Will these wheels fit?
Discussion in 'Wheels & Tires' started by Tundralove2010, Sep 20, 2022.
  1. Sep 20, 2022 at 7:27 AM
    Tundralove2010
    Tundralove2010 [OP] New Member
    2010 Tundra
    4Wd extended cab
    I am about to buy a set of alloy wheels off of a 2018 platinum Tundra and need assurance they’ll fit my 2010 4Wd extended cab Tundra which currently has the original steel wheels on it. 28B88FE6-E7B8-4D58-81A3-E6BEE374E22E.jpg
  2. Sep 20, 2022 at 7:31 AM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    you should be fine. The 5x150 bolt pattern went through gen 2 and gen 2.5. Double check the sticker on your door frame and good luck with the new rims.
  3. Sep 20, 2022 at 7:39 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    yes. beware, your TPMS will not transfer over to these as the steel wheels use a different TPMS than pretty much all the rest of the wheels
  4. Sep 20, 2022 at 7:39 AM
  5. Sep 20, 2022 at 7:42 AM
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    I'll take those TPMS sensors out of the 2018 wheels if your swapping them out!
  6. Sep 17, 2024 at 6:11 PM
    2011Tundra200thousandkm
    2011Tundra200thousandkm New Member
    2011 Tundra 200 thousand km
    Hey folks,
    Looking at a set of 20" rims off a 2020 for my 2011 and after reading the chart from the link Jim Le shared it looks like the bolt pattern is the same but the center bore is different. 110 for the 2011 vs 110.5 for the 2020.
    That mean they won't fit or am I reading this chart wrong?
    Thanks for the help. Such a great forum.
    Cheers.
