Wiring new winch
Discussion in '2.5 Gen Tundras (2014-2021)' started by J's 4x4, Jun 10, 2024.
  1. Jun 10, 2024 at 9:46 AM
    J's 4x4
    J's 4x4 [OP] New Member
    Juan
    Los Angeles County
    2020 Tundra Cement Grey TRD 4x4
    King lift,Leather seats,3m film wrap around,35's KO2 on FUEL Wheels,Line-X, backflip,Bam 10" exhaust with Toyota Black Chrome Exhaust tip,Amp research step,K&N air Filter,TRD air flow Accelerator
    Hey guy's quick question. 1st time owning a winch and wanted to know should I install a fuse block or just connect directly to the battery? Any info helps. Thanks
  2. Jun 10, 2024 at 9:52 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    J's 4x4[OP] likes this.
  3. Jun 10, 2024 at 9:56 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Not necessarily needed, but not a bad idea. The one @vtl listed is more cost friendly or you could go for a blue sea 7713 which allows for switching in the cab but also offers a manual override if things get outta hand
    J's 4x4[OP] and FrenchToasty like this.
  4. Jun 10, 2024 at 10:24 AM
    J's 4x4
    Juan
    Los Angeles County
    Appreciate the info guys. Thanks
  5. Jun 10, 2024 at 10:34 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Use corrugated wire loom, especially on the red cable. Zip tie them along the way, so the cables don't shake, rub against parts of the truck and finally grind through isolation.
  6. Jun 10, 2024 at 1:29 PM
    J's 4x4
    Juan
    Los Angeles County
    @vtl I like your thinking. I loomed the power and ground cable already. Just left these guys exposed since nothing is rubbing on them.
  7. Jun 10, 2024 at 1:40 PM
    AZBoatHauler
    So.Arizona
    I’m a caveman and just hooked it to the battery. Going on a year and a half with no issues.
    J's 4x4[OP] and Mater like this.
  8. Jun 10, 2024 at 1:43 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I did similar but I have a relay with a switch in there.
