Will Sequoia Running Boards fit my 2006 DoubleCab?
Discussion in '1st Gen Tundras (2000-2006)' started by Trueno, Nov 1, 2023.
  1. Nov 1, 2023 at 12:36 PM
    Trueno
    Trueno [OP] New Member
    Will
    2006 Sr5 Dbl Cab
    Before I drive two hours to pickup these running boards for my 06 DBL, can someone please help me confirm that our trucks have four (4) mounting brackets. These came from a Sequoia.
    389448819_7096577717069375_7067236142044_7917ab981ec7b61f5624ee109d1a0497ae8191d4.jpg
  2. Nov 2, 2023 at 5:21 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Confirmed, they're identical to the OEM set on my 05 DC.
  3. Nov 2, 2023 at 6:21 AM
    @noahrexion is there an intermediary bracket missing in @trueno's pic though?
    My OEM steps (which are slightly diff't for AC trucks) have 2, 3 intermediate brackets. The one OP shows in his pic that act as the "shelf" for the step, then there's 1 or 2 additional brackets which help mount that shelf to the frame.
    The reason I ask, if @trueno gets these and is missing brackets, you can't easily get replacements from Toyota. He may spend months hitting junkyards before he finds the proper brackets.
    I get the sense of those 4 mounts, the oddball one may be a direct-mount, but the other three probably have an intermediate bracket... but you'll know better than anyone, since your truck is assembled. Any chance you can grab pics?
  4. Nov 2, 2023 at 6:34 AM
    noahrexion
    Washington
    2005 4WD DC
    See attached. I'm glad Shifty said something cause now that I look a little closer at the pic OP attached it seems that one of those brackets is a black sheep.
    On my DC ALL 4 are identical, same holes and spacing as 3 of the 4 on the OP's Sequoia pic. They look to be the front mount that is different. If it were me and they were a good price I would move on em if you've been looking for a while. Having 3 of the 4 seems good enough to mount up and then either modify OR fab a new mount for the 4th location if you can't find it from dealer/parts truck.
    In looking at the black sheep it does look to have a similar shape to the others; if you were lucky it could be as easy as drilling a few holes in that one to match the other 3.
  5. Nov 2, 2023 at 6:49 AM
    In your pics, it looks same to me - 4 brackets, 3 same, 1 oddball per side. Your pics show two diff't brackets, and your last pic looks like the oddball bracket, notice the 45° at the tip.
  6. Nov 2, 2023 at 12:37 PM
    Trueno
    Will
    2006 Sr5 Dbl Cab
    Additional pics.
    389002438_5975858952517242_1973007627855_b6731eae7f6a984167b9eecbceb512655435da73.jpg
    389448819_7096577717069375_7067236142044_fcdb0a8f549359f57fba2130c6bd3a1b06f04ece.jpg
    389414977_24057130413931492_846156384468_f297ecbe4726d81d92b454d56ee6fadf8fab0d2c.jpg
    394243983_6685489814833725_5953672028562_130e0ed8587ce045c726534a8ea6c7d9ac24a29d.jpg
  7. Nov 2, 2023 at 7:41 PM
    noahrexion
    Washington
    2005 4WD DC
    Yep, buy em.
  8. Nov 7, 2023 at 1:21 PM
    Trueno
    Will
    2006 Sr5 Dbl Cab
    I picked them but because they install right at the base of the cabin, they are still too high for my short wife and children. I will be selling them and picking up these as they drop 3 or 4 inches
    N-FAB BLACK CAB LENGTH NERF BARS
