Wiper arms
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jpilot, Feb 2, 2025.
  1. Feb 2, 2025 at 6:41 PM
    Jpilot
    Jpilot [OP] New Member
    joe
    1261 doric dr
    None Yet
    I am not a fan of the wiper arms and how you cannot put regular blades on there. Anyone changed out the arms for a standard J hook set?
  2. Feb 3, 2025 at 6:09 AM
    gunpup
    gunpup New Member
    Nate
    WA
    2018 SR5 DC
    FWIW the bosh icons come with everything you need for the right attachment.
    panicman and agrestic1 like this.
  3. Feb 3, 2025 at 7:07 AM
    seydou
    seydou Distinguished Member
    WTF are "regular" blades?
  4. Feb 3, 2025 at 3:02 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Get the Bosch Icons, usually on sale some where, and easy install..zero adapters..
  5. Feb 3, 2025 at 3:16 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I would advocate for using the Mama Toyota blades. OEM. NOT Sighlines. About $20 a blade. Snap out old factory type of blade (I'm assuming that's what you have) and snap in the new one. If you get bound up it might then take 75 seconds to change out. I get between 4 and 5 years out of a set of these OEM blades.
    AZTundra and panicman like this.
  6. Feb 3, 2025 at 5:16 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I'd dare guess he is referring to a standard hook style.
    It is what has been on every vehicle I've owned until I bought a Tundra.
    Rdrcr and panicman like this.
  7. Feb 3, 2025 at 6:13 PM
    +1 on these. I just replaced mine yesterday with these.
  8. Feb 3, 2025 at 7:34 PM
    jmanscotch
    jmanscotch New Member
    Jake
    2020 Tundra TRD OR CM
    They are annoying and I share your thoughts.
    If no one has a specific suggestion for what your seeking, I’d suggest measuring the lengths of the arms, the diameter and tooth count of the wiper base mount and going to a junk yard or something and seeing what older Tundras/Sequoias or similar size windshield Toyota vehicles might have.
    Rdrcr likes this.
  9. Feb 7, 2025 at 7:30 PM
    Jpilot
    joe
    1261 doric dr
    None Yet
    Thanks. By Regular, I mean, go to the store and pick up a set of silicon blades. Attachment does not require some special order adapter to put the blade on. A regular J hook is standard on 90% of cars. I got some silicon blades from Walmart and even with the adapter pack in the package, that adapts to probably 7 different styles, I could not get them onto this truck. Why so different?
  10. Feb 7, 2025 at 7:39 PM
    AZTundra
    Paul
    Phoenix, AZ
    I use OEM as well. I’m only on my 2nd set after 7.5 years and 98K miles. They outlast everything else out there.
    Jpilot[OP] likes this.
  11. Feb 8, 2025 at 7:45 PM
    eagleguy
    eagleguy New Member
    Lets keep in mind there are 2, not 1 OEM items available. One is a good 20-30 bucks less (Sightline) and is Ebay quality
  12. Feb 9, 2025 at 10:46 AM
    jmanscotch
    Jake
    The problem is these are only listed to fit up to 2018/2019 Tundras.
    Does anyone know what changed for the 2020/2021 wipers?
