Wipers wont go to the bottom of windshield when turned off
Discussion in '2.5 Gen Tundras (2014-2021)' started by security, Dec 25, 2020.
  1. Dec 25, 2020 at 5:02 AM
    security
    security [OP] New Member
    paul
    2014 Toyota Tundra
    4x4
    have a question i replaced my wiper arm controls now my wiper wont go to the bottom of windshield when shut off
    YardBird likes this.
  2. Dec 25, 2020 at 5:32 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    You replaced your "wiper arm controls", meaning you replaced the switch stalk on the steering column?
    According to Repair Manual, wiper arm "parked position" is determined by the wiper motor, not the column switch. What problem were you fixing when you replaced the wiper arm controls?
    Do your wiper arms stop immediately when you turn off the switch?...Or, do they continue moving to an abnormal parked position?
    Welcome from the Texas Hill Country.
  3. Dec 25, 2020 at 6:14 AM
    Shark Bait
    Shark Bait Not new anymore
    David
    2019 Platinum
    If you replaced the external arm that the wiper blade is attached to did you put them back on in the same “clocked” position from which the old ones were removed?
    NewImprovedRon and Black Wolf like this.
  4. Dec 25, 2020 at 7:22 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  5. Dec 25, 2020 at 7:25 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Just pull the arms off and replace in a lower position
  6. Dec 26, 2020 at 7:33 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  7. Dec 26, 2020 at 7:50 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  8. Dec 26, 2020 at 9:02 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome from Ontario Canada . I agree with Stumpjumper , just pull the arms and put them back on at a lower position .
  9. Dec 27, 2020 at 7:45 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA.
  10. Dec 27, 2020 at 7:50 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  11. Dec 27, 2020 at 8:09 PM
    Welcome from NY.
  12. Jan 4, 2021 at 12:27 PM
    jna
    jna New Member
    2016 Limited
    I had a recent issue with the wind shield wipers not shutting off. I had a small amount of snow that apparently created some ice that caused the wipers to stick to the glass.
    I hit the washer switch and got washer fluid but could tell the wipers were frozen, ok no problem just clean with broom. As I drove for about 2 miles I kept hearing a noise that repeated a few times I thought I had left the wiper switch on but no it was off. After a few minutes suddenly I heard a louder noise and the wipers did a sweep the passenger blade was fine, the drivers blade was still frozen so it broke free from the arm. I only hit the washer button and made sure the switch was off but now realize the noise I heard was the wipers trying to sweep for at least 2-3 minutes. Anyone else have this happen? None of my other vehicles wipers work like this.
    Truck is 2016 Limited.
