Blown fuse from led cabin lights
Discussion in 'Lighting' started by Spolar, Sep 29, 2016.
  1. Sep 29, 2016 at 7:59 PM
    Spolar
    Spolar [OP] Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Installing my cabin leds, didn't bother to disconnect the fuse for the lights, and boom, I go dark after switching a few bulbs.
    I'm looking at the fuse box and I have no idea which fuse is for the interior lights on a 2016. There is no more "dome" fuse. I read somewhere it was the pwr outlet fuse, but I pulled that and it was fine. I even went through and pulled every other fuse that could possibly have the lights associated with them and they were all fine. I'm at a loss and super annoyed.
    Is there something else I could have messed up?
    Asalinas4 likes this.
  2. Sep 29, 2016 at 11:40 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Fuse box under hood?
    Asalinas4 and NewImprovedRon like this.
  3. Sep 30, 2016 at 1:43 PM
    Spolar
    Zac
    Seal Beach CA
    2016 sr5
    Thank you!
    Asalinas4 and SouthBoundSteve like this.
  4. Feb 25, 2017 at 6:02 PM
    3RsDad
    3RsDad New Member
    Roger
    17 Tundra TRD OR
    I agree about the aggravation, and may have not done my due diligence, electronic issues are APITA!. If I can see it ,I can fif it ! Thank you all for getting us off the ledge
  5. Feb 26, 2017 at 5:06 PM
    3RsDad
    3RsDad New Member
    Roger
    17 Tundra TRD OR
    Okay, day 2 of on and off trying to fix my interior bulbs. I replaced all of them with led's with no problem until I went to put in the vanity festoons. Lights out. I have done the work in my manuals and csuvipers replies, and others on this site. Have looked in the cabin fuse box at all power 15 amp fuses and none are blown. I guess the next step is under the hood? Thanks for any advice
  6. Feb 26, 2017 at 5:27 PM
    3RsDad
    3RsDad New Member
    Roger
    17 Tundra TRD OR
    Ok, while I've got my heels dug in. All of these F'n manuals for our beautiful babies and no detailed diagram of fuse box? Most of us don't need to go to the stealership for a easy fix
  7. Feb 26, 2017 at 6:08 PM
    3RsDad
    3RsDad New Member
    Roger
    17 Tundra TRD OR
    Well I guess I screwed that up too! I'll try the the way the thread says. I'm sure I saw that different somewhere else:hattip:
  8. Feb 27, 2017 at 4:04 AM
    3RsDad
    3RsDad New Member
    Roger
    17 Tundra TRD OR
    Thanks Steve, I'm not sure why I had it in my mind to do the 15A in the cabin. Guess my ADD,look balloons
    joonbug likes this.
  9. Feb 27, 2017 at 8:25 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    Did you ever figure out what was wrong?
    IndianaGeologist likes this.
  10. Feb 27, 2017 at 4:17 PM
    Sixpack
    Sixpack New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    Steve is right, it's a 7.5 amp fuse in the fuse box under the hood.
  11. Feb 27, 2017 at 4:57 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Holy crap Steve. I thought I kept my engine bay fairly clean. I could eat a sandwich off your fuse box or battery. Nice job on that for a 2015...:thumbsup:
  12. May 16, 2018 at 10:19 AM
    Asalinas4
    Asalinas4 New Member
    Adriel
    2014 Toyota Tundra 1794 edition
    I was about to take it to the dealer but thanks to this thread i solved the issue.
    SouthBoundSteve likes this.
  13. May 16, 2018 at 3:47 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I blew my fuse when I replaced mine too. Again it blew again today. I ended up needing to take the reflective shields out of the light fixtures and filing the opening for the bulbs out to make them bigger. The LED bulbs were longer and a little wider than the stock bulbs. It fixed my issue.
  14. Oct 7, 2018 at 1:08 AM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    I need some help! Does anyone know where the fuse is for the vanity mirror light? They won’t turn on.
  15. Jan 14, 2019 at 6:58 PM
    Edwardrdo
    Edwardrdo New Member
    Edward
    2018 Toyota Tundra TRD
    Funny thing I have a 2018 Toyota Tundra TRD read all the posts regarding replacing the 7.5 amp fuse I swapped them out and interior lights still don’t come on. Very frustrating, I guess I’ll have to go to the dealership and ask at the parts dept about what to do. If any one knows anything it would greatly be appreciated.
  16. Jul 18, 2019 at 11:02 AM
    Harlan_2nd Gen
    Harlan_2nd Gen New Member
    2007 XSP Double Cab
    Bed cover LED Low Beam, High Beam
    Did you find anything?
  17. Aug 23, 2019 at 9:48 PM
    Chevyjlewis
    Chevyjlewis New Member
    Missouri
    2019 Barcelona Red Tundra sr5 trd offroad
    I am having this same problem
  18. Dec 7, 2019 at 10:18 PM
    b99g51
    b99g51 New Member
    Alex
    2016 Tundra
    Toyota has the proprietary OEM parts recommendations and no aftermarket LED lights or bulbs are allowed to install on Toyota cars/trucks. Even if you replace the fuse and install a higher power of resistance fuse, you are still going to have a major problem down the road. In most cases, you will experience a starting problems out of nowhere. What end up happening is the immobilizer stops communicating with the UCM unit, which prevents it from starting the engine. The real problem with this is that it doesn’t happen consistently, but rather intermittently. You might see this once a year or once in a few months. The computer is assuming that the LED lights are drawing excessive amount of power, while in reality LED bulbs/lights draw much lesser power than regular factory lights. This confusion in the system causes the miscommunication between the immobilizer and the main computer, which prevents it from starting the engine.
    even if you trick it by resistors, although the lights will work but will create a terminal problem within the system. Toyota will void the warranty anything caused by the aftermarket parts and accessories. If you are installing the lights that can be controlled independently by connecting them directly to the battery and running the switch to the dashboard, you are better off doing that, than piggybacking the other components. You can run things to the battery, with relay, and its own fuse and switch. But avoid installing LED bulbs in the overhead map reading lights or licenses plate lights, or any LED light strips tapping into the parking lights or other components. Save yourself frustration and money.
  19. Dec 8, 2019 at 7:02 AM
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    Damn....didn’t realized these could cause problems. Just ordered the headlight revolution interior LED kit.
  20. Dec 8, 2019 at 7:39 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Most times (not always) when people talk scare tactics, they have ulterior motives. To me, it sounds like something a Toyota employee would spread the word on, so you pay them for their parts and service.
    No ulterior motive with this comment and I know you agree ...DISCONNECT THE BATTERY WHEN REPLACING LIGHTS. It takes 30 seconds
    nvrgvup444 and NewImprovedRon like this.
  21. Dec 13, 2019 at 8:17 PM
    ProtoJ
    ProtoJ New Member
    So has everyone switched back to the stock bulbs or do the LEDs work? I have my interior LED kit sitting on my work bench but now I’m scared to put them in after reading this!
  22. Dec 13, 2019 at 8:59 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Nope, haven't switched back. LED on interior and 3rd brake light.
    Disconnect the battery when installing. It's so easy to do and you likely won't run into the same problem everyone is having with blow fuses and other issues.
    I disconnected for each bulb. Dry fit the negative back on after each was installed to ensure connection and polarity. Turns out each bulb was installed correctly or the polarity didn't matter. But I wasn't going to take chance with electrical issues or fuses and have the battery blow something to save me 30 seconds on each bulb by having to disconnect it.
    The LED on the interior is amazing.
    NewImprovedRon likes this.
  23. Dec 15, 2019 at 1:16 PM
    ProtoJ
    ProtoJ New Member
    That was the easiest upgrade! They are amazing. I can’t even believe how much brighter they are than factory!
  24. Dec 25, 2019 at 4:37 PM
    BrennanC0212
    BrennanC0212 New Member
    Brennan
    Atlanta, GA
    2014 Toyota Tundra Platinum - White
    Any idea how I should fix my issue? I bought the same HR kit and when replacing them, they won’t work anymore. Thinking I blew a fuse like you guys mentioned. I didn’t disconnect the negative terminal, really wish I would’ve read this thread before. How should I fix my issue?
  25. Dec 25, 2019 at 7:15 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I blew the fuse accidental doing the dome lights. Slipped and touched both contacts at once.
    TS1794 and BrennanC0212[QUOTED] like this.
  26. Feb 4, 2020 at 4:02 AM
    adaird
    adaird New Member
    Is there any other fuse (besides "Dome" under the hood) and the Dome relay I could check to solve the issue with interior lights? I have a 2014 Tundra and changed out all dome and map lights to LED and when proceeding the same change of the footwell light on the driver's side, all door switches stopped working. Basically, all the dome lights come on if I manually switch the dome light to "on", but if I switch it back to "door", they don't come on when I open a door. I wouldn't think it would have anything to do with the individual door switches themselves since the dome lights don't come on regardless of what door I open. I checked all fuses under the hood and in cabin that I could find. Any help would be appreciated. Thanks-
    MRG likes this.
  27. Feb 4, 2020 at 10:50 AM
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    I blew mine yesterday installing LEDs from footwell light. There is a small fuse box along interior driver side wall, there is a 10a dome fuse I blew.
  28. Feb 4, 2020 at 10:53 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Toyota is the only one I know of that cant handle a bulb change without disconnecting the battery
    It in itself is a fucking fuse
  29. Feb 4, 2020 at 6:16 PM
    adaird
    adaird New Member
    My dome fuse is under the hood (I have a 2014). I already checked that fuse to see if it was the culprit, but it's still good. Actually tested every fuse in both boxes (under hood and in diver's side footwell fuse box). Thanks for the suggestion though.
  30. Feb 4, 2020 at 6:34 PM
    adaird
    adaird New Member
    I'm still looking for suggestions if anyone has any. I tested all fuses in both fuse boxes (under hood and in the cabin) with a tester and all are good. The dome and map lights work when I turn the dome switch to "on" but won't work when it's set to "door". Doesn't matter which door is open, none of them trigger the dome lights to come on. I'm baffled. The footwell light is not working either even when I turn the dome light to "on", but I don't remember if that typically came on or not when you open the door?? When I put my tester in the socket of where the footwell bulb goes, my tester lights up. It will even light the bulb up if I put it in there while the bulb is still in the socket. Not sure if that provides any more clues to the mystery. Could the switch for the dome light be bad when in the "door" position, but still work when in the "on" position??? I don't know enough about how those work. Thanks for suggestions.
