My attempt at 100K maintenance
Discussion in '2.5 Gen Tundras (2014-2021)' started by Damie Street, Mar 23, 2024.
  1. Mar 27, 2024 at 5:47 AM
    #61
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The Care Care Nut videos are a very good source of information and you can't go wrong with his information. Brake fluid is hygroscopic meaning that it absorbs water as it ages and the reason for changing it. You can get brake fluid test strips at any parts store and you can test the brake fluid fo make sure you need to change it.
  2. Mar 27, 2024 at 5:54 AM
    #62
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Don't bother draining the engine block. Just drain the fluid. You will get enough of the coolant out. When we do a fluid exchange at the dealership just the rad is drained. You will never get out all of the coolant. It's the same when you do the transmission service. You are just draining the oil that's in the pan and your only getting about a third of the oil that's in the transmission.
  3. Mar 27, 2024 at 5:57 AM
    #63
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It's not woth the risk on opening brake bleeder screws when someone is this new to mechanical service work and he would have to bleed the system afterwards which, if done wrong, can be a safety concern.
  4. Mar 27, 2024 at 5:59 AM
    #64
    Damie Street
    Damie Street [OP] New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    So just drain the coolant in the radiator and fill it back up with a gallon of Toyota LLC. Drain from the plug on the bottom of the radiator next to the skid plate? Making sure I understand correctly? I did all ready buy 3 gallons of the Toyota LLC from the local dealership, wonder if I will be able to return the other 2 gallons?
    Ruggybuggy[QUOTED] likes this.
  5. Mar 27, 2024 at 6:01 AM
    #65
    Damie Street
    Edsel
    South Carolina
    So best to wait to bleed until I replace the brake line with SDHQ brake lines?
  6. Mar 27, 2024 at 6:04 AM
    #66
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes, very easy to do. You will only need just over a gallon on coolant. I just did mine a couple of months ago and I needed just over a gallon. Buy two gallons and save the what you have left over for top ups or your next coolant service.
    Find a clean length of tubing that fits over the radiator drain that way you can monitor the coolant as it's draining. You can buy it at many hardware stores.
  7. Mar 27, 2024 at 6:07 AM
    #67
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Why do you want to replace your brake lines?
  8. Mar 27, 2024 at 6:08 AM
    #68
    Damie Street
    Edsel
    South Carolina
    Awesome. Thank you for the advice and guidance. I should be able to knock out both the brake fluid and coolant tonight, weather permitted.
  9. Mar 27, 2024 at 6:09 AM
    #69
    Damie Street
    Edsel
    South Carolina
    Maybe within the next couple of months. There is no real rush, I hope?
  10. Mar 27, 2024 at 6:10 AM
    #70
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    What's wrong with your brake lines?
  11. Mar 27, 2024 at 6:12 AM
    #71
    Damie Street
    Edsel
    South Carolina
    Nothing really. I am going to install Bilsten 6112/5160s on the truck this summer so figured better and a little longer brake lines will be needed. Please correct me if I'm wrong with this thought path.
  12. Mar 27, 2024 at 6:19 AM
    #72
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Most lifts don't require brake lines. The only issue I have seen is a tight rear brake flex hose on a moderate lift but it just required bending the bracket down to give some slack.
  13. Mar 27, 2024 at 6:25 AM
    #73
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
  14. Mar 27, 2024 at 6:28 AM
    #74
    Damie Street
    Edsel
    South Carolina
    Someone is getting ready!! Gun safe that its all stacked on?
    ToyoMafia[QUOTED] likes this.
  15. Mar 27, 2024 at 6:30 AM
    #75
    Damie Street
    Edsel
    South Carolina
    Did you find a sale? Or just resupplying? I know you like to stay stocked on detailing supplies.
  16. Mar 27, 2024 at 6:50 AM
    #76
    ToyoMafia
    Magic carpet.
    I have the premium account (or whatever they call it) I got a free screwdriver on this $500 order lol
  17. Mar 27, 2024 at 6:51 AM
    #77
    ToyoMafia
    Magic carpet.
    That’s a get rid of safe from years ago.
  18. Mar 27, 2024 at 6:56 AM
    #78
    Damie Street
    Edsel
    South Carolina
    I'm in the market for a gun safe with shelves for ammo, cleaning kits and what nots and be able to fit a few rifles, shotguns and pistols. I would like to spend around $600, so looking at ones from tractor supply.
  19. Mar 27, 2024 at 7:04 AM
    #79
    ToyoMafia
    Magic carpet.
    Check Costco also. I recommend to all my friends a $600-$1000 safe. It doesn’t need to be a super expensive one to get the job done.
  20. Mar 27, 2024 at 7:06 AM
    #80
    ToyoMafia
    Magic carpet.
    I’m a huge advocate of gun safes. I believe if you own firearms they should have a “safe” place. I got mine once we had kids. My kids all shoot and wouldn’t mess with them without me but I don’t trust their friends.
  21. Mar 27, 2024 at 9:17 AM
    #81
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
  22. Mar 27, 2024 at 9:26 AM
    #82
    ToyoMafia
    Magic carpet.
    Damie Street[OP] likes this.
  23. Mar 27, 2024 at 10:26 AM
    #83
    Damie Street
    Edsel
    South Carolina
    That's an excellent idea!!
  24. Mar 27, 2024 at 10:40 AM
    #84
    parkerbows
    Jack
    Yeah I have a 5x10 trailer I used and a few guys for help
  25. Mar 27, 2024 at 12:20 PM
    #85
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    ToyoMafia likes this.
  26. Mar 27, 2024 at 12:39 PM
    #86
    Damie Street
    Edsel
    South Carolina
    Columbia. Where abouts for you?
  27. Mar 27, 2024 at 1:11 PM
    #87
    Ebrperk
    Ebrperk New Member
    2016 SR5 4wd Crewmax
    Factory LED headlights with ihacker harness, Bilstein 6112,s at 2" lift and 5100 in back, SABM, rear diff breather mod, Firestone Destinations AT2, metal oil filter mod, fumoto oil drain, stock skidplate mod to access oil filter
    KNABORES and ToyoMafia[QUOTED] like this.
  28. Mar 27, 2024 at 1:12 PM
    #88
    Damie Street
    Edsel
    South Carolina
  29. Mar 28, 2024 at 4:03 AM
    #89
    Damie Street
    Edsel
    South Carolina
    Update:
    Was unable to work on the truck yesterday due to weather. But ordered a couple more items for the maintenance.
  30. Mar 28, 2024 at 4:40 AM
    #90
    morgaj1
    morgaj1 New Member
    AL
    2021 Tundra Platinum CM 4x4
    What is the item to right of the fluid extractor in the picture above?
