Wireless Carplay Connectivity Issues
Discussion in 'Audio & Video' started by Cemented-, Oct 29, 2024.
  1. Oct 29, 2024 at 1:23 PM
    Cemented-
    Cemented- [OP] New Member
    Been having issues connecting my phone every so often. Usually happens when I start my truck in front of my house it won't connect then I will get a message Wifi Connection Interrupted. Even if I retry the connection it will try for a minute then keep failing. I figured it was because my phone is still connected to my home wifi, but it will also happen sometimes just starting my truck from wherever. Kind of annoying I sometimes have to restart my truck to get it to work, but when it is connected it works perfectly fine.
    Thought about maybe getting one of those boxes but don't really wanna spend $150-200 just to use carplay.
  2. Oct 29, 2024 at 1:34 PM
    msubullyfan
    msubullyfan New Member
    Robert
    2024 Tundra i-FORCE MAX 1794 Edition
    Same. Haven’t found a solution yet. Generally, I have had luck turning the phone to airplane mode and then reconnecting. If you take the time to do it, mine has connected successfully after rebooting my iPhone 100% of the time.
  3. Oct 29, 2024 at 3:25 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    My CarPlay connects within seconds of starting my truck, both wirelessly or hooked up to the USB port. It's actually been one of my favorite features of my Gen3.
  4. Oct 29, 2024 at 5:38 PM
    Sunstealer
    Sunstealer New Member
    2024 Platinum TRD HV Celestial Silver
    Hold the volume button in for a few seconds to just restart the stereo components.
  5. Oct 29, 2024 at 7:40 PM
    Linesman
    Linesman New Member
    David
    2023 Smoke Mesquite Tundra Double Cab limited
    When I lose connectivity, if it doesn’t connect by itself, I go to the truck settings and choose Bluetooth and Devices, I choose my iPhone and then it gives you three choices. I choose the one that says CarPlay
  6. Oct 30, 2024 at 4:02 AM
    JerseyGeorge
    JerseyGeorge New Member
    2024 Platinum
    If your iPhone has been restarted, but you have not "logged" back into phone with code, it will not connect to CarPlay until you unlock phone. After that it will connect fine.
  7. Oct 31, 2024 at 11:58 AM
    Cemented-
    I do that too, but it still fails.
