Will a 2006 Tundra rear diff limited slip fit on a 2002 Sequoia 4wd?
Discussion in '1st Gen Tundras (2000-2006)' started by Dannyguo316, Nov 20, 2019.
  1. Nov 20, 2019 at 6:20 PM
    Dannyguo316
    Dannyguo316 [OP] New Member
    Danny
    2nd gen tundra double cab.
    Hello everyone, can any experts on here tell me if a 2006 tundra rear diff limited slip fit on a 2002 sequoia 4wd?
    Much appreciated
  2. Nov 20, 2019 at 6:24 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Do you mean just the diff/ring/pinion with the 3rd member, or the entire axle assembly?
  3. Nov 20, 2019 at 6:25 PM
    Dannyguo316
    Danny
    The entire assembly
  4. Nov 20, 2019 at 6:26 PM
    Dannyguo316
    Danny
    I have a 2002 sequoia. The mechanic just told me the rear diff is bad when I took it ot get the fluid changed. And the axle seal is leaking as wel . So he just told me it's cheaper just to replace the entire assembly
  5. Nov 20, 2019 at 6:27 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Dont you have coils? Replacing the axle seals on your axle will be a heck of a lot cheaper than welding all the pieces you need onto the tundra axle. Swap the 3rd member into yours and replace the seals
    2scars and revtune like this.
  6. Nov 20, 2019 at 6:29 PM
    Dannyguo316
    Danny
    Ok. Thank you.
  7. Nov 20, 2019 at 6:41 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    The 3rd member will fit into your axle housing but the tundra axle housing will not swap in to the Sequoia without lots of fabrication.
  8. Nov 20, 2019 at 9:41 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Plus your Sequoia has rear disc brakes and the Tundra has rear drum brakes. You don't want to down grade your brakes like that.
    KarmaKannon and Dannyguo316[OP] like this.
  9. Nov 21, 2019 at 3:38 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    This.
    And also I want to do this exact swap in reverse. When I regear I want to use a Sequoia axle, cut off the old brackets, and swap it in my tundra. Discs baby!
  10. Nov 21, 2019 at 4:43 AM
    Professional Hand Model
    Hand Protectors
    I wish we were neighbors. I saw a 2003 Tundra with this and it looked awesome. Wish I could have spoken with the owner about it all.
    FrenchToasty likes this.
  11. Nov 21, 2019 at 6:42 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Why not just swap the entire axle shaft/ brake assemblies? Seems easier than swapping the axle housing.
  12. Nov 21, 2019 at 7:40 AM
    KarmaKannon
    Utah
    Some junk
    If the backing plates bolt up the same. The issue really is that I need a complete axle minus the third member more or less anyway and if I have a spare third I can regear without taking my truck down. If the axles are the same then I have spares of those which is nice. Price wise I bet it's the same at a u-pull yard to get a complete axle compared to everything from the axle seal out.
    I wouldn't complain if we were neighbors because it's getting pretty chilly here haha.
  13. Nov 27, 2019 at 3:11 AM
    Chicken Run45
    Chicken Run45 New Member
    Marshville NC
    04 silver streak dcsr5
    None YET
    Guys I've been thinking about the Sequoia rear end in my Tundra also. I know about all the bracket but was wondering if I needed to change out the master cylinder propositioning valve etc... what else would need to be changed. TIA.
  14. Nov 27, 2019 at 3:23 AM
    KarmaKannon
    Utah
    Some junk
    It's probably suggested you change at least the proportioning valve. I was thinking of just ditching the load sensing deal for the rear brakes if I do it and seeing how it feels. I guess it depends how close in size the Sequoia master cylinder is compared to the tundra on whether it will work.
    I was being told my ranger would need a new proportioning valve when I did the rear disc swap on it. That little truck with 4 wheel disc and 35" tires stops amazingly well with the factory prop valve. I also like a little rear brake bias anyway to allow for braking and steering though so I'm a unique case.
  15. Nov 27, 2019 at 6:08 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    I would be surprised if the axles/ backing plates didn't work. But yeah, having the spare 3rd and housing would be good.
    On my Tacoma I cut the rod off and zip tied it up to the lines connected to the LSPV. What this does is essentially tells the prop valve that my rear is weighed down and sends more bias to the back. Great way to get more braking power from the rear without having to change anything. I did recently have to adjust it down because the rear brakes locked up during a hard stop. But my Tacoma is on 40's and stops really well for what it is. I would recommend that before going and changing anything.
    KarmaKannon[QUOTED] likes this.
  16. Dec 9, 2019 at 12:09 AM
    Dannyguo316
    Danny
    Hello, does anyone know where I can pick up a pair of rear brake plate for 2002 sequoia 4wd for a reasonable price? I saw one from toyota. They wanted 700 for 2 pieces of metal. Hardly seem worth the price. Thanks in advance
