X-Start or 12volt solutions
Discussion in '2nd Gen Tundras (2007-2013)' started by jjainseattle, Nov 28, 2024.
  1. Nov 28, 2024 at 4:12 PM
    jjainseattle
    jjainseattle [OP] New Member
    2008 Tundra Limited
    I have a 2008 limited that does not appear to have remote start (or if it does I can’t get it figured out)
    looking at both the xstart and the 12 volt solutions products for remote start and wanted to see what folks have done, how they are working over time and what you all recommend.
    Thanks in advance for any replies.
  2. Nov 28, 2024 at 4:16 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    I have the 12voltsolutions (with cellular and app) for 3.5 years and it still works great. I love being able to locate, start, and lock or unlock with my phone. Install was easy, maybe 45 minutes.
  3. Nov 28, 2024 at 4:30 PM
    Kurt1011
    Kurt1011 New Member
    Kurt
    2013 rock warrior
    I have installed 3 12voltsolutions over the years, including one in my '13 rock warrior. Always easy install and works perfectly. I don't have the app, just the regular that works with the key fob (lock button 3 times). the company is great, if you want special features (like extending the run time) just call them and they can modify the programming for you.
  4. Nov 28, 2024 at 4:31 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I have had 12v in 3 cars since 2018, all were easy to install and the cellular app is great. Highly recommended.
    Here’s the interface.
  5. Nov 28, 2024 at 4:41 PM
    tacomawv
    tacomawv New Member
    Richard
    I have had several from 12 volt. Never a problem . My wife is getting one for Christmas for her new to her IS 350.
  6. Nov 28, 2024 at 4:56 PM
    jjainseattle
    2008 Tundra Limited
    Has anyone had an opportunity to try the X-Start
    Vahret832 likes this.
  7. Nov 28, 2024 at 9:47 PM
    Vahret832
    Vahret832 New Member
    Rick
    X-Start works great. Instructions are straight forward and is plug and play. Wiring is nice and has the protective covering. Just use factory lock x3 to start and x3 again to top. It has automatic shutoff after 15 mins.
    07 Tundie likes this.
  8. Dec 4, 2024 at 4:39 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    I installed an X-Start 3 years ago. Super easy install and works great
  9. Dec 4, 2024 at 5:45 AM
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    I put an x start in my wife's 4runner for the price and ease of install i would do it again. I had not seen the 12 volt start kit but if the wiring harness is plug and play and the cost is similar I would prolly go with that one for the app start.
  10. Dec 4, 2024 at 11:28 AM
    Bullshawrk
    Bullshawrk New Member
    how much do u pay per month for the app?
  11. Dec 4, 2024 at 11:57 AM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    Listed in my build thread
    I put a 12V solutions remote start into my 2008 Tundra. It (at least for our year) has a pit stop mode for quick stops when you want to leave the truck running. The remote key FOB range on my Tundra was very short which limited the usefulness or remote start. I considered buying the long distance FOBs or the cellular module from 12V, but went the cheap route and added a length of wire to the receiver antenna and ran it up around the rear window. I now get >70 yards with the stock key FOB.
    07 Tundie and jtwags like this.
  12. Dec 11, 2024 at 10:10 PM
    quikz
    quikz New Member
    2012 5.7 DC 4x4
    TRD Intake 'Accelerator'
    Do you have to plug it into the OBD port full time? If you do, what happens when you unplug it to read a code etc?
  13. Dec 11, 2024 at 10:16 PM
    jjainseattle
    2008 Tundra Limited
    Just pulled the trigger on the 12 volt. Holding off on the accessories and may add later if the distance is an issue.
    Will certainly try the extra wire as well. Thanks all
  14. Dec 12, 2024 at 11:19 AM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    Going by memory, the 12Vsolutions plugs into your OBDII cable, but has another plug to replace the OEM OBDII cable/plug that plugged into the module. In other words, you will have your OBDII port open for using code scanners.
  15. Dec 12, 2024 at 2:08 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Ok, where is your writeup for this mod? :) This would be a great mod for anyone. Just had my stock alarm go off across football field and had to walk a bit before my key fob worked.
  16. Dec 12, 2024 at 2:10 PM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    Here it is. https://youtu.be/8DUjbqny26Q?si=btiXXhJJwMCmaeXC
    07 Tundie and jtwags[QUOTED] like this.
  17. Dec 12, 2024 at 2:11 PM
    Bullshawrk
    if you put the key under your chin your head becomes antenna too. No joke it works
    COTundie and jtwags[QUOTED] like this.
  18. Dec 12, 2024 at 2:17 PM
    jtwags
    League City, TX
    2018 Tundra CM
  19. Mar 18, 2025 at 12:54 PM
    Oystercopy
    Oystercopy New Member
    I installed a 12V solutions system in my 16 Tundra about 4.5 years ago. I just had to remove it today because it caused the AM2 fuse to continuously blow and the truck was dead. Nothing online tells you about this fault or why. All I could think to do was remove the system, because its directly connected to the ignition system and the AM2 fuse is all about ignition. VERY frustrating. Could not get the company on the phone at all to help troubleshoot.
  20. Mar 24, 2025 at 4:38 PM
    FFR1910
    FFR1910 New Member
    If this mod doesn’t have its own sticky it needs one! 30min and the perfect addition to a remote start addition. Do it, did mine yesterday afternoon. Bill
