Will 275/65/18 fit on my 02 tundra sr5 stock?
Discussion in '1st Gen Tundras (2000-2006)' started by Leosteel, Aug 3, 2021.
  1. Aug 3, 2021 at 9:57 PM
    Leosteel
    Leosteel [OP] New Member
    Leo
    2002 sr5 tundra 4.7 4x4
    I need new tires and found a sweet deal on a pair of 275/65/18 big foot’s I’m currently running on 275/70/16 ko2’s. I’m not 100 percent on tires so I don’t know if I should do it?
  2. Aug 3, 2021 at 10:02 PM
    Leosteel
    Leo
  3. Aug 3, 2021 at 10:17 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    They’re similar overall size. But the wheel may not fit properly and cause issues
    Depends on backspacing and offset
    Leosteel[OP] likes this.
  4. Aug 4, 2021 at 2:48 AM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    You're going to need 18" wheels if you don't have a set laying around.
    Do you plan on off-roading? If so, upgrading to larger 18" wheels will work against you. They'll be wider, much more likely to take dings on the trail, and you will not be able to air down your tires and achieve the same ride/ footprint as an aired down 16" tire.
    Unless you meant 275/65/16?
  5. Aug 4, 2021 at 6:15 AM
    Leosteel
    Leo
    Where do I find that info out?
  6. Aug 4, 2021 at 6:28 AM
    Leosteel
    Leo
    3549295A-F349-4D56-9E85-0CB1E7FD51B8.jpg 3549295A-F349-4D56-9E85-0CB1E7FD51B8.jpg
  7. Aug 4, 2021 at 6:39 AM
    des2mtn
    SW
    Tonto cover
    That information will be specific to the 18" wheel that you intend to use with the 275/65/18 tires.
    The 275/65/18 tires will not physically fit onto your current wheels. Your current wheels are too small in diameter for 275/65/18 tires.
  8. Aug 4, 2021 at 7:30 AM
    Leosteel
    Leo
    I will be getting both tires and wheels. The sizes look very similar
    des2mtn[QUOTED] likes this.
  9. Aug 4, 2021 at 7:49 AM
    des2mtn
    SW
    Tonto cover
    Thanks for clarifying. Backspace/ offset basically determines how far out your wheels (and tires) will sit when they're bolted on your truck. If you get a wheel with the wrong offset, the wheel itself can sit farther in the wheel well and may hit suspension components, or the tire can hit the frame.
    Since the tires are very similar in overall size, it's more a question of "will the wheels I want to use with these tires work?"
    https://www.tundras.com/threads/offset-and-backspace.255/
