:27 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    My 2017, as already mentioned, says 7.9 US quarts. I put in 8.4 US quarts and all is at peace with the world.
    IEsurfer[OP] likes this.
  8. Feb 11, 2025 at 1:32 PM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    My 2021 takes 8 qts to hit the midway point on the dipstick, 8.5 snugs me right up to the fill line
  9. Feb 11, 2025 at 2:30 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    8 quarts gets mine to just a tiny bit below full mark. I check it hot a few minutes after running like my manual says.
    Clemsonman14 likes this.
  10. Feb 11, 2025 at 2:49 PM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    Listed in my build thread
    My 2008 manual for the 5.7 says 7L (7.4 quarts) with filter (below picture). One time I just googled how much oil to put in a 5.7 and it was 8+ quarts. The dipstick showed it was overfilled. I wondered why so I checked my manual and saw it should have been 7.4 quarts. Not sure where that extra oil goes in the newer trucks.
    For the dipstick, I normally have one side that reads lower and the other side reads higher. The higher side is often streaky (doesn't completely cover the width of the dipstick). I experimented once adding a little oil at a time and the lower side came up a little each time as expected while the higher streaky side jumped around.
