windshield wiper pump not spraying
Discussion in '2.5 Gen Tundras (2014-2021)' started by tjacob95, Oct 14, 2024.
  1. Oct 14, 2024 at 12:27 PM
    tjacob95
    tjacob95 [OP] New Member
    2014 toyota tundra limited
    before I pull my dash apart I'm wondering anyone may know the answer to this, a while back i was under the dash disconnecting something the previous owner wired up, flash forward my windshield wiper sprayer isn't spraying is it possible that i unplugged it while under there or does it just work off the wipers automatically? my wipers move but the pump doesn't spray the fluid before I order a new pump I want to make sure it isn't something unplugged any help is appreciated thanks
  2. Oct 14, 2024 at 1:34 PM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    I'm not 100% sure, but I think there might be a seperate fuse for the washer pump. One might say wiper/washer and another just washer. Check the washer one. If that doesn't work, then yeah, check for something unplugged or loose wiring since that was the last thing your were messing with. Also, if the previous owner did "extra" wiring work, check all that wiring for inline fuses even if you don't think it is associated with the washer motor. When folks start messing with wiring, all bets are off.
  3. Oct 14, 2024 at 1:37 PM
    AZBoatHauler
    So.Arizona
    Also worth a look to make sure the hose is intact. A thirty mouse chewed through mine before along the passenger side between the reservoir and the windshield.
  4. Oct 14, 2024 at 1:44 PM
    tjacob95
    10/4 ill try that
  5. Oct 14, 2024 at 5:05 PM
    Tundra1988
    Tundra1988 New Member
    Cody
    17 Trd Pro White CrewMax
    295/70/18 Tires
    Also not sure but recently had to hunt down on my wife’s 4runner why it wasn’t spraying. We put rain x green fluid in it and was too thick and gummed up a CHECK VALVE in the fluid lines under the hood insulation. If you hear the pump running and nothing coming out it could be clogged or the jet itself is clogged at windshield. All things you would t think to check but lesson learned. FYI the Toyota check valve is expensive, I bought pack of 3 from Amazon for 1/3 of Toyota price. Just something else to check if tundras have a check valve in wiper fluid lines.
  6. Oct 14, 2024 at 5:07 PM
    tjacob95
    can you send a link for reference... im not sure what the check valve is
  7. Oct 14, 2024 at 5:22 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    This may or may not help.
    There is a WSH fuse.
    Fuse is under the hood.
    Unit B.
  8. Oct 14, 2024 at 6:08 PM
    Tundra1988
    Cody
    295/70/18 Tires
  9. Oct 14, 2024 at 6:22 PM
    tjacob95
    thanks buddy I'll try that I wonder if I can spray it out with some air..
  10. Oct 14, 2024 at 6:53 PM
    Tundra1988
    Cody
    295/70/18 Tires
    Man I went down that road and tried everything, even running vinegar through it and such to no avail. The passages are small and gunks up easy, at least mine did. Amazon ones worked great so far and have spares.
    Good luck Brother!
  11. Oct 14, 2024 at 7:03 PM
    tjacob95
    well we will see in a few what it could be possibly
  12. Oct 15, 2024 at 9:37 AM
    tjacob95
    Idk how to post a pic but it ended up beinga a rodent chewed the tube… anyone onow where i could get a new tube?
    ejes likes this.
  13. Oct 15, 2024 at 9:40 AM
    AZBoatHauler
    So.Arizona
    I picked up some barbed unions and cut out the bad section. Good to go.
    HulkSmurf14 and TaquitoBandito like this.
  14. Oct 15, 2024 at 8:11 PM
    tjacob95
    5 bucks at a parts store and we are back to the way it should be! My next project is learning to find out how to wire lights and stuff lol im new to this stuff this forum has got me wanting to do so many mods to my truck now
    AZBoatHauler and Joe333x like this.
  15. Oct 17, 2024 at 8:46 AM
    trails-end
    trails-end New Member
    NWGA
    2021 Tundra SR5 4x4 crewmax trail white
    TRD antisway bars front and rear.
    That's a $200 fix at the dealer. I had that happen in the spring.
    AZBoatHauler[QUOTED] likes this.
  16. Oct 17, 2024 at 12:02 PM
    tjacob95
    shouldve fixed it yourself it was fairly simple just ran a new line where they chewed
  17. Oct 17, 2024 at 12:05 PM
    AZBoatHauler
    So.Arizona
    My guess is he didn’t know what exactly the problem was until after. Maybe I interpreted it wrong…
  18. Oct 17, 2024 at 12:07 PM
    tjacob95
    I will say this i can change an alternator and small stuff like that but one thing I've learned as I've gotten older, sometimes its just easier to take it to the mechanic and save yourself some headaches Lol
  19. Oct 17, 2024 at 12:13 PM
    AZBoatHauler
    So.Arizona
    The alternator on the Tundra is a real pain in the ass!!
  20. Oct 17, 2024 at 12:16 PM
    tjacob95
    lol believe me I know lol my buddy changed his and he's a die-hard diy guy, but he probably won't attempt that again.
