Spark plug change, how difficult?
Discussion in '3rd Gen Tundras (2022+)' started by Oldandfat, Jan 31, 2023.
  1. Nov 19, 2023 at 9:29 AM
    #91
    Breathing Borla
    those don’t look bad at all
  2. Jan 12, 2024 at 5:51 PM
    #92
    virgilus11
    virgilus11 New Member
    2022 Tundra Capstone
    1/2" front spacer 37" Cooper ATX
    Did change them today
    The one closer to the cab, left and right bank, where the one darker. See the pic attached. The other four where in pretty good shape. IMG_0227.jpg
    I started on the driver side and it took me about an hour. The passenger side it took me about 30 minutes.
    mayan, ryanwgregg, raylo and 2 others like this.
  3. Jan 12, 2024 at 7:09 PM
    #93
    ArBrnSnpr
    ArBrnSnpr New Member
    Colin
    22' AG SR5 TRD OR
    ^^^ Notice any difference after the swap?
    I have some slight hesitation under throttle that feels like it could be plugs, but I only have 6,500 miles so I'm inclined to think plugs aren't the culprit.
  4. Jan 12, 2024 at 7:13 PM
    #94
    virgilus11
    No difference that I feel.
  5. Jan 12, 2024 at 8:50 PM
    #95
    HLR_NM
    HLR_NM New Member
    Harry
    Tundras.com: 80k is fine for a plug swap!
    Also Tundras.com: 10k is way too long for oil change intervals!
    I love this place :rofl:
  6. Jan 12, 2024 at 9:19 PM
    #96
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Love me some Rockauto !!
  7. Jan 12, 2024 at 9:57 PM
    #97
    Tom976
    Tom976 New Member
    Tom
    Nobody is using antiseize on the plugs anymore? I would pop the plugs just to put that on. Well maybe.
  8. Jan 12, 2024 at 10:40 PM
    #98
    HLR_NM
    HLR_NM New Member
    Harry
    Antiseize can prevent thread galling but it also lowers the torque spec by 10-20% - use with care. Modern iridium plug threads are already plated and there’s no need to use antiseize. NGK for example has a nickel chromium plate (IIRC) and are designed to be installed dry.
    Any time you have dissimilar metals in contact there will be a redox reaction. In the old days of steel plug threads and cast iron heads all you needed was a little engine oil. The plating or antiseize is intended to act as a sacrificial metal barrier that separates and protects the threads of the aluminum head and steel plug (prevents galling).
    That said I’ve been known to use a tiny dab of copper antiseize on spark plugs but I’m super careful not to over torque the plugs.
  9. Jan 13, 2024 at 4:47 AM
    #99
    raylo
    raylo not so new member
    Frederick, MD
    None
    I used to really love them back in the day, but their shipping has gotten very $$ and very slow. At least last couple times I used them. So now I look elsewhere first.
  10. Apr 26, 2024 at 11:11 AM
    #100
    KA22TRD
    KA22TRD New Member
    Kevin
    2022 White Tundra SR5 TRD
    Level lift
    This thread helped!! Pretty easy job (except for #6) knocked it out in an hour and a half. 58K miles reference picture
  11. Apr 26, 2024 at 4:57 PM
    #101
    lapoolboy
    lapoolboy New Member
    Run any better?
