Windshield wiper linkage/motor question
Discussion in '1st Gen Tundras (2000-2006)' started by Splashbrother13, Jun 29, 2021.
  1. Jun 29, 2021 at 2:13 PM
    Splashbrother13
    Splashbrother13 [OP] New Member
    Aaron
    AZ native
    2000 SR5 Tundra
    Just replaced the wiper transmission + purchased a new motor
    not quite sure how to fasten the motor to the linkage piece or what tool i might need.
    I tried muscling it on there w/o any luck
    not really much clearance room b/w linkage piece
    Thanks
  2. Jun 30, 2021 at 8:17 AM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Use the nut to pull it on, but measure the motor swing so you can clock the arm where it needs to be.
    KNABORES likes this.
  3. Jun 30, 2021 at 11:50 AM
    Replaced the linkage on mine. I plugged the motor in and let it cycle once to get it to the starting position. Then lined the linkage up in the resting position and attached to the motor using the nut to "press" the arm on. The new linkage has a slightly longer throw, so the blades rest too low and sweep too long.
    Splashbrother13[OP] likes this.
  4. Jun 30, 2021 at 1:04 PM
    Splashbrother13
    Aaron
    AZ native
    2000 SR5 Tundra
    Having difficulty with ‘press’ part
  5. Jun 30, 2021 at 1:18 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Not enough threads to start the nut? Are there ‘teeth’ or splines on the ID of the linkage?
  6. Jun 30, 2021 at 1:22 PM
    Describe the difficulty. I put the arm against the motor output shaft and lined the splines up, put the nut on the threads and cranked that puppy down.
  7. Jun 30, 2021 at 2:12 PM
    Splashbrother13
    Aaron
    AZ native
    2000 SR5 Tundra
    There’s splines/teeth on each and they line up (don’t think incorrect fitting is the issue)
    After getting nut lined up with linkage arm, I don’t have the clearance space I need on the opposite side of the linkage arm for the shaft to get through with the pressure I’m applying pressing the motor toward the arm
    Feel like I need a binding tool, but there isn’t enough space for a c-clamp to get from motor to arm on opposite sides.
