Winching an ATV into the bed
Discussion in '2nd Gen Tundras (2007-2013)' started by fixnfly, Jan 18, 2019.
  1. Jan 18, 2019 at 12:56 PM
    fixnfly
    fixnfly [OP] New Member
    08 double cab 5.7
    Anyone have any experience with using an atv winch attached to the front tie down rack to pull a disabled atv up ramps into the bed ? More likely a heavier utility atv. (Grizzly 700)
    Asking for future reference !
    tbrown likes this.
  2. Jan 20, 2019 at 9:44 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You’re going to need a serious mount for the winch to safely do this. Sounds extremely dangerous unless you cut through the bed and the winch is frame mounted somehow
    Sas and NewImprovedRon like this.
  3. Jan 21, 2019 at 1:16 AM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    Get a couple buddies and just push it up. I push my 450r up by myself but it's half the weight of a grizzly.
  4. Jan 21, 2019 at 5:45 AM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Be a man and take a chance. We'll visit you in the hospital. LOL
    Law323 likes this.
  5. Jan 21, 2019 at 5:49 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    My front bed corners and front of the bed are bent/deformed just from securing dirt bikes against it. I wouldn't trust it to pull any sort of weight into the truck. I purchased the Relentless Fab corner braces for the front of the bed just to make sure that the front wall stays there while the bikes are in there.
  6. Jan 21, 2019 at 6:11 AM
    fixnfly
    08 double cab 5.7
    Using the winch on the grizzly, not a bed mounted winch.
  7. Jan 21, 2019 at 6:14 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Get a dirtbike. ;)
    Law323 likes this.
  8. Jan 21, 2019 at 6:16 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    I still wouldn't attach the winch cable to the inside of the bed and winch it in. Same forces are applied to the weak bed.
  9. Jan 21, 2019 at 6:18 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Either bed mounted or Grizzly mounted, I don’t see a safe way of doing this unless you rig something up via the frame.
    Without the frame mount, this seems like a surefire way to get hurt. Why not get a trailer to pull your ATV? This would be a better option, not to mention safer if/when you have to load up a disabled ATV. Degree of loading ramp is less, so it would be less weight to push/winch. Not to mention you can attach (or there already are) a solid anchor point for winches, straps, etc.
    NewImprovedRon likes this.
  10. Jan 21, 2019 at 6:18 AM
    fixnfly
    08 double cab 5.7
    So if the rolling weight of the grizzly is less than the rating of the tie down rack, it should work.
    Sounds like a job for mythbusters
  11. Jan 21, 2019 at 6:24 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The tie down is not meant to have a 600+ lb item being pulled on it up a ramp. No way. It will pull out of the bed and go flying at you.
    Law323 likes this.
  12. Jan 21, 2019 at 6:50 AM
    Grizzly660
    Grizzly660 21 Army Green Sport
    North Dakota
    2021 Army Green Sport
    20 inch XD Hoss wheels with Nitto EXO Grappler Wetokole seat covers
    Back your tundra down into a smaller ditch and push it in, strap it in good and drive out. Otherwise 3 guys can push it in up ramps if it's not running and can't drive it up the ramps. I had a grizzly 660 and did this.
    fixnfly[OP] and Law323 like this.
  13. Jan 21, 2019 at 6:53 AM
    Jengel451
    The Bitterroot, MT
    Serious note.
    The front of the bed/rail is not that strong. Even strapping down a dirtbike makes the rails Flex. I have rack installed just to alleviate the problem. Using the rails etc for an anchor pioint to haul 700 lbs up a ramp is asking for trouble.
    OBXTundra likes this.
  14. Jan 21, 2019 at 6:58 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You can also drive the front wheels up a birm. Ive seen someone do this far enough to drive a razr into their truck
  15. Jan 21, 2019 at 8:40 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Ive had to do this before, but you won’t always have a berm/ditch to make loading easier nor will it always be accessible (water, obstructions, mud, etc)
    Best option is always have a buddy with you or get a trailer. Just my .02
    zcarpenter92 and NewImprovedRon like this.
