My attempt at 100K maintenance
Discussion in '2.5 Gen Tundras (2014-2021)' started by Damie Street, Mar 23, 2024.
  1. Mar 28, 2024 at 5:05 AM
    #91
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Those will come in handy for the transmission fluid change.
  2. Mar 28, 2024 at 5:32 AM
    #92
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Hang on, you don't have to pull the skid plate? I thought for sure my TRD skidplate would block access, it's bigger than the off-road package skid!
  3. Mar 28, 2024 at 5:42 AM
    #93
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm referring to the stock skid plate.
  4. Mar 28, 2024 at 7:17 AM
    #94
    Damie Street
    Damie Street [OP] New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    I am hoping to knock out the coolant tonight. *fingers crossed that the weather holds out to allow this. I am really trying to knock out the rest of the schedule maintenance prior to leaving next week Wednesday for a little road trip.
  5. Mar 28, 2024 at 9:18 AM
    #95
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    The scanner, yes. The fluid syringe, no.
    Go grab two things for the trans fluid swap. One is a simple $5 oil jug adapter that you can get at Walmart.
    https://www.walmart.com/ip/Hyper-Tough-Gear-Oil-Fluid-Plastic-Funnel-Spout-10106/636907435
    It screws right on to the Toyota WS jugs. Pull off the short clear hose and toss it in a drawer somewhere.
    Go to Home Depot/ Lowe’s/ or similar and buy 5’ of clear vinyl hose from their bulk rolls. You want 1/2” inside diameter with a 5/8” outside diameter.
    Shove the Walmart bottle adapter into the end of the hose and slide the other end down behind the driver’s side valve cover from the engine bay. You can grab this end from below and slip it into the trans fill hole that is above the front driveline. Fits real nice like.
    When you fill the trans from above, just jab a screwdriver or knife into the bottom each quart of WS to vent it.
    Henry1jg likes this.
  6. Mar 28, 2024 at 9:34 AM
    #96
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    Ditto on this. See this video - about 2:20 in you'll see how this works.
  7. Mar 28, 2024 at 10:44 AM
    #97
    Damie Street
    Edsel
    South Carolina
    That is actually what I have and plan to do. Great minds think alike. Well the idea came from a video. Haha
    Edit: from the above mentioned video
  8. Mar 28, 2024 at 10:49 AM
    #98
    Damie Street
    Edsel
    South Carolina
    Waiting for the engine to cool before I start the coolant! Going to do the brake fluid on Saturday. Hopefully the transmission on Sunday or Monday.
  9. Mar 28, 2024 at 1:04 PM
    #99
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    I use those on my wife Highlander. Don't use them on the Tundra. They go on top of the jack stands and fit where the jack points are on the body
    Damie Street[OP] likes this.
  10. Mar 28, 2024 at 1:23 PM
    #100
    Damie Street
    Edsel
    South Carolina
    Sorry yes those go on the jack stands. Would like no metal to metal contact if I can help it.
  11. Mar 28, 2024 at 1:26 PM
    #101
    Damie Street
    Edsel
    South Carolina
    Coolant was a breeze. Followed @Ruggybuggy guidance. Longest part was waiting for the radiator to finish draining. About 1 1/2 gallons of Toyota LLC.
    Thanks to everyone's advice and guidance these jobs are getting done.
  12. Mar 28, 2024 at 1:52 PM
    #102
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I personally like the syringe method. The one I use at home has inlet and outlet. I drill a half inch hole in the cap of a 4 litre container of trans fluid and insert my clear inlet hose then the exit hose in the transmission. Pump the syringe and I can empty the 4 litre container in about six pumps. Faster then waiting for 1 litre bottles to drain. To each his own.
    Henry1jg and Damie Street[OP] like this.
  13. Mar 28, 2024 at 4:25 PM
    #103
    Chad D.
    Chad D. New Member
    Western Oregon
    Ah-ha. Different syringe from the sound of it. Yours sounds really slick!
    Ruggybuggy[QUOTED] likes this.
  14. Mar 30, 2024 at 1:57 PM
    #104
    Damie Street
    Edsel
    South Carolina
    Anyone done their front diff yet? Curious how much gear oil is needed. I bought 2 quarts. One video I saw said 2.1 quarts. So my question is the .1 really necessary?
  15. Mar 30, 2024 at 3:12 PM
    #105
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Did you have any left from the rear diff service?
  16. Mar 30, 2024 at 4:16 PM
    #106
    MedCityMoto
    You should be filling it on a level surface, and it should be just overflowing slightly from the fill hole. Should be around 2.1 or 2.2 - if it took less, you might need to let it sit a minute and top it off.
  17. Mar 30, 2024 at 5:11 PM
    #107
    meeseeks55
    meeseeks55 New Member
    2002 SR5 Access Cab 3.4L V6
    If you don't want to wait 10k you could always just do 3 drain and fills back to back within like a week or a months time. Some manufacturers actually suggest this for dirty fluid.
  18. Mar 31, 2024 at 6:27 AM
    #108
    Damie Street
    Edsel
    South Carolina
    No. I made a horrible mess. :rofl:
  19. Mar 31, 2024 at 7:32 AM
    #109
    MedCityMoto
    Recommendation! $20 gets you like a 50? 100? pack of XL absorbent puppy pads on Amazon. These are amazing at helping keep oil off the floor during any fluid changes, throw down 3-4 and toss 'em after. I've had a large box I'm slowly working through over the last 2 years, and that's doing all the fluids for 4 motorcycles, 2 cars and my truck. Work great for cleaning firearms on too.
  20. Mar 31, 2024 at 9:56 AM
    #110
    Damie Street
    Edsel
    South Carolina
    That's a great idea. Thank you!!
  21. Mar 31, 2024 at 3:08 PM
    #111
    Chad D.
    Chad D. New Member
    Western Oregon
    Probably a better idea than parking over a storm drain in the gutter. Gotta be real careful if you do that. Too easy to drop the drain bolt through the grate, and then you’re in trouble.
    Leo's first likes this.
  22. Mar 31, 2024 at 6:33 PM
    #112
    fallen0
    fallen0 New Member
    2017 Tundra TSS Off-Road
    Fill for me was about 2qt.
    Hardest part was getting the drain bolt off. It is a 10mm Allen hex. Needed to use a foot on my breaker bar to get it off. Leard of the Lexus drain bolt and will get that for next time.
  23. Mar 31, 2024 at 9:34 PM
    #113
    MedCityMoto
    Would suggest you grab the Kaon drain plug instead. 24mm head on it vs the 14mm Lexus one, and the material's hardened a bit more I honestly believe. It's a $35 thing I hope to not need replace, I've already replaced my drain plug twice now, looking for this to be the last on it. Takes a month to arrive from Australia, but designed for offroad conditions in the Outback.
    Model's KS0127 - https://www.kaon.com.au/front-diff-drain-plug-to-suit-toyota
  24. Mar 31, 2024 at 9:48 PM
    #114
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    When you go to service the front diff, undo the fill plug first then the drain plug. You want to make sure you can get the fill plug open first. Pro-tip, before you insert your allen socket, make sure the it clear of debris. When the allen is inserted, use a small hammer and tap on the end of the allen socket a bunch of times. It helps break the drain plug free. I've never stripped one and I've undone a lot of them.
  25. Apr 1, 2024 at 7:29 AM
    #115
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Dave, is there a burping procedure after the drain and fill of the radiator to get the air out? I have been convinced that I can do it, saving the 200+ dollars that the dealer wants. I love this place...
    Norfolk757 and Damie Street[OP] like this.
  26. Apr 1, 2024 at 7:35 AM
    #116
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Very easy to do. It's unlikely you will get an airlock doing a drain and fill. If you have some car/truck ramps that most shade tree techs do, run it up on the ramps gets the radiator fill the highest point in the cooling system.
  27. Apr 1, 2024 at 8:42 AM
    #117
    fallen0
    fallen0 New Member
    Sweet thanks!
  28. Apr 1, 2024 at 8:48 AM
    #118
    Bammer
    Monroe, CT
    Right stuff ?
    00272-1LLAC-01
  29. Apr 1, 2024 at 8:52 AM
    #119
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That appears to be the long life coolant. You want the super long life coolant.
  30. Apr 1, 2024 at 9:30 AM
    #120
    Bammer
    Monroe, CT
    Ok, Thank you Dave
