Wrench appears on dash all of a sudden
Discussion in '3rd Gen Tundras (2022+)' started by Tideisrolling, Jan 1, 2025.
  1. Jan 1, 2025 at 10:26 PM
    Tideisrolling
    Tideisrolling [OP] New Member
    2025 Limited Non-hynrid, 2100 miles
    got a white wrench in the dash where the odo typically appears. Never seen it before. Guessing that's the countdown till my oil change?
    It won't go away, just stays up there for some reason now.
    Did a break in oil change at 875 so not sure why that's there and showing 7800 or so. Guessing dealer didn't reset oil level when changing it.
    Thanks for feedback. Just new to me.
  2. Jan 1, 2025 at 10:41 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Press the ODO Trip button. Does it change?
    Metro14536 and Tideisrolling[OP] like this.
  3. Jan 1, 2025 at 10:48 PM
    Tideisrolling
    Will check first thing in am. I could have easily hit that. Thanks!
  4. Jan 1, 2025 at 11:11 PM
    Observer
    Observer New Member
    It's a general maintenance reminder, not necessarily a critical warning about a specific problem. It can be reset but read up on it before you do. As I do oil change earlier the the 10,000 mark i typically reset mine. However, I do recall reading that there is one of them you can reset other then the oil change that you might not want to. so do a little reading and search before you make the changes.
    BoulderGT3 and Tideisrolling[OP] like this.
  5. Jan 1, 2025 at 11:12 PM
    Tideisrolling
  6. Jan 2, 2025 at 3:57 AM
    Rockpig
    Rockpig You did what?
    08 Limited
    Yes, it's the countdown to the first oil change as stated by another. I must have hit the button by accident and thought, I didn't drive that far, did someone use my truck? Then I realized it wasn't on the regular odometer setting and it was on the maintenance countdown.
  7. Jan 2, 2025 at 8:18 AM
    Tideisrolling
    Haha, I did the same. Saw the miles and was like, what the hell?!
    Rockpig[QUOTED] likes this.
  8. Jan 2, 2025 at 8:43 AM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Read Owners Manual please. You’ll be amazed what your truck can do
    Pine_Cone67, kirkb, Raven67 and 2 others like this.
  9. Jan 2, 2025 at 2:33 PM
    Tideisrolling
    Thanks, i did check the manual. Nothing in there under "wrench". Could have been under odometer potentially.
  10. Jan 2, 2025 at 3:30 PM
    JDAZ
    JDAZ New Member
    One is a general maintenance reminder with a 5k countdown probably for tire rotation the other is for a 10k countdown that is called oil change. They are located in the center cluster. Move the cursor on them press AND HOLD FOR 3 seconds I use the 5k one for the oil reminder
    Toyota_Ed likes this.
