Will both of these shocks work with my OEM springs?
Discussion in 'Suspension' started by DiegoC, Jul 10, 2019.
  1. Jul 10, 2019 at 6:21 PM
    DiegoC
    DiegoC [OP] New car smell
    Diego
    2016 White Tundra Limited
    ReadyLift SST 3/1 Level Lift W/ sum 35's
    Both of these shocks should work with the OEM Springs off my 2016 tundra right? I also have a spacer lift. 04D9DC7A-266B-4E0F-AF4C-32E3094FCB6A.jpgB30A05D6-9251-46E5-B1A2-3A57C4C0724A.jpg
  2. Jul 10, 2019 at 6:47 PM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Are you keeping the spacers or replacing them with the shocks? Your stock springs should work with the 5100’s and provide about 2 inches of lift on the top setting. I believe the 4600’s are the factory shocks on the TRD package.
  3. Jul 10, 2019 at 7:11 PM
    DiegoC
    Diego
    I’ll probably keep the spacers because I have a 3 in spacer in front w/35s
  4. Jul 10, 2019 at 7:13 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I'm running the 5100s at the top settings on the stock springs along with 2 shims on each side. With this setup, you would remove the spacers.
  5. Jul 10, 2019 at 7:15 PM
    DiegoC
    Diego
    Would you prefer that? Over what have going on?
  6. Jul 10, 2019 at 7:16 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    I originally had spacers with the stock shocks. It was definitely an upgrade. Any day you can remove spacers is a good day. I'm running 285/65/R20s KO2s (34.6 inch). I get no rubbing and a great ride. I also added a diff-drop in the front although I suppose that might be overkill for a 3" lift.
    For the rear I added 5100s and +3 shackles which gives me a level ride. If you raise the rear you may need to add a carrier bearing drop if you notice any drive-line vibration.
  7. Jul 10, 2019 at 8:28 PM
    DiegoC
    Diego
    So I could run 5100 with a shim in the front with stock springs to fit my 35’s with a minor rub and I currently have a 1 inch block in the back. I could leave that too since it’s minor huh?
  8. Jul 10, 2019 at 8:29 PM
    DiegoC
    Diego
    I don’t off road. But I will be pulling a light weight 22-24 ft trailer
