Will my 2006 tundra access cab (4wd) frame interchange with a frame from a 2006 2wd?
Discussion in '1st Gen Tundras (2000-2006)' started by Nedflanders1220, May 15, 2023.
  1. May 15, 2023 at 3:37 PM
    Nedflanders1220
    Nedflanders1220 [OP] New Member
    Matthew
    2006 Toyota Tundra 4.7 V8 access cab sr5
    I bought an 06 tundra 4wd access cab and I found out the frame was bad. I got a new frame in mint condition for $600 with most of the parts still on it. This truck is the exact same year model, cab configuration, and trim level. The only difference is that the new frame is from a 6 cylinder model. Will they interchange, if so, is it as simple as moving a crossmember and or motor mounts? Or swapping the mounts to my new frame?
  2. May 15, 2023 at 3:41 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Same engine?
    w666 likes this.
  3. May 15, 2023 at 5:23 PM
    N84434 likes this.
  4. May 15, 2023 at 8:01 PM
    Nedflanders1220
    Matthew
    My donor frame is a 2wd 4.0 v6. The truck I am swapping the donor frame to is a 4.7 v8. I have all the parts to swap from my v8 truck, as well as fab knowledge and a full shop with a lift. I’m not scared of a little fab work, but I just need to know what I’m getting myself into lol.
  5. May 15, 2023 at 8:07 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Engine mounts are different on v6. Someone on here has done close to the same thing you are doing. Had to fab up new engine mounts. May do a bit of searching on here. I haven't seen it in a while.
  6. May 15, 2023 at 8:17 PM
    Nedflanders1220
    Matthew
    I’m going to do some more research. I’m hoping I can just make some new motor mounts. Or possibly swap my ones from my v8.
  7. May 16, 2023 at 5:48 AM
