Will I need to recalibrate TSS after replacing chrome grille surround
Discussion in '3rd Gen Tundras (2022+)' started by 802_Tundra Limited, Oct 29, 2024.
  1. Oct 29, 2024 at 7:48 AM
    802_Tundra Limited
    802_Tundra Limited [OP] New Member
    2023 Tundra Limited HV 4x4
    Chrome delete
    I am working on a chrome delete of my ‘23 Limited HV. My last piece is the grille surround. Yea, I should have bought the snap on overlay. I didn’t, and I’ll pay for it (probably).
    My question is, after replacing the trim will I need to re-calibrate the TSS sensor? How is that done? No applicable YouTube video I’ve seen addresses the issue.
    Perhaps I’m better off having Toyota service do this? In which case I might as well have them update the entire grille with light bars too?!! And for that matter when I lift the truck the TSS sensor will need to be adjusted again, right?
    Thanks.
  2. Oct 29, 2024 at 8:36 AM
    You don't need to calibrate if after swapping out the surround. Just make sure you don't start the truck with the sensor unplugged. Once the lift is done, you won't need to have it calibrated unless you start having issues. I'm not familiar with the 22 and newer TSS, but I did not have any issues when I installed a 4/2 lift on my 2020 with TSS.
    TwiZtedBiker likes this.
  3. Oct 29, 2024 at 8:51 AM
    TwiZtedBiker
    TwiZtedBiker New Member
    2024 limited TRD Off-road
    Redid my entire front clip, new bumper with all the sensors moved, swapped to the smoked grill, had to completely remake a camera mount and the radar pad to see through the new bumper. New shutter unit and cut down the spoiler motor with an adapter & moved it. Everything works, no recalibrating was needed. Battery unplugged and like the last post mentioned DO NOT start it with anything unplugged or the system will freak out.
    Raven67 likes this.
  4. Oct 29, 2024 at 1:06 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    No issues. I had mine apart last weekend for a grille swap, everything works as it should. Cameras, sensors, etc.20241026_102011.jpg
  5. Oct 29, 2024 at 2:50 PM
    802_Tundra Limited
    Chrome delete
    Amazing. How’d it workout with your clips? Any break? I’m nervous of that too.
  6. Oct 29, 2024 at 3:07 PM
    Raven67
    Kentucky
    Not one! Just take your time & it's pretty damn easy.
  7. Nov 12, 2024 at 8:08 PM
    TwiZtedBiker
    Suspect you'll find a snapped clip or two already when tearing it down, some are extremely thin material at critical mount points, seriously disappointed with Toyota and this. That said, it isn't showstopper and you don't have to buy new parts if you have a hot glue gun, not joking about that. Redid several on my rebuild to avoid buying new overpriced plastic and reinforced a few of the weaker spots found. Added an inner screen to protect the radiator and intercoolers too, cleaned a lot of garbage out of all of them and found spots where large debris had hit all 3, truck only had 8,000mi on it.
    1lowlife, Tundrastruck91 and Raven67 like this.
  8. Nov 14, 2024 at 7:42 PM
    ghunter321
    ghunter321 Trail Hunter
    NC
    2022 Blueprint Limited Tundra
    Retrax Pro XR bed cover, UpTop Overland mid truss system with Baja Designs rock lighting X6, GGOffroad rearview camera relocation kit, Pelican cargo BX90 case, Maxtrax recovery traction boards, OEM bed step, OEM dash and door trim/cubby/footwell lighting, Slee Offroad dual wireless Qi phone charger upgrade, CBI covert front bumper with air dam delete module, TRD Pro heritage grille replace with amber OEM marker lights, Diode Dynamics 18" white lightbar kit and OEM marker lighting, Diode Dynamics covert 18" amber lightbar, Rough Country bed mat, Rough Country defender series fender flares, TRD camo tailgate spoiler and OEM marker lights, TRD camo rear bumper arms, Screen Protech for interior surfaces, OEM badge blackout
    Does Toyota offer OEM color matched grille surround pieces? I imagine it would be cheaper than bumpershellz maybe? How would I find the blueprint pieces specifically?
  9. Nov 15, 2024 at 11:52 PM
    TwiZtedBiker
