WHY does PA put a #2 on my truck?
Discussion in 'North East U.S.' started by rmdepero53, Oct 14, 2024.
  1. Oct 14, 2024 at 8:36 AM
    rmdepero53
    rmdepero53 [OP] New Member
    Rita
    2010 tundra 5.7cu, crew cab
    none
    im trying to figure out what the #2 sticker mean?
  2. Oct 14, 2024 at 8:53 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    It's the weight class the truck is registered under.
  3. Jan 22, 2025 at 8:42 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    If your talking the inspection stickers, because I wondered this myself...If your in a big city one is for mechanical and the other is for emissions. In reading you need two.
  4. Jan 23, 2025 at 3:18 AM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    The post above noting the weight class is 100% correct.
    Keep in mind the higher the weight class, the higher your registration cost is.
    You can always register lower if you don't tow or carry a lot of weight, since you are at a weight class 2, I would not go any lower.
    When I bought my truck i registered it at weight class 2 but could have registered it at weight class 3 per the weight listed from the manufacturer (7200)
    In fact the dealer wanted to register it at weight class 3 but since I don't tow more than 5000 lbs, I had them make it class 2 to save some cash every year.
    Make sure the title reflects the correct weight (NOT what the truck is registered for). These numbers may be different. For example, My truck is registered at weight class 2 which is 5001-7000 lbs but is titled at 7200 lbs which is from the manufacture. This would allow me to increase to weight class 3 is needed, but I don't see that happening. My dealer I used had no idea about this and I had to walk them through it and they still made mistakes which took weeks/months to straighten out.
    Remember even if it was registered at weight class 3 (which is up to 9000 lbs), you should not exceed the manufactures weigh limit, which in my case is 7200 lbs.
    increasing my weight limit 200lbs was not work the added expense every year in my case.
    hagrid likes this.
