Your thoughts on wheel spacers?
Discussion in 'Wheels & Tires' started by mrburns05, Sep 19, 2018.
  1. Sep 28, 2018 at 6:16 AM
    ELKAHOLIC
    ELKAHOLIC New Member
    2018 MGM DC
    Thanks. 3” readylift up front, 1.5 AAL in the rear. 35/12.5/R18 Gladiator Xcomps.
  2. Sep 28, 2018 at 6:34 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I understand one of the times it be best to avoid spacers or low offset tires is when hauling big payloads or towing heavy with high TW, but I suppose most of us didn't buy a Tundra for those attributes.
    Sampson likes this.
  3. Oct 13, 2018 at 10:04 PM
    Hunterd_22
    Hunterd_22 New Member
    Hunter
    Kentucky
    2010 Black Tundra Rock Warrior
    How do you like the tires? How’s the wear on them?
  4. Aug 5, 2019 at 5:47 AM
    dbuckman
    dbuckman New Member
    David
    2019 Black Tundra TRD Sport
    2" level
    Are you running 12.5’s on 18x8 wheels?
  5. Aug 5, 2019 at 6:25 AM
    Justin Case
    Justin Case New Member
    TX
    Spacer are for suckers. I just pull the wheels, turn them around, then re mount on hub. Go from a +60 to -60 with no extra parts. Instant "stance" improvement...
    Wheels with correct offset are always the right answer.
  6. Aug 5, 2019 at 12:24 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    @phogallen there Nitto Ridge Grapplers 295's, low road noise. I like them so far. Got around 8k on them
    Watt maker likes this.
  7. Jun 12, 2020 at 12:08 AM
    Guti94
    Guti94 New Member
    2012 Toyota tundra
    Are the studs on the spacers longer than stocks I’m having trouble getting full engagement from lugs on my aftermarket wheels and hoping I can just get spacers...
  8. Jun 12, 2020 at 4:14 AM
    What wheels and lug nuts do you have? You may need an ET lug nut. Pics will help.so that we can see what you have.
    Voyagermike likes this.
  9. Jun 12, 2020 at 7:14 AM
    Guti94
    Guti94 New Member
    2012 Toyota tundra
    I have vtx wheels and the et lugs don’t work.
  10. Jun 12, 2020 at 7:17 AM
    Others will chime in. I'm not familiar with VTX wheels.
  11. Aug 1, 2020 at 10:39 AM
    TonyNCo
    TonyNCo New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    What is minimum spacer thickness to not have to cut wheel studs? Previous spacers on a different truck caused issues due to cutting.
    Are wheel studs a simple replacement on these Tundras? My previous truck the axle shafts had to come out!
  12. Aug 1, 2020 at 5:31 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    I just noticed your grill badge. HA!
  13. Aug 6, 2020 at 2:33 PM
    65SNAKE
    65SNAKE New Member
    RON
    2020 TRD PRO
    Did you have to change and of the lug nuts or studs? I'd like to keep the factory lug nut showing...
  14. Aug 6, 2020 at 2:54 PM
    Hurricane
    Hurricane Default: Aggressive
    NC
    2017 White 1794
    None
    Why not just buy longer studs?
  15. Aug 7, 2020 at 5:16 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    No sir. Now running SCS wheels, but stock studs still. No issues!
    65SNAKE[QUOTED] likes this.
  16. Aug 9, 2020 at 10:14 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    For those that have run spacers on the stock TRD Off Road wheels, is there enough of an indent on the back of the wheel mounting surface to allow the studs to recess when using a 1" BORA spacer? I tried searching for pics of the back of the wheels but no joy.
    I guess I could go pull one off, and will probably do that tomorrow after work, but figured I'd ask if any has confirmed/denied this already.
    I've seen conflicting info here, some say 1" will fit since the stock studs will fit into the recesses in between the bolt holes, and some say the stock studs are just too long and a 1.25" is required.
    If someone has a pic of the back of the wheels that would be awesome as well.
  17. Aug 18, 2020 at 1:33 AM
    Nifty_Nate
    Nifty_Nate New Member
    Beautiful!
    65SNAKE likes this.
  18. Aug 19, 2020 at 2:48 PM
    65SNAKE
    65SNAKE New Member
    RON
    2020 TRD PRO
    I just installed 1 1/2" spacers on my 2020 TRD PRO from Supreme Suspensions...about $260.00. T6 billet hdub centric. Factory studs could have been about 1/4" longer and still not protruded beyond the spacer but there should be enough thread to do an adequate job. Installed very nicely with no issues. Used red locktite as instructed and will recheck torques in about 100 miles (also as instructions say). Both sets of lug nuts were torqued to 130#'s. Called the dealer and he told me they torque to about 110 and called a tire store and they torque Tundra's to about 120#'s. Before I took the wheels off I checked the torque on all four wheel (lug nuts), and they averaged 126#'s from the factory. Test drive proved very smooth so I said, I'll check the torques again in about 100 or so miles. I'd post pics but have a new phone and no cord for the computer. The wheels look great as I also added factory color matched flares.
    GELCW likes this.
  19. Aug 19, 2020 at 2:58 PM
    #49
    throughitalldude
    throughitalldude New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    I run them. I use only spidertrax and have never had any issues. Follow the instructions and ignore negative comments..... easy!
    TheBubbaDude, 65SNAKE and Black Wolf like this.
  20. Aug 21, 2020 at 4:05 AM
    #50
    TheBubbaDude
    TheBubbaDude New Member
    2020 Tundra TRD Pro
    AJT Blackout Kit 1.25" Wheel Spacers NRG 285/70/18 Meso Customs TRD Start Button
    Beautiful build!
  21. Aug 21, 2020 at 4:22 AM
    #51
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Been running Spiders ,front only , for over a year ,also wanted to keep rims , went with 35x12.5 20 , Cooper ST Max , rims have 52 offset, only had to remove front mud flaps. Looks and runs great. As far as wheel bearings go , the larger heavier tires with wider grip is harder on bearings. IMG-0727.jpg IMG_0707.jpg I also run lug nuts purchased from Camburg, with collars that go down into rim. Also have ToyTech Boss 3/2 level kit.
  22. Nov 3, 2020 at 3:54 AM
    #52
    Derf77
    Derf77 New Member
    South Chesterfield VA
    2020 Crewmax SB SR5 TRD Off Road
    TRD rear sway bar, Ready lift 3/1, 4 window auto up/ down.
    Are you running a 3/2 lift?
  23. Nov 3, 2020 at 4:49 AM
    #53
    rons23
    Ron
    Kill Devil Hills
    I'm running 6112's @ top setting 2 1/2" - 2 3/4" with 1" tapered block in the rear.
    Derf77[QUOTED] likes this.
  24. Nov 3, 2020 at 4:50 AM
    #54
    65SNAKE
    65SNAKE New Member
    RON
    2020 TRD PRO
    IMG_0320.jpg IMG_0319.jpg I added a set of 1 1/2" SUPREME. Kept the stock wheels because they were another reason to buy the PRO. Also kept the stock Michein tires because their smooth and quiet. I don't off road much so I'm not going larger or more aggressive. Have no issues with rubbing or getting close to the mud guards. Like the other members say, be sure to use the proper torque and, recheck the torque on the wheels and spacers after a hundred miles or so.:thumbsup:
    gkelm, TelemarkTumalo and rons23 like this.
  25. Mar 28, 2024 at 8:10 AM
    #55
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Man that truck looks mean! Love it. Makes me want to get spacers when I do my lift. Thinking 1”-1.12”.
  26. Mar 28, 2024 at 8:56 AM
    #56
    Just get different offset wheels.
  27. Mar 28, 2024 at 9:35 AM
    #57
    therealjonwick
    JR
    2019 OR
    That’s the plan when my current tires wear out. Sadly I purchased them in the fall when I first got the truck. Stupidly I thought I wouldn’t end up lifting it haha
