2016 Tundra Pro engine replacement??
Discussion in '2.5 Gen Tundras (2014-2021)' started by stroutman81, Mar 27, 2024.
  1. Mar 27, 2024 at 8:48 PM
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    2021 Tundra Superpro
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Flowmaster outlaw cat back exhaust Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger (couple weeks out)
    correct it is built up with pressure but the pressure isn’t the issue it’s the clip itself. Even if the pressure wasn’t present that clip would still be locked and that noise would still be there. Pressure or not the clips stuck the noise is still going to be happening because of that small play between the tensioner and the chain. Only way to fix it is to replace the tensioner not the oil or the pressure.
  2. Mar 27, 2024 at 8:49 PM
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    Have a great night!
  3. Mar 27, 2024 at 8:56 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    When I worked for Mazda many years ago we had these Turds called MPV's. They would all come in around the 60k mark with very loud lifters, and before warranty replacement was approved we were told to drain two quarts from the engine and add two quarts of trans. fluid and then run it for a half an hour. (old school). After that we did two oil changes after running it in a bit, then shipped them off. I don't ever remember any of them coming back when I worked there. This might not work with our rigs, but I would definitely try this first on my own truck before tearing everything apart if I was in this situation.
    Ctaylor76 likes this.
  4. Mar 27, 2024 at 9:13 PM
    Ctaylor76
    Chaz
    yeah I mean I would definitely try it, that hole that goes to the tensioner is so small I honestly doubt it would change the outcome but at this point it’s definitely worth a couple hundred dollars rather then thousands ‍♂️
  5. Mar 27, 2024 at 9:32 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Newer trucks being 3rd gen’s?
  6. Mar 27, 2024 at 9:34 PM
    Ctaylor76
    Chaz
    not sure probably anything 2019+ at least but who knows. My truck might even have a hydraulic tensioner, I looked up the part but it doesn’t say if it has a spring in it or not.
  7. Mar 28, 2024 at 12:21 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    All the exact same. Parts haven’t changed.
  8. Mar 28, 2024 at 12:23 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Question still remains… people complain about the noise but have any engines actually failed? Have any skipped time? Don’t want to pay the money, just keep driving the truck. You’d think if something was actually destroying itself you’ll see shavings in the filter and pan.
  9. Mar 28, 2024 at 7:32 AM
    stroutman81
    stroutman81 [OP] New Member
    2016 Tundra Pro
    FWIW, this sounds exactly like what's going on here.
  10. Mar 28, 2024 at 9:39 AM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    It is funny. I took it to a Jeep dealer after I threw money at 2 cams, rocker arms and lash adjusters because that is an incredible common thing to happen in the Jeep and sounds the same. The dealer said….needs rocker arms. So I said, nope. They are brand new OEM. They said, our guy has been doing only this for 10 years. He knows what it needs. So I told them, he opens it up and finds bad ones then I will happily pay you for fixing it. If he opens it and finds nothing then it is on you and I’m not paying so just how much faith do you have in your guy?
    they crack it open and call me. They say, your motor is bad. Has a wiped bearing on the crank. Really??? I asked, and how do you know that? He said, I had one in here last week and that was what it was. Now, I have never heard a piston rod knock at low rpm and stop with higher rpm. I called BS and asked him in front of his boss and about 4 other mechanics….if this was your jeep would you replace the motor. Imagine the stutters and crawfishing for a few minutes. When he was finally able to talk I told them the lack of immediate response told me all I needed to know. Took the keys and departed. That was 10,000 miles ago. Still ticking. No worse no better. That jeep will tick till it dies or gives me an idea what is wrong. Then I will be in your shoes deciding what to do.
    Matala likes this.
  11. Mar 28, 2024 at 2:15 PM
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    I agree sometimes when cold on start up leaving on idle I’ll here a louder slapping kind of clack clack. But it’s only happened to me 3 times in all my years owning the truck. I then drive it and it went away.
  12. Apr 14, 2024 at 6:40 PM
    HexWorks
    HexWorks New Member
    2020 Tundra Platinum
