Windshield Tint Strip?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by lunarpro29, Oct 31, 2021.
  1. Oct 31, 2021 at 9:39 AM
    lunarpro29
    lunarpro29 [OP] New Member
    2021 Lunar Rock Tundra TRD Pro
    I have a 2021 Tundra TRD Pro CrewMax in Lunar Rock. I got mine tinted at a shop that has done hundreds of tundras. I wanted to get a tint strip at the top of the windshield as I do on all my vehicles but the shop owner says he doesn't recommend doing it on Tundras because the center of the top windshield with the dotted area will look silver with tint behind it, and he says I will hate it because it will look bad and I will go back to him to take it off. He has done the same windshield strip on all my other vehicles and no problem. He said this is specific to Tundras because Toyota designed the windshield poorly. He obviously is being honest because he would rather I pay extra to have him do the strip, and even if I didn't like it he would charge me to remove it as well. Has anyone else done this windshield tint strip and noticed the silver look? Does it bother you? I personally love the look of windshield tint strips in general and the functionality of them. I had them on all my previous vehicles. I haven't seen one on a tundra in person though.
  2. Oct 31, 2021 at 10:48 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Any windshield that has dot matrix on it will look that way, it’s not uncommon. This is my pathfinder that has the silver look that you are talking about. CA85BEE2-0A37-4385-A353-9F6FC94BCD97.jpg
    lunarpro29[OP] likes this.
  3. Oct 31, 2021 at 10:55 AM
    Omohundro
    Jody
    McMinnville TN
    I have sprayed the dots with windshield primer before to avoid the crap tint look. It’s a pain to do with the glass in the truck (has to be sprayed inside the truck) but not really another option that I know of.
  4. Oct 31, 2021 at 12:11 PM
    lunarpro29
    @Omohundro For my other vehicles that have the same dot matrix, I never got a silver look on them. The same tint shop owner never brought it up when tinting that before on other vehicles. He said it is specific to Tundras or Toyotas in general, and said in his experience a lot of people want them removed because they don't like the look of it. He even recommended that if I were to replace my windshield in the future, to replace it with an aftermarket one that doesn't have the same dot matrix Toyota uses, so that a windshield strip would look better
    Did you use that primer on your tundra for the strip? What makes it a pain to do other than having to spray it on the inside? How does the primer affect the look?
  5. Oct 31, 2021 at 12:16 PM
    CorpsTundra
    CorpsTundra New Member
    Michigan
    2021 Tundra CrewMax SR5-TRD OR - Cement
    The “silver” area doesn’t bother me too much, but I don’t like where mine lined up. It is crooked for one, but I think it looks better aligned to the bottom of the silver part, as opposed to the drop down that mine is aligned to.
    I am actually taking it back in and if he can’t cut it higher then I will probably have him remove it altogether.
  6. Oct 31, 2021 at 12:30 PM
    kylers2k
    kylers2k New Member
    KWS
    Troutman, North Carolina
    I have my whole windshield tinted and I think it looks great, silver doesn’t bother me in the slightest. Really never notice it.
  7. Oct 31, 2021 at 5:54 PM
    yonquixote
    yonquixote New Member
    ‘21 TRD Pro CM Lunar Rock
    No. If the shop uses the right type of vinyl (sometimes gloss) the dot matrix will disappear in the vinyl. Once mine dried, you can’t see it.
  8. Oct 31, 2021 at 8:08 PM
    Omohundro
    Jody
    McMinnville TN
    It’s just a pain because you have to tape everything up inside the truck, when you spray the primer it essentially covers the dots where you can not see them from the outside of the truck. We use to have to do it Corvette’s a lot.
  9. Oct 31, 2021 at 8:13 PM
    Omohundro
    Jody
    McMinnville TN
    I hate the eyebrow look of the top strip, I did my whole windshield on the tundra and called it a day.
  10. Oct 31, 2021 at 8:16 PM
    lunarpro29
    I assume you did the primer on the dot matrix for your tundra before tinting the whole windshield?
  11. Oct 31, 2021 at 9:55 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I have a huge eyebrow on my truck. I love it, couldn’t have a vehicle without it. Dont even need sunglasses
  12. Nov 1, 2021 at 10:24 AM
    Omohundro
    Jody
    McMinnville TN
    No I didn’t, should have but I’m lazy.
  13. Nov 1, 2021 at 10:31 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    I dunno, I have my whole windshield done and love it - never noticed any issues with the dot matrix. Sounds like your tint guy had a couple of people complain and doesn't want to deal with it again.
  14. Nov 1, 2021 at 10:53 AM
    808Tunderer
    808Tunderer New Member
    2021 DubCab SR5 4x4 TRD Offroad
    Stock
    Went and got 3M crystalline tint this past Friday. They put a 5% tint strip on my windshield and never mentioned anything about dot matrix. Will have to take a closer look in a few minutes as I haven't noticed anything looking unusual when looking at it from the front.
