Strawberry Milkshake of Death or Paranoia?
Discussion in '1st Gen Tundras (2000-2006)' started by KSteng, Mar 27, 2024.
  1. Mar 27, 2024 at 4:52 PM
    KSteng
    KSteng [OP] New Member
    Kyle
    2005 Tundra SR5 V8 4x4
    Hello! I'm a new 1st gen Tundra owner as I just bought an 05 Tundra today! Leading up to buying it, I've been doing a lot of research and forum digging on common issues and whatnot. A common problem I saw was the "strawberry milkshake of death" caused from coolant and trans fluid mixing. When I was looking the truck over, after looking at the frame (spotless), I noticed around the radiator cap was a little bit of hard, dry, crusty coolant. The coolant in the reservoir and radiator doesn't seem to be cloudy to me and I tried to capture that in the photos. I'm either paranoid, dumb, or both but either way, I would love a second opinion on what you guys think this is from. Thanks!
  2. Mar 27, 2024 at 4:55 PM
    shifty` One great big festering neon distraction
    That's totally normal. Coolant crystalizes after evaporation.
    Jack McCarthy and FrenchToasty like this.
  3. Mar 27, 2024 at 4:56 PM
  4. Mar 27, 2024 at 4:56 PM
    CCE525
    CCE525 New Member
    Chad
    2000 SR5
    None
    Looks good to me! Little crust is normal.
    FrenchToasty likes this.
  5. Mar 27, 2024 at 4:57 PM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    Looks fine to me. The pink milkshake on our trucks is possible but not extremely common. Even less common if you replace an old radiator.
    Post some pictures of your new truck and congrats.
  6. Mar 27, 2024 at 4:59 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Rockford Fosgate DSR1, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    toyota uses pink coolant, so you won't see the neon green color if that is what you were expecting.
    Lifer likes this.
  7. Mar 27, 2024 at 4:59 PM
    x2 on this.
    Clearly that truck was NOT living in the rust belt at any point. All fasteners in the front look clean as a whistle.
  8. Mar 27, 2024 at 5:07 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    +1 looks normal for Toyota coolant. Appears your radiator cap may be leaking a bit - I’d replace. The place to look for milkshake is in the transmission fluid. That’s where it does the damage.
  9. Mar 27, 2024 at 5:14 PM
    KSteng
    Kyle
    Alright so paranoid it is. Thank you guys for your quick responses!
  10. Mar 27, 2024 at 5:16 PM
    BoyHowdy
    BoyHowdy New Member
    2021 Tundra
    Just how I like my brisket
    KSteng[OP] likes this.
  11. Mar 27, 2024 at 5:19 PM
    KSteng
    Kyle
    Will do! I actually live in the rust belt but it was taken care of and garage kept its whole life.
  12. Mar 27, 2024 at 5:21 PM
    That's wild! Normally rust belt trucks will have rust on clamps and fasteners in the engine bay. And rust inside the hood latch, etc. Looks good, considering.
  13. Mar 28, 2024 at 6:55 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    Coolant looks good to me.
