Will 275 75 r17 fit on tundra double cab sr and not rub
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bentundra563, Apr 18, 2022.
  1. Apr 18, 2022 at 2:47 PM
    Bentundra563
    Bentundra563 [OP] New Member
    Truck is standard ride height l just bought 285 75 r17 tires and rims to go with them didn’t know you had to lift the truck 2 inches to make them work. Can I change to 275 to have all the clearance and not have a leveling kit?
  2. Apr 18, 2022 at 3:03 PM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    Im not sure how much help I am but this is clearance on a 275/65/18 stock height. Dont look there is much room to go wider without lifting.
    Drivers side.
    Passenger side
    Addition: yes, my truck looks like shit underneath and on top cuz nobody sees it but me... Well and yall:thumbsup:
  3. Apr 18, 2022 at 3:52 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I am running 285/70/17, your 275/75/17 would be about 1/2" taller than mine and it would fit on my truck based on what I have seen. The closest I am to rubbing right now is on the small plastic mudflaps in the front wheel well and pulling those gains you some space at the expense of just a little bit of mud and dirt on the front door.
  4. Apr 18, 2022 at 4:35 PM
    PermaFrostTRD
    Northern NY
  5. Apr 18, 2022 at 4:44 PM
    TRDBurglar
    TRDBurglar New Member
    Slidell, LA
    2016 TRD Crewmax
    Level kit, Method MR316 wheels, 295/70R-18 FALKEN WILDPEAK A/T3W, BAK Revolver X4s tonneau, RB20s
  6. Apr 19, 2022 at 4:19 AM
    Bentundra563
    These are the rims that I ordered
  7. Apr 19, 2022 at 4:22 AM
    Bentundra563
  8. Apr 19, 2022 at 4:51 AM
    PermaFrostTRD
    Northern NY
    Those are great looking wheels, btw.
    I think you will be fine. Maybe you will have to remove the forward front mudflap, and get handy with a heat gun, but I think you will be ok.
  9. Apr 19, 2022 at 6:45 AM
    Bentundra563
    Exchanged the 285 to 275 70 r17 so should be all good now. Thank you everyone for your knowledge appreciate it. I’ll update this thread with ether good news or bad new next week when I get everything installed.
    Clemsonman14 likes this.
  10. Apr 20, 2022 at 6:01 PM
    UtahGuy
    UtahGuy New Member
    Ben
    2021 Tundra SR5 Double Cab
    2.5" Front 1" AAL rear
    I ran 35 offset with rub on that tire size. I like the look and no poke.
