Obd2 scan tool for transmission temp
Discussion in '3rd Gen Tundras (2022+)' started by 389 24/7, Mar 27, 2024.
  1. Mar 27, 2024 at 8:32 PM
    389 24/7 [OP] New Member
    2022 TRD OR
    Does anyone have or know of a obd2 scan tool for gen3 tundra that shows tranny temp?
  2. Mar 27, 2024 at 8:51 PM
    Hella Krusty
    Hella Krusty New Member
  3. Mar 28, 2024 at 5:54 AM
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    For other vehicles I use the OBD Link MX+. But for some reason they haven't updated to read out 22+ Tundras. Hopefully its imminent.
  4. Mar 28, 2024 at 6:44 AM
    raylo
    raylo not so new member
    Frederick, MD
    None
    ScanGage 2 and 3 can report trans fluid and engine oil temps.
    389 24/7[OP] and Xcumminsguy like this.
  5. Mar 28, 2024 at 7:29 AM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
  6. Mar 28, 2024 at 8:38 AM
    2022 TRD OR
    Thanks!
  7. Mar 28, 2024 at 8:38 AM
    2022 TRD OR
    Thank you
  8. Mar 28, 2024 at 10:51 AM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
  9. Mar 28, 2024 at 11:07 AM
    jctmundra
    Northern VT
    Careful with the dongle, do your research. I have had 3 different inexpensive dongles cause issues with a GM vehicle, appears to be spewing noise onto the canbus. Occasional connect was ok, it's when left on the port that issues arose.
  10. Mar 28, 2024 at 11:13 AM
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    I have the Carista and still in the free month trial. I’ll check shortly and see if it gives trans temp. I have only used to to turn the fake engine sound off so far but didn’t mess around with it much after doing that. Will keep you posted.
    edit: just confirmed it will give you live trans temp. But you would need to open the app and check it.
    389 24/7[OP] likes this.
